Old 03-22-2018, 03:36 PM   #127
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
I'm probably going to change my starting IAM to .9 or 1. On most of my drives the IAM only makes it up to .84-.87 before I reach my destination.
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 03-22-2018, 04:30 PM   #128
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
All roms pre 2017 now based on A01I rom so should work. IAM initial on e85 roms is stil! 1
Mine is still 1 on the petrol tune. I thought it was odd, but saves me the trouble of modifying it!
Weigaldo is offline   Reply With Quote
Old 03-22-2018, 04:47 PM   #129
Jasonb
Drives: 17 Series Yellow BRZ
are you using 93?
Jasonb is offline   Reply With Quote
Old 03-22-2018, 04:55 PM   #130
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
2015 FRS AT
Had the v4 stage 2 (catted aftermarket, shell 93) tune on for a few days now and it feels great.
The quieter cold start is worth going to the new tunes by itself.
Shifting feels smoother in low to mid throttle from 2->3 and 3->4. not sure if that is placebo or improvements to fueling or other inputs around the shift points.
My IAM has been at 1 everytime i've started the car.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 03-22-2018, 05:15 PM   #131
DaveyBonesJones
Drives: 2013 Scion FRS
I just put about 37 mi on the car with the 4.01 stage 2+ E85. Car feels very smooth at idle and through the mid range. At cruising speeds under light load the fuel trims stayed pretty balanced around 3.25 to around 4.3. My gas pedal does still have some dead space though. Hopefully it works itself out a little better.
All this is on my 13 FRS MT with equal length, non catted header and 2.5" over pipe, stock front and mid pipe with a muffler delete.
Cheers'
DaveyBonesJones is offline   Reply With Quote
Old 03-22-2018, 05:28 PM   #132
timmydatooth
Drives: Scion Frs
Originally Posted by Tectoniic View Post
2015 FRS AT
I have a Q300 as well but with a tomei UEL uncatted header on my 2013 Scion FRS Automatic. I have the v2.076 tune right now do you think this new v4 tune would help with my cold start loudness and smother shifting as well?
timmydatooth is offline   Reply With Quote
Old 03-22-2018, 05:33 PM   #133
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I used the 2.076 tunes and the 3.xx tunes in the past and it is so much quieter on the cold start. You still get the nice couple rumbles when you initially turn the key but then it quiets down nicely. The FT86 Catted header is a pretty low cell count so I would think the noise would be pretty close to the catless
I can't give any 100% true info on the smoother shifting as it might be placebo but it definitely feels less jerky.
The Following User Says Thank You to Tectoniic For This Useful Post:
timmydatooth (03-22-2018)
Old 03-22-2018, 05:47 PM   #134
BFIFE22
BFIFE22's Avatar
Originally Posted by Jasonb View Post
are you using 93?
Yes, Shell 93
Old 03-22-2018, 05:50 PM   #135
timmydatooth
Drives: Scion Frs
Will someone refresh my memory please, I have tomei UEL headers so I use the stage 2 tune right? The only time you use the stage 2+ is if you have the open flash headers correct? sorry its been awhile...
Old 03-22-2018, 05:51 PM   #136
BFIFE22
BFIFE22's Avatar
With the V4 tunes, Stage 2 is for catted aftermarket headers and Stage 2+ is for catless
The Following User Says Thank You to BFIFE22 For This Useful Post:
Old 03-22-2018, 05:54 PM   #137
timmydatooth
Drives: Scion Frs
no one has specified yet tho if these v4.0 tunes are safe for a 2013 Scion FRS from what I am reading these are only for the newer 2017+ gt86 am I wrong?
Old 03-22-2018, 05:59 PM   #138
BFIFE22
BFIFE22's Avatar
The V4's are compatible with the 2017's, but also the 2012-2016's
Old 03-22-2018, 06:24 PM   #139
Weigaldo
Weigaldo's Avatar
I just got P0420 after a pull on the way home from work. I’ll have to disable it this weekend.
Edit: Just checked and P0420 doesn’t show up in the trouble codes to be turned off. Any ideas?
Old 03-22-2018, 06:27 PM   #140
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Unless it's E85 which SHOULD be labeled Stage 1 but are misnamed as Stage 2+
guybo is offline   Reply With Quote
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
