Old 07-10-2012, 10:28 AM   #1
brzninja
brzninja's Avatar
Drives: 2015 WRB WRX Premium
Getting mixed responses about RPM
Hello! I've been trying to find what the rpm is when going 60-70 mph. I've been getting answers anywhere from 2500 to 3700 and I don't know which is true.
If an owner can clarify this for me that would be amazing!
Thanks!
2013 Subaru BRZ Limited WRB
brzninja is offline   Reply With Quote
Old 07-10-2012, 10:31 AM   #2
Synack
Boosted
Synack's Avatar
Drives: Sideways
Depends on what gear you are in...........
Synack is offline   Reply With Quote
Old 07-10-2012, 10:40 AM   #3
pyro530
Drives: Ultramarine FR-S 6MT
And what transmission you have.
I'm usually around 3k at freeway speeds, say 65mph
Current: FR-S Ultramarine 6MT - Took delivery 05/30/2012 - Now for sale here
1995 M3 Coupe MT - the "Bavarian Bumblebee"
Past: 1994 Integra - Sold | 2005 Dodge SRT-4 - Totaled by Hail | 1997 Acura 2.2 CL slowmobile - Sold | 1991 BMW E30 - Sold | 1991 Acura Integra GS - Wrecked | 1971 Chevy C-10 shortbed stepside - Sold | 1973 Camaro Z-28 Clone - Stolen
pyro530 is offline   Reply With Quote
Old 07-10-2012, 10:42 AM   #4
ZENBOX
ZENBOX's Avatar
Drives: DGM BRZ
In my BRZ when I'm cruising at 70mph in 6th gear, my rpm is right at 3K. Hope that helps.
ZENBOX is offline   Reply With Quote
Old 07-10-2012, 10:44 AM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Manual transmissions are around 3K. Auto transmissions will be around 2.5K due to higher gearing.
Old 07-10-2012, 11:05 AM   #6
brzninja
brzninja's Avatar
Sorry, I forgot to mention cruising at top gear.
Thanks for everyone's responses, I greatly appreciate it.
Old 07-10-2012, 11:06 AM   #7
Synack
Boosted
Synack's Avatar
Drives: Sideways
That's probably why they claim a higher MPG.
Old 07-10-2012, 11:11 AM   #8
Thanks!
Here's mine at 55/60/70MPH. The MT would be higher.
Old 07-10-2012, 11:50 AM   #9
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
This should help.
Note: P = Premium; L=Limited; AT=Auto; MT=Manual; FD2=4.1 Final Drive; FD1=3.727 Final Drive - No LSD (JDM-Only)
chart in MPH
Here it the same graph in kilometers per hour: link
Also, here it is for the FR-S: MPH KPH
Note: the BRZ Premium data is based on 16" tires for the japanese market, the North American market premium comes with 17" which is the same as the BRZ Limited version.
Last edited by azian_advanced; 07-10-2012 at 04:13 PM. Reason: Chart matches values from FR-S gauge cluster (photos from Dadhawk in previous post). Chart remains unchanged.
azian_advanced is offline   Reply With Quote
Old 07-10-2012, 12:08 PM   #10
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
Originally Posted by azian_advanced View Post
This should help.
OEM tire sizes (tire deflection due to vertical load neglected), OEM wheel sizes, final drive ratios, transmission gear ratios are all factored in on these charts.
I don't understand why so many posts use the wrong tire rolling circumference when taking the trouble to make a chart like this. You cannot just use the wheel size and nominal profile times tire width to calculate the rotations per mile of a tire: it simply doesn't work. But, you don't need to: the tire manufacturers standardize the rolling circumference so that speedometers will work. Just visit tirerack.com or Michelin's website and you can find out the correct rotations per mile for the various tire sizes. The value for 215/45R17 tires is 844 revolutions per mile. The correct chart for the MT limited should therefore show 59.0 MPH for 2nd gear at fuel cutoff of 7450 RPM.
60*7450/4.1/844 ./[3.626 2.188 1.541 1.213 1 .767]
ans =
35.6249 59.0383 83.8260 106.4928 129.1758 168.4170
Note that car speedometer displays are not necessarily exact. I once worked at a factory that made tachometers, gauges and speedometers for Ford and Chrysler. The speedometer settings were set to read about 1 MPH high at 60 MPH on average. I understood that the logic was that it was best to err slightly on the side of the driver thinking he was going faster than he really was to avoid arguments about causing speeding tickets etc.
Last edited by DSPographer; 07-10-2012 at 05:25 PM. Reason: Note that gauges do not necessarily show accurate MPH values.
DSPographer is offline   Reply With Quote
Old 07-10-2012, 12:12 PM   #11
Synack
Boosted
Synack's Avatar
Drives: Sideways
Ouch, no wonder the FR-S Auto is slow. Look at the graph. The auto 4th gear is the same as the MT 5th. They did the Manual perfect for gearing on the FR-S, I really like it.
Old 07-10-2012, 12:12 PM   #12
Synack
Boosted
Synack's Avatar
Drives: Sideways
So does this mean dynos are done in 5th gear MT and 4th gear AT?
Old 07-10-2012, 12:41 PM   #13
SkullWorks
Drives: SSM LT MT BRZ
please take down that graphic or fix it,
that is so far off it hurts to look at...
Old 07-10-2012, 01:38 PM   #14
brzninja
brzninja's Avatar
Exactly what I was looking for. Thank you!
Responses?"Scion FR-S kill (not surprising...) " mickey177 Scion FR-S / Toyota 86 GT86 General Forum 70 06-07-2012 07:45 PM
Mixed day today checking out my DGM Phaedrus29 BRZ First-Gen (2012+) — General Topics 61 06-03-2012 11:30 PM
