Old 03-21-2018, 10:02 PM   #113
steve99
Drives: FT86
Originally Posted by Weigaldo View Post
I just flashed my ecu on my lunch break and the car stayed at 1 IAM after the initial flash. I'll have to load up the xml in romraider tonight and check to see if the initial is at 1 or if maybe mine isn't reading right (F00D). I know before on the V2 it wasn't, and I needed V3 for it to work. I do have maf voltage on the V4 displaying properly though.
All roms pre 2017 now based on A01I rom so should work. IAM initial on e85 roms is stil! 1
Weigaldo (03-22-2018)
Old 03-21-2018, 10:05 PM   #114
steve99
Drives: FT86
Originally Posted by ThatDamnRanga View Post
Do I take it from this that I can alter the CALID and run on a car currently using an A02G map? Excepting fuelling matters (obviously have to use the '91' not '93' maps)
That's how it reads to me, but I don't really wanna risk a bricking.
RR2ECUFlash worked a treat. I may run the defs all through it today and upload them here for everyone's benefit
Basicly any 2012-2016 manual car will run on an A01G based map
XCO (03-22-2018)
Old 03-21-2018, 10:16 PM   #115
steve99
Drives: FT86
Originally Posted by ermax View Post
I'm new to this platform, actually new to flashing any ECUs for that matter. My understanding was you could read a rom without defs but could not flash a rom without correct defs. But reading your response here leads me to believe that correct defs aren't actually needed for flashing either. From the sounds of what you are saying, you only need correct defs to "edit" a rom.
Am I correct in this assumption? I mean, I've read so many times on this forum that you should check all the tables to make sure things don't look all wacky before flashing. Sounds like the advice should be, make sure the tables don't look all wacky if you plan to edit the table.
Not trying to create any confusion around here. Just looking for a better understanding of how this all fits together. Any time I flash a rom I'm a bit stressed. A better understanding would certainly reduce my stress level a little. Hahaha
Correct, you only need defs to edit roms, they are the index into the tables within the rom\tune.
If you just want to flash your just flashing the entire block of code so you dont need def, just a device that knows​ how to flash the ecu with the block of code. All ecu the code block is same size and gets flashed to same location in ecu.
Old 03-21-2018, 10:22 PM   #116
steve99
Drives: FT86
If you could provide a diff between the 'broken' def (Can confirm it is broken back in V2.076) and the corrected def would be great. My perfectionist instincts are kicking in.
Use kodename47 def here its has corrected table and more tables defined
Use text editor search fir the bad table name and compare between defs
http://www.ft86club.com/forums/showp...&postcount=107
Old 03-21-2018, 11:35 PM   #117
stlgrym3
has anyone with 2017 push button model 86/BRZ successfully used the V4 tunes yet?
stlgrym3 is offline   Reply With Quote
Old 03-21-2018, 11:36 PM   #118
stlgrym3
Originally Posted by Lightened View Post
Is the 2017+ K00D auto rom updated?
i'd like to know this too
Old 03-21-2018, 11:54 PM   #119
Lantanafrs2
Drives: 2013 frs red
It took my car roughly 25 miles of short hop driving (after flash) to regain throttle response and for idle to stabilize. V4 e85 has a nice shove around 3500 rpm that aids acceleration and I don't need to go over 5k now to be amused
Lantanafrs2 is offline   Reply With Quote
Old 03-22-2018, 12:27 AM   #120
uppitypanda
Drives: '17 BRZ PP
Good to know, looking forward to this setup soon
uppitypanda is offline   Reply With Quote
Old 03-22-2018, 12:41 AM   #121
Decep
Drives: 2013 FR-S Series 10
seems like the vvt is not as loud as it used to be ?
Old 03-22-2018, 01:37 AM   #122
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Saves havjng to have 50 different roms and defs for all the different years and countries badicly all roms and defs will be same except for calid changes, saves a lot of work and hassle
So now you have a single rom file? Wow! A bit risky if there are small differences in uncharted areas on the roms ...
Old 03-22-2018, 04:22 AM   #123
steve99
Drives: FT86
not rearly been doing it for years :-)
the ecu hardware is same in all cars
There are some small differences in external connections like for evap purge connection, but these are non critical. Only connected on usa cars, hence why euro roms used
Old 03-22-2018, 08:37 AM   #124
brz182
Drives: 2013 BRZ Limited
Flashed the car yesterday with Stage 2+ for 91/93 and it definitely seems quieter. Less than 25 miles on it so I haven't tested power but so far everything seems to be working well. It was nice not having to adjust the cold start tables.
brz182 is offline   Reply With Quote
Old 03-22-2018, 10:22 AM   #125
Teseo
Drives: frs
Tried to download latest open flash manager but doesnt download
Old 03-22-2018, 10:58 AM   #126
timmydatooth
Drives: Scion Frs
Has anyone with a 2013 scion frs AT upgraded to the new tunes yet? any difference at all from the old ones? Im still using the v2.076 tunes just want to know if it's even worth updating...
timmydatooth is offline   Reply With Quote
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
