Old 03-16-2018, 04:19 PM   #1037
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by snoxracer183 View Post
I purchased the Subaru sandwich plate cooler thing to run as an oil cooler, as I do plan to track my SSC car some. Used the car at a lapping day last year (completely stock) and the OBD reader said I could get oil temps to 265F in 4-5 laps so I do see where people are coming from with the oil cooler thing (even though its completely not needed for autox)
I think i'd be considered an aggressive driver on track, so i'm curious to find out if this bumpstop thing sends me sideways and smiling or sideways into a tire wall
You gonna run any of the 86 Cup events with us?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 03-16-2018, 05:37 PM   #1038
tony_r
tony_r's Avatar
Drives: '15 STX
It's not insane, it's controllable and somewhat progressive with stiff bar settings. That's more because the car is pretty easy to drive and recover. A bumpy track would be annoying, though.
tony_r is offline   Reply With Quote
Old 03-19-2018, 11:19 AM   #1039
snoxracer183
Drives: 2014 FR-S SSC
Looking at the schedule, not likely. I'll be doing the GL Autobahn event, but I will be taking my LS-Z
-Eric K - Milwaukee Region SCCA - 2014 FR-S
snoxracer183 is offline   Reply With Quote
The Following User Says Thank You to snoxracer183 For This Useful Post:
Shark_Bait88 (03-19-2018)
Old 03-19-2018, 12:14 PM   #1040
Shark_Bait88
For sure. I'll be adding 3 more events to the schedule this week. We will be running with Milwaukee Track Days too. Milwaukee Mile, Blackhawk, and Road America events too
Old 03-20-2018, 10:06 PM   #1041
Open Loop
2013 FR-S Whiteout / SSC
Rota Strike
Does anyone know the weight of the Rota Strike wheel in a 17x8? I searched on line and couldn't find a weight. Thank you.
Open Loop is offline   Reply With Quote
Old 03-21-2018, 07:13 AM   #1042
steverife
Drives: 2016 Scion FRS
I didn't weigh mine, but I've seen at least 3 people post 17.4 lbs.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
Open Loop (03-21-2018)
Old 03-21-2018, 09:18 AM   #1043
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
And I continue with my Subaru love/hate relationship. Went to install everything last night on my '14 BRZ bought used, but New England car, which is my 10th Subaru I've owned in my life. It's like the scene from Ferris Buellers day off "This is crazy. This is crazy. This is crazy.... this is CRAZY."
Car's all jacked up (heh) on jack stands, wheels off, just working front suspension, got brake line off, got lower strut bolts off, time to take off the endlinks. Kinda rustly already... ok VERY rusty. Douse upper and lower endlink nuts with liquid wrench, , wait a bit) get allen(6) in the hole, got 17mm wrench, no bueno. Won't budge. Turn some more... nada. Break out the breaker bar and get some more leverage, allen strips inside. :unamused:
Go to other side, just to loosen up because I know I now need new endlinks... same thing. Tighten everything back up (what I can), put wheels back on and drive home (was at a buds house because I don't have a garage) with clanking endlinks.
If we were allowed aftermarket endlinks, I would have cut them right then and there because I'd have already had them. Time to order some and get them and try again before 1st event in a few weeks (one of which I'll not have a chance to do anything to the car).
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 03-21-2018, 09:43 AM   #1044
Lex_K
Drives: 987S, e46, mkv, frs
Yes, 17.4 lbs. The weight seems to be the same between flat black and hyperblack.
Lex_K is offline   Reply With Quote
Old 03-21-2018, 12:04 PM   #1045
steverife
--kC
The endlinks are insane. I had my car on a lift before I bought it and it looked great. I go to install the suspension and the endlinks look like something off a 70's GM.
Old 03-21-2018, 01:19 PM   #1046
jorober5
Drives: 2015 FR-S
I've though about purchasing at least a spare rear end link, just in case of failure. It looks like the ULTRA-POWER K750486 from RockAuto (at $18.25 plus shipping) may be the best best bet. Has anyone else found a better OEM equivalent replacement?
jorober5 is offline   Reply With Quote
Old 03-21-2018, 01:57 PM   #1047
Imp
Bring out your dead
I couldn't believe that Subaru wants around $50 for them, when there's less material than the front's that are $25.
Old 03-21-2018, 03:47 PM   #1048
Open Loop
--kC
I have dealt with this too many times, and then having to carefully cut them off with an angle grinder (shade tree mechanic). With end links or other connections like this where you may need to hold on to one end with an allen wrench that may strip, I carefully clean the threads with a wire brush or even a little wire wheel on a Dremel after soaking with penetrant before starting to loosen the nut.
Old 03-21-2018, 08:56 PM   #1049
DaWorstPlaya
Drives: 2016 FR-S
I wish they would just allow aftermarket front and rear endlinks in this class and call it done.
DaWorstPlaya is offline   Reply With Quote
Old 03-22-2018, 08:15 AM   #1050
steverife
Seems worth it just to not have to deal with allen wrenches...
Would the Moog Problem Solver be considered OEM equivalent?
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
