Old 03-20-2018, 09:59 PM   #71
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Originally Posted by solidONE View Post
Did you take data logs when you were on the dyno?
I have logs for most of the runs, is there one in particular you are interested in?
Originally Posted by Lantanafrs2 View Post
Thanx so much for dyno graphs. Imo they would look even better on a dyno jet chart.
In a perfect world this would have been a Dynojet but I have a really good relationship with the owner of this dyno. I also have access to a lot of historical data from other cars that have run on this dyno, ultimately the A/B delta is the most important.
Lincoln Logs is offline   Reply With Quote
Old 03-20-2018, 10:17 PM   #72
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
just the ones that are connected to the dyno charts you posted. I want to see what was different between them that explains the difference in performance.
The difference between the stock '17 header and OFH is a bit disappointing. That, or the 17 OEM headers are impressive.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
nikitopo (03-21-2018)
Old 03-20-2018, 10:22 PM   #73
brzgabriel47
Drives: 17' WRB BRZ Premium
Anyone know how to bring back the cold start up? My neighbors don’t care so I want my cold start back lol
brzgabriel47 is offline   Reply With Quote
Old 03-20-2018, 10:32 PM   #74
Lincoln Logs
I think the '17 header is actually very good for what it is. The graph's scale make the gains seem much less impressive than they are. Moving to the UEL header the mid-range came up as much as ~13 ft-lbs. The mid-range gains are noticeable on the street and help quite a bit at autocross. I also think it's important to remember this is on E85, pump gas will probably tell a different story.
I plan on heading back to the dyno with 91 in the tank and same day I'll test the factory tune, v3.02 Stage 2+ and v4 Stage 2+.
v4.0 Stage 2+ E85 w/ stock header log:
https://datazap.me/u/sathomson1/log-...0?log=0&data=1
v4.0 Stage 2+ w/ OpenFlash header log:
https://datazap.me/u/sathomson1/log-...9?log=0&data=1
I can post up a v3.02 log when I'm at work tomorrow.
The Following User Says Thank You to Lincoln Logs For This Useful Post:
Teseo (03-21-2018)
Old 03-20-2018, 10:40 PM   #75
coxxoc
Originally Posted by Northern_18 View Post
With the new V4 tunes could I technically just compare the timing tables from this new tune to an actual 91 octane tune and use a value somewhere in between both and then do some logging and fine tune the timing to get a tune that will mostly stay close to 1.0 and use that as a 91 tune and use the plain unmodified v4 tune as a 93/94 tune? Would the timing be the only change between this v4 tune and a 91 octane tune from the past?
Edit: @steve99 maybe you would be best to answer this?
I compare values by copying data from RomRaider into Excel workbooks and using Spreadsheet Compare to see the differences. You will need to switch ECU definitions when opening the 2.x vs 4.x roms. If they used the same definitions you could just use the RomRaider compare image function.
When you open a table in RomRaider, click edit > copy table to get values you can paste into excel. Save whatever tables you want to compare into different worksheets within the workbooks. Use one workbook per rom file.
Follow the directions for Spreadsheet Compare from here to compare the worksheets from the two workbooks. https://support.office.com/en-us/art...1-f15b3229f5d8
coxxoc is offline   Reply With Quote
The Following User Says Thank You to coxxoc For This Useful Post:
Northern_18 (03-21-2018)
Old 03-20-2018, 11:04 PM   #76
Lantanafrs2
Drives: 2013 frs red
My car feels crisper during part throttle now.
Lantanafrs2 is offline   Reply With Quote
Old 03-20-2018, 11:58 PM   #77
steve99
Drives: FT86
their are some cam timing and fueling adjustments as well between v2 and v4
the v4 is best on 93/94
if you want a dedicated 91 tune then log the v4 on 91 and pull some timing in problem load/rpm areas (where flkc exceeds -1 enough to keep iam at 1.
then you can set iam initial to 1 in your 93 tune and your 91 tune
if you want to go to that trouble
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Northern_18 (03-21-2018), Teseo (03-21-2018)
Old 03-21-2018, 12:11 AM   #78
Jasonb
Drives: 17 Series Yellow BRZ
If advance multiplier inital is set to 0.7 then every time you start car iam will start from 0.7, unless it was already less than 0.7.
ie if it was 0.5 it will stay at 0.5
if it was 1 it will reset to 0.7
If you find the iam is almost always 1 then you could reset iam initial in tune to 1. The lower iam initial is to accomodate lower quality fuels like 91 as their is no dedicated 91 tune
I set mine to .9 and so far it's been hovering around .95 to 1.
Jasonb is offline   Reply With Quote
Old 03-21-2018, 12:44 AM   #79
ThatDamnRanga
Drives: 2014 Dark Grey Metallic GT86
Given my preference for editing in ECUFlash rather than RomRaider, is there any chance we'll get ECUFlash defs soon? I seem to recall someone here created some for the v2 tunes.
ThatDamnRanga is offline   Reply With Quote
Old 03-21-2018, 12:50 AM   #80
steve99
Drives: FT86
How to Convert any RomRaider Editor def to a EcuFlash def
Use the RR2EcuFlash.exe to convert any RR def to an EcuFlash def.
Conversion of 16 bit ECU defs may require some manual updates to make them 100% usable.
Copy the file created by the converter to your EcuFlash rommetadata directory and startup EcuFlash, then open the ROM for editing.
Application: RR2EcuFlash.exe
https://github.com/dschultzca/Defini...h.exe?raw=true
its a command line utility so you will need to run it from a DOS or command window
The full page on romraider here
http://www.romraider.com/forum/viewtopic.php?t=8449
you will generally need to correct a couple of things
flash method
mem model
and other initial header values
as per below in the ecuflash def after running the conversion utility
< rom> <romid> <xmlid>ZA1JF00C</xmlid>
<internalidaddress>8000</internalidaddress>
<internalidstring>ZA1JF00C</internalidstring>
<ecuid>A929703007</ecuid>
<year>2016</year>
<market>USDM</market>
<make>Subaru</make>
<model>BRZ</model>
<submodel>FA20</submodel>
<transmission>MT</transmission>
<memmodel>SH72531</memmodel>
<flashmethod>subarubrz</flashmethod>
<checksummodule>subarudbw</checksummodule>
Old 03-21-2018, 02:18 AM   #81
solidONE
solidONE's Avatar
Too bad the cam angles were not logged. Aside from the nice lump of torque from 4000-5000 its looks nearly identical everywhere else. With the cat removed and assumedly larger runner diameters, I would have expected more power everywhere. Then again... they were using the exact same tune. I would think that the optimal cam timing for each of these 2 headers should look a bit different as well. UEL vs Catted EL.
Intent > Content
Old 03-21-2018, 05:58 AM   #82
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Interested on such comparison and if possible some logs.
Old 03-21-2018, 06:30 AM   #83
tomm.brz
Drives: brz 2017 hksv2
modify ignition timing after start map and set everything to - 15 or - 19
Old 03-21-2018, 11:58 AM   #84
tomm.brz
I still don t get how there may be only one map for both EL/UEL... it sounds like a compromise
smg1138 (03-21-2018)
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
