Old 03-19-2018, 11:34 PM   #18481
Originally Posted by arxm View Post
alas no my girlfriend wouldnt be too happy with me
Hey, it was St Patty's Day ...... you were exempt, same with company Christmas parties and New Years Eve parties ...... shut up humfrz ..... that was before all this hash tag bull shit started.......
arxm (03-20-2018)
Old 03-20-2018, 02:36 AM   #18482
Slushboxr
Slushboxr's Avatar
Drives: 2015 Asphalt slush box
i didnt end up getting anything yet, seller fell through lol, im still on the search for fitment lmfao im looking at konig although the wheels im looking at has an offset thats too high, might need spacers (konig oversteer 18x9 et42) but theyre only like $800 canadian for a set
Idk why fit meant you are looking for. But mine are 18x9.5 with 245/40/18 tires. They are federals 595rs-rr which run 10 mm bigger so it's really a 255/40. Before I lowered my car it was a lot of room top to bottom but was a 1/8 inch to 1/4 inch away from shock. The Coilovers allowed an extra inch. Lowered now I'm a hit below stock hight and I rub now and then till I roll fenders but I love the aggressive tires and fitment
Slushboxr is offline   Reply With Quote
Old 03-20-2018, 07:50 AM   #18483
Ashikabi
Ashikabi's Avatar
Offset?
Old 03-20-2018, 10:08 AM   #18484
Slushboxr
Slushboxr's Avatar
Offset?
+38
Old 03-20-2018, 10:09 AM   #18485
Ashikabi
Ashikabi's Avatar
+38
That should do her
Old 03-20-2018, 01:09 PM   #18486
Pbrown
Drives: 2013 Scion FRS Raven
LMAO
Well, which one was better ......??
Left. Felt more like a stranger
Pbrown is offline   Reply With Quote
The Following User Says Thank You to Pbrown For This Useful Post:
humfrz (03-20-2018)
Old 03-20-2018, 01:38 PM   #18487
trvth
trvth's Avatar
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
Not today, but a day or 2 ago, I gave her a bath and took her picture for her 3rd birthday. Still averaging 30,000 DD miles per year, with 90,632 total miles.
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
trvth is offline   Reply With Quote
The Following 3 Users Say Thank You to trvth For This Useful Post:
MJones_RB (03-22-2018), Tcoat (03-20-2018), ToySub1946 (03-20-2018)
Old 03-20-2018, 01:59 PM   #18488
arxm
Drives: 2013 FR-S, 2023 BRZ
Yeah, you'd probably want a 10mm up front and a 5 at least in the back. Now, I have XXRs and when I added a 5mm spacer, I had to get extended lugs. Maybe XXR has a really thick mounting face, but it is something you should consider if you look at spacers. It may cost you in lugs and lug nuts. They aren't hard to replace but that shit ain't free. Getting the offset you want us always best. Unfortunately the front and rear don't have the same offset it seems. My setup is square but my wheel gap isn't equal. Maybe it's just my camber
if the xxr guy falls through ill get the konigs + spacers, the xxr are 17x8.25 +35 the konigs are either 17 or 18 x8 +45
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 03-20-2018, 02:03 PM   #18489
Ashikabi
Ashikabi's Avatar
Neither one of those is that great. Have you checked eBay? I dunno about others but nextlevelmotoring has some XXRs on clearance that may fit. You could wait for a sale too
Old 03-20-2018, 02:28 PM   #18490
arxm
18x8.75 +35?! i think these are the ones lol basically 18x9
Old 03-20-2018, 02:45 PM   #18491
Ashikabi
Ashikabi's Avatar
I got mine from NLM for 115$ each. 18x8.75 +36. They were on clearance
Old 03-20-2018, 05:14 PM   #18492
arxm
you like the way it sits on them? whats your height and camber btw? unfortunately the canadian dollar is and tax is a lot so each wheel is $239 which puts me right above a grand for a set and thats the best price ive found both new and used
Old 03-20-2018, 05:30 PM   #18493
Ashikabi
Ashikabi's Avatar
Sits really well. I put a 5mm spacer up front to flush it up a little more. Rear wouldn't fit one. I'm dropped probably 2 inches. -2.25degrees up front and about 1.5 rear.
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
arxm (03-20-2018), ERA (03-21-2018)
Old 03-20-2018, 07:33 PM   #18494
arxm
did you need extended studs for the 5mm spacer, i was thinking the same but wasnt sure if the cost of extended studs + spacer + open ended lug nuts was worth the extra 5mm lol
