Drives: 14 FRS Monogram, 05 Mazdasped Miata
Gauge question
I just picked up a '14 Monogram edition which I'll set up for track. First concern is for oil pressure and temp gauges. I haven't had time to pull the intake filter box off, but I'm told there are sending units for both underneath it. Is that so? Also, I plan to put in a K&N filter, but wonder if there's any real gain from an aftermarket unit.
Thanks |
#2 | |
![]() humfrz |
#3 | |
Drives: 2016 Subaru BRZ
I would recommend sticking with a drop in filter instead of going the route I went. You will also need to use the sending units of the gauges you buy regardless of what it has from the factory, sure there are locations you can tap into or save the headache and get a sandwich plate. |
#4 | |
Drives: Crapcan
I would also recommend going with a separate oil and temp gauge. I went with the Innovate dual gauge and the temp is hard to read since it is represented as a graph. |
#5 |
Huge E85 fan!
Drives: 2016 Scion FRS
Under the air box next to the TB there's a port that you can tap into. http://www.ft86club.com/forums/showthread.php?t=125350
I have my sending unit in that port, but I had to make an extension for it because of my intake getting in the way. A lot of people use a sandwich plate since the oil filter is right there practically poking you in the eye. DSportMag did a round up with tuned and untuned dyno numbers of a BUNCH of different intakes. Make up your own mind if it's worth it. |
| Fuel Pressure Gauge Question | Strife26 | Engine, Exhaust, Transmission | 19 | 12-20-2017 10:34 PM |
| Prosport Oil Gauge Question | guybo | Electronics | Audio | NAV | Infotainment | 3 | 08-25-2017 05:56 AM |
| Question regarding installing Defi gauge | nichiolas | DIY (Do-It-Yourself) Guides | 2 | 07-13-2016 11:42 AM |
| Frs temperature gauge question | Young_makaveli | Engine, Exhaust, Transmission | 11 | 01-03-2014 05:25 PM |
| P3 Gauge Question | jjkerr626 | Software Tuning | 1 | 01-01-2014 01:41 AM |
