03-16-2018, 01:52 PM | #127 |
Drives: 2017 BRZ
Just to clarify, the dyno tuning gains are being compared to the datalog-revised tune and not the initial tune?
03-16-2018, 02:29 PM | #128 | |
btr.life
Drives: 2022 GR86
The street tune power results are what is posted at beginning of this thread.
03-17-2018, 03:57 PM | #130 |
Drives: '15 BRZ RA
I thought you mentioned in the first post something about a Mustang dyno. So it was a street dyno? Anyway, not much of importance. The difference in the new dyno is still small. The Nameless header was giving the same or even better results a long time ago.
http://www.ft86club.com/forums/showp...98&postcount=1 But if you are happy with the gains in 3-4k rpm, who cares? Enjoy your car! |
03-17-2018, 04:13 PM | #131 | |
btr.life
Drives: 2022 GR86
03-17-2018, 04:31 PM | #132 | |
You cannot compare dynos that are not on the same dyno. Just how OFT's "baseline" dyno is way higher than everyone else. Both of these are "about 200whp", but one is much slower than the other. |
03-17-2018, 10:13 PM | #133 |
Drives: 2013 frs red
Is that a more recent baseline from oft? I believe their shop car in the past baselined around 170
03-18-2018, 01:24 AM | #134 |
Drives: '15 BRZ RA
What I don't get it? The post was comparing the Nameless with the Ace 350. Different dynos, but same headers. Not some random header like the OFH you referenced. I would never consider OFH a serious header. I also said that Justin's is better in mid range which is a fact for Ace. It is his car and if he likes it more, then it is what counts.
03-18-2018, 04:44 AM | #135 | |
03-18-2018, 04:47 AM | #136 | |
Here's the two overlaid dynos, in their original forms. Most people conveniently ignore baselines, because they so desperately want to believe they hit that magic 200whp NA. |
03-18-2018, 05:49 AM | #137 |
Drives: '15 BRZ RA
03-18-2018, 07:51 AM | #138 |
Drives: 13 FR-S
A set of curves on a graph should have a legend identifying what the three colors represent. Should I assume this is stock, tune +93 octane and tune + E85 on the same car? I just want to make sure I am interpreting the DT supplied chart correctly.
Former rides: 78 Scirocco, 80 Corolla, 79 Celica, 91 CRX, 90 CRX-Si,02 GTI, 87 944s, 86 911 3.2 Carrera, 03 MR2 Spyder
03-18-2018, 11:18 AM | #139 |
I think we can suffice it to say that the ace is the best solution but not the only solution. My car makes a stocker feel weak and I'm running a much lower budget tune/header combo.
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | bfrank1972 (03-18-2018) |
03-18-2018, 09:25 PM | #140 | |
- 17 stock - 17 + 91 tune - 17 + 91 tune + OFH - 17 + E85 tune + OFH DT - 17 stock - 17 + 91 tune + Ace - 17 + flex tune + Ace Note how one set of graphs conveniently scales to have a barely 200whp number. |
Similar Threads | ||||
My Nameless header dyno results (results to follow) | Simply_the_best | Engine, Exhaust, Transmission | 39 | 06-28-2016 04:09 PM |
Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 04:57 AM |
86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 06:54 AM |
Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
