Old 03-17-2018, 10:54 AM   #1
natedawg239
Drives: 2017 Subaru BRZ Limited PP
OFT V2
Just ordered my OFT V2. Looking forward to the bigger screen and hopefully faster load times due to the better processor. Does anyone know if they will come with the tunes for my 17 brz or if that’s something I’ll have to contact shiv directly for?
natedawg239 is offline   Reply With Quote
Old 03-17-2018, 11:35 AM   #2
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
I wonder if there’s a trade in/up program lol
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 03-17-2018, 11:39 AM   #3
stlgrym3
I’d like to know the 2017 compatibility too. Matter of fact I ordered and then canceled the OFT V2 worrying about not having the tunes for our 2017.
stlgrym3 is offline   Reply With Quote
Old 03-17-2018, 11:41 AM   #4
natedawg239
Yea I was thinking about that but I figure I'll get a hold of them eventually if they are not already preloaded on it. I'll let you know if they include the 2017 tunes when I get a hold of it.
Sent from my SM-G950U using Tapatalk
Old 03-17-2018, 11:55 AM   #5
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Also interested on this, website says supports 2017 models. Want to know if flex fuel is available.
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 03-17-2018, 12:31 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
My OFT has a messed up USB port and doesn't want to connect to my PC anymore (I can make it, but it's a PITA) and the connection to the OBD2 port doesn't fit well either. I may end up getting a V2 also.
guybo is offline   Reply With Quote
Old 03-17-2018, 01:23 PM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Does this device support the newer cars? I've seen a few logs of the old device and different parameters were plain zero. People that were trying to modify their cars moved to the Ecutek world.
Old 03-17-2018, 02:03 PM   #8
Teseo
Drives: frs
More interested on v4 tunes rather than hardware
Old 03-17-2018, 06:22 PM   #9
djezlee
Drives: 2017 BRZ Limited
Which v4 tunes do you need?
djezlee is offline   Reply With Quote
Old 03-17-2018, 08:52 PM   #10
Teseo
Drives: frs
All the data, dyno graphs comparing old tunes with new one etc
Old 03-17-2018, 08:54 PM   #11
steve99
Drives: FT86
The OFT hardware old or new definitly supports flashing and reading the 2017 ecu, its same as earlier cars jyst the firmare in ecu is different requiring different Tuning.
All you need is access to the V3\4 tunes and you wil! be fine on old or new hardware.
However no flex fuel support for 2017 tunes, only dedicated e85 at this point in time
Old 03-17-2018, 09:00 PM   #12
stlgrym3
can you elaborate more on the highlighted part? i'm ordering a V2 tablet, does it contain the tune for 91 petro stage 1 for 2017 BRZ/86 right out of box?
Old 03-17-2018, 09:04 PM   #13
steve99
Drives: FT86
What im saying is the physical oft device js capabke of reading and writing to 2017\2018 cars but you need the cirrect tune.
My understanding is that currently the 2017 tunes you need to get oft guys to email them to you then you load onto oft and flash. I dont think the oft will come pre loaded with the 2017 tunes only the older tunes
Old 03-17-2018, 09:21 PM   #14
stlgrym3
David from FT86 Speedfactory just confirmed via an email to me that "the tablet will have the correct tunes for the 2017 models as they all have the updated files to support all model years" ---his words.
