Old 03-14-2018, 09:44 PM   #2731
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Originally Posted by whataboutbob View Post
Approaching 400WHP on E85 with a lot of area under the curve I'd bet.
Hmm, I could almost come play with you kids in SM at that point.
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
whataboutbob (03-15-2018)
Old 03-14-2018, 09:56 PM   #2732
Im_SPEED
Drives: FRS hot lava
"Almost"
Im_SPEED is offline   Reply With Quote
Old 03-15-2018, 04:29 PM   #2733
whataboutbob
AutoX-10/10ths every run
Bring extra motors, because SM+Subaru lol.
Build thread:Here
Old 03-18-2018, 01:55 PM   #2734
cjopant
cjopant's Avatar
Drives: 2015 Subaru BRZ
Is anyone here running a Verus AOS system with their Edelbrock setup?
It looks like it should fit, but I'm looking to order my supercharger in the next week or so, and wanted to double-check.
cjopant is offline   Reply With Quote
Old 03-20-2018, 05:23 PM   #2735
Proseph
Drives: Supercharged 2016 CBS BRZ
The D-box works universally with any tune provided by CSG/DT for the Edelbrock.
Does this mean the D-Box also works with a tune from HRI tuning (James) or does it only work with CSG/Delicious tunes?
Thank you for your help as always.
Proseph is offline   Reply With Quote
Old 03-20-2018, 07:00 PM   #2736
CSG Mike
CSG Mike's Avatar
It only works with DT/CST provided tunes.
Proseph (03-20-2018), ThatAsianBradah (03-20-2018)
Old 03-20-2018, 07:36 PM   #2737
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
At one point, this was true, but I believe you would end up with a CEL when running the d-box with a non DT tune. I would get P0451, EVAPORATIVE EMISION CONTROL SYSTEM PRESSURE SENSOR RANGE/PERFORMANCE when I had mine flashed with the CARB tune. You might be able to get your tuner to turn off that code?
The Following User Says Thank You to BigFatFlip For This Useful Post:
Proseph (03-21-2018)
Old 03-20-2018, 08:33 PM   #2738
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'd be surprised if James can't get it to work on his tunes.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-21-2018, 08:18 AM   #2739
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I am currently working with James and have the D box...no CEL's.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Old 03-21-2018, 09:30 AM   #2740
Proseph
From the research I have done, it seems like James is more than capable tuning for the D-Box.
Old 03-24-2018, 04:48 PM   #2741
taiguy
Drives: 2013 Black BRZ Limited
Unhappy more error codes.
I have a feeling my issues are stemming for a single issue I just can't find.
Today with ambient temps in the 60s, the engine was revving up to 2500 RPM while coasting in neutral. Then when I started the car next, it threw P2109 (Throttle / Pedal Position Sensor A Minimum Stop Performance) and P0123 (Throttle / Pedal Position Sensor / Switch A Circuit High).
It went into limp mode and I found a place to pull over. Turning the car off and then back on, the starter was cranking but the engine wouldn't fire up.
After letting it sit for a bit it finally started up again and I was able to make it home. Searching for those error codes online, there isn't a lot of information available.
Anyone have thoughts on where to start?
taiguy is offline   Reply With Quote
Old 03-24-2018, 09:17 PM   #2742
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
This is highly unlikely, but symptoms are the same as mine. Ensure there's nothing in the OBD port. I used a cheap OBD dongle and it would give me all kinds of crazy issues and codes. As soon as I reset the codes and removed the dongle, everything was ok. I replicated the issue, just in case I was crazy, but it all happened again and I corrected it.
Sent from my Moto G (5) Plus using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 03-25-2018, 03:28 AM   #2743
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have you got the ability to log anything? Those kind of codes throw when there is a genuine issue with pedal or throttle, same with the symptoms. Could be worth checking the throttle connections as I assume that the TB is moved with an extension harness?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-25-2018, 01:57 PM   #2744
taiguy
Nothing in the OBD port. Tried resetting codes with a reader and they immediately show up again. CEL never goes off.
The Following User Says Thank You to taiguy For This Useful Post:
paiceyfan (03-25-2018)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
