Old 03-13-2018, 09:10 AM   #1
Baramzisyan
turbo turtle
Baramzisyan's Avatar
Drives: exit GT86 enter STI
FB25 VS FA20
hello! fa20 exhaust manifold to fb25 , will it fit?
Baramzisyan is offline   Reply With Quote
Old 03-13-2018, 09:23 AM   #2
celek
Resident Gear Head
celek's Avatar
Yes same block height the F series are modular.
you can bolt a set of BRZ heads on a FB25 block, they have the same head bolt pattern.
Unknown at least to me is the front cover bolts and how they line up. between the 2 engines.
I should pop the hood on the 2018 Legacy 2.5i and take a peek at the cover to compare.
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Baramzisyan (03-13-2018), Teseo (03-13-2018)
Old 03-13-2018, 09:30 AM   #3
Baramzisyan
turbo turtle
thanks! im interesting how brz exhaust manifold better then rxhaust manifold fb25 engine
Old 03-13-2018, 09:52 AM   #4
celek
Resident Gear Head
celek's Avatar
Problem is the exhaust routing and engine cradle location differ in the 2 chassis. Not sure everything will line up the same.
Old 03-13-2018, 10:40 AM   #5
Teseo
Drives: frs
Can i use FB bottom end with FA top and will increase the compression?
Old 03-13-2018, 10:52 AM   #6
celek
Resident Gear Head
celek's Avatar
In theory yes. I have been trying to locate a FB25 since about 2013 to confirm fitment. I have not validated the setup yet.
Teseo (03-13-2018)
Old 03-13-2018, 12:03 PM   #7
fika84
fika84's Avatar
Wrong thread @celek ! Keep your eye on the prize! Back to work!
fika84 is offline   Reply With Quote
Old 03-13-2018, 02:28 PM   #8
Teseo
Drives: frs
If the FB have stronger bottom end than the FA i think would be worth to do the search/test.
Old 03-13-2018, 03:54 PM   #9
celek
Resident Gear Head
celek's Avatar
The FB25 is actually worse shorter rods crappy rod to stroke ratio and smaller thinner rod bearings
The Following 2 Users Say Thank You to celek For This Useful Post:
NoHaveMSG (03-13-2018), Teseo (03-13-2018)
Old 03-13-2018, 03:55 PM   #10
celek
Resident Gear Head
celek's Avatar
I really want to switch it up for a 2.5 build if someone will by my 2.3
Old 03-13-2018, 04:01 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I was just about to reference your build as I had remembered reading that.
Old 03-13-2018, 04:05 PM   #12
fika84
fika84's Avatar
Wouldn't you still use your FA heads off your build? PS - what did you do to your heads at this point? Or has it all been bottom end work thus far?
Old 03-13-2018, 04:05 PM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The FB25 wasn't supposed to be a performance motor.
Old 03-13-2018, 04:33 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
We will not be oppressed !!!
JazzleSAURUS (03-19-2018)
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 07:05 PM
WTB Fa20 PolishFrs13 Want-To-Buy Requests 1 06-28-2015 10:12 PM
Fa20 with Fb25 block. jet86 Engine, Exhaust, Transmission 49 04-23-2014 07:21 PM
New Impreza with FB25 GTLegend Other Vehicles & General Automotive Discussions 1 02-07-2014 06:24 PM
Would you guys prefer FB20 or FB25 for NA FT? tranzformer Engine, Exhaust, Transmission 89 07-20-2011 05:00 PM
