Old 01-11-2018, 10:29 AM   #1
celek
Resident Gear Head
celek's Avatar
Clutch Master Cylinder hard line Fiting size?
Hey everyone,
I am working on a project and trying to locate the Clutch MC hard line fitting size. Searched the Service documentation and called my go to Parts Subaru department that usually can help me out.
They "think" its M10 x 1.0 thread for where the hard line goes into the Master cylinder.
I have not had the time to tear my car apart with all the snow. Anyone know this fitting size?
Marked in ORANGE
celek is offline   Reply With Quote
Old 01-11-2018, 02:06 PM   #2
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
IIRC Chase Bays clutch line replaces that hard line. You could try contacting them, they usually respond within 24 hours.
https://www.chasebays.com/products/c...nt=33631474953
Trueweltall is offline   Reply With Quote
Old 01-11-2018, 02:49 PM   #3
celek
Resident Gear Head
celek's Avatar
While I know Chase I do not feel leeching info from his is right , I do not know him well enough to ask how did you make that.
Old 01-11-2018, 03:20 PM   #4
Trueweltall
I have one on order from ft86speedfactory, I will update this post with the information when it gets here if someone doesn't answer you before me.
Old 03-09-2018, 09:23 AM   #5
celek
Resident Gear Head
celek's Avatar
Assume you forgot about this.
But I think it is a M10 x 1.0 I am about to pull mine to find out.
Old 03-10-2018, 02:37 PM   #6
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
m10x1
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 03-11-2018, 10:58 PM   #7
Trueweltall
I did forget, my order was delayed from FT86speedfactory because it was in fact, not in stock even though listed as such. Took several weeks for it to arrive.
Old 03-12-2018, 08:30 AM   #8
celek
Resident Gear Head
celek's Avatar
Not unheard of very common from them.
DIY - Swap clutch slave cylinder and hydraulic line for improved feel and control Ultramaroon DIY (Do-It-Yourself) Guides 452 02-18-2023 09:58 PM
Clutch Master cylinder - bleeder screw size? Joesurf79 Engine, Exhaust, Transmission 3 12-28-2019 08:16 AM
FS: Agency Power SS clutch line, OEM slave cylinder - SOLD Agent_D Transmission and Driveline 2 08-01-2017 07:02 PM
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 04:48 PM
What happens if I get air in the master cylinder? dstrout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-21-2015 11:42 PM
