Old 03-10-2018, 12:29 AM   #1
texastwurkt3am
texastwurkt3am's Avatar
Drives: '17 PP BRZ
Best size lowering springs for a daily/drift car?
I recently got some 18x8 squared Raijins and it's too high so I was looking to drop it a bit. What would be the best size springs to keep the car functional on the road while also being good for drifting? I know coils are best but I just don't see me needed them at the moment. I've had my eye on the Eibach Pros.
Also, is there anything else that anybody would recommend that I absolutely upgrade when drifting an 86? Mainly stuff that has a tendency to break. I'm still pretty new so I'm thrashing it a little bit
Edit: I do have the '17 PP with SACHS dampers
texastwurkt3am is offline   Reply With Quote
Old 03-10-2018, 02:41 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Drifting you say?
All you need is practice and tires. After enough of that any nut can do that.
Stuff only brakes when you hit stuff. So make sure not to hit stuff like curbs or walls. I recommend you don't be _____ and keep it off public roads. Go to race tracks.
Worse case you snap an axle.
Loweing spring wise, Eibachs (aka TRD) are perfectly fine for that compromise.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
Leonardo (03-10-2018), texastwurkt3am (03-10-2018)
Old 03-10-2018, 02:51 AM   #3
texastwurkt3am
Drives: '17 PP BRZ
There's an old abandoned NFL stadium parking lot that I've been using to practice when it rains. I'm down to be a jackass but not when it puts others at risk. Thanks for the advice!
The Following User Says Thank You to texastwurkt3am For This Useful Post:
Old 03-10-2018, 05:10 AM   #4
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Haha lol, i might have to join you one of these times.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following User Says Thank You to Spawn_Of_Creation For This Useful Post:
Old 03-10-2018, 03:08 PM   #5
texastwurkt3am
Drives: '17 PP BRZ
I usually go on lunch, see you there! Lol
Old 03-10-2018, 07:16 PM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Clutch/shift fork.
When the clutch finally lets go.
Most of the other stuff should hold up ok unless you hit something.
The Following User Says Thank You to x808drifter For This Useful Post:
texastwurkt3am (03-11-2018)
drift, lowering springs
FRS slow daily/ drift build SciOnDrifTtSlIdeR Member's Car Journals 7 04-19-2015 01:50 AM
Lowering Springs and Wheel Spacers... Size?? cjhopkins Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 03-14-2014 12:16 PM
Springs for a Daily Driver: Looks over Performance HELP ! ScionFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 01-31-2014 06:55 AM
Lowering as a daily & sometimes spirited driver 1086 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 12-24-2013 10:26 PM
Risky Devil BRZ - Daily / Drift car ill roller Member's Car Journals 32 12-11-2012 08:26 PM
