#421 | |
Drives: 2017 Brz
#422 |
Drives: 2017 BRZ
Yeah that's all I'm doing with the tool, just makes it easier to push the core to the side. Did you take the green clips out of the cores and put them into the trunk first? Seems to be easier that way.
#423 | |
Drives: 2017 DGM BRZ Limited
![]() I'm glad I'm not the only one having issues with taking that piece off. For the record, I did use the same pry tool. The right side is the one that was giving me issues. I must have pushed in and downward too hard, breaking the little plastic clip. After I popped it out with greater force than the left side, the metal clip came out with it still attached. I'm pretty sure the metal clip is the culprit which causes you to put more force than needed. |
#424 |
Drives: 2017 Brz
I tried both ways and neither worked. Seems the core is just about 1-2mm too far inside the cover to let it reach the clip in point. :/ just snugged the 4 trunk bolts and the 3m tape held everything in place so I didnt worrry about it.
#425 | |
Drives: 2017 BRZ
#426 | ||
When it's in proper shape even and you place it under the black bracket it also still has some space, making it move more than I'd personally prefer. It doesn't "lock in" until you've put the cap on, which is when the metal clip bites it with the teeth-looking edges to hold it in place. Sort of on-topic: I'm still researching how to get extras of the metal clip.. It's proving to be kind of difficult because at least a couple companies I've contacted or looked at require the customer to be an OEM, and others require buying a huge pack of at least 100, lol. This is before I've even confirmed the ones I'm looking at are the proper size that matches what we need to use. Not sure how much more I'll look into it because it's just not as easy as I'd like lol. @Tcoat any ideas on how to get small clips like the ones we're having issues with without having to do a huge bulk order?
Instagram: @spike.grc
#427 | |
#428 | ||
I'd say maybe something like.. 36 or.. 52? I don't think we need a ton but enough extra pairs for maybe 20 sets, give or take, could be useful. So far I've seen this, which is similar, but we need to verify dimensions first for sure: https://www.huyett.com/Products/Fast...B?searchText=# Edit: when I get home I can take some proper photos of the one working one I have for now unless someone beats me to it
#429 | ||
Drives: '14 981CS, '99 NB1
#430 | |
It's definitely up to him. I've just been figuring that it's not specifically a part of the kit so I don't think he's necessarily responsible for replacing any that get screwed up during the install.
#431 |
Oh, I agree with that, he's not responsible, but he could offer them for an extra $1 or $2 or w/e? idk... just throwing out ideas.
#432 | |
Yeah that could work too.
#433 |
Drives: Black 17 BRZ LT MT PP
Sorry, been a bit busy. Which exact part needs replacing? The black plastic bolt cover or the thin metal piece that sits inside the black cover? Or is it the black metal bracket that sits under the two bolts?
#434 | |
Its the thin metal clip piece that sits inside the black bolt cover and locks the cap into place
| Tags |
| removal, spoiler, trunk, wing |
| Remove trunk spoiler clips? | Drambeenie | Member's Car Journals | 0 | 05-09-2017 11:31 PM |
| 2017 BRZ Limited Spoiler | Chayce808 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 01-04-2017 12:49 AM |
| 2017 BRZ without spoiler? | vroomvroom1 | BRZ First-Gen (2012+) General Topics | 9 | 07-18-2016 10:46 AM |
| Remove spoiler for Rocket Bunny one? | xrinnenganx | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-21-2014 10:28 AM |
| Is there a way to remove the spoiler? | rapier7 | BRZ First-Gen (2012+) General Topics | 15 | 08-21-2013 10:58 PM |
