#771 |
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
The HKS is probably the best looking SC kit. Was not an easy decision not to go that route.
#772 |
Sarcastic SOB
The V1 setup is probably the least pretty and the most raw with the mushroom intake.
Mine has the intake restrictor deleted and an oversized intercooler. In fact there is no space for an oil cooler, so it is behind the intercooler. Will be looking to purchase new oil lines, AN fittings and thermostatic sandwich plate this year.
#773 |
Drives: 2013 subaru brz
so for anyone that has a hks v3 kit or even any other hks kits make sure your diverter valve is working perfect cause i have traced my failed supercharger to that.
it wasn't opening all the way! turns out the diaphragm had a little tiny crack in the rubber causing a small vacuum leak that wouldn't allow it to open all the way!!! it must have been like this a few months after i got the kit new. anyways if the valve doesn't open all the way it causes the compressor to surge and put a ton of stress on the charger and in the end the annulus will strip out! and then bam fucked!. so one way to know its not working properly is to pull the hose that is attached to the intake off and see if the diverter valve is open full on idle!. should be blowing air out like a leaf blower. and another tell tale sign is you will hear a flutter sound. I'm just letting everyone on here know thats what my failure was cause by and as of now i have heard 3 other kits with the valve issue and also in the end a stripped annulus. its a easy fix i just bought a bicycle inner tube patch kit and used the vulcanizing cement to seal it back up. car is running a 100 times better and will keep an eye on this issue. |
#774 | |
![]() ![]() ![]() Sent from my SM-G950W using Tapatalk |
#775 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#776 | |
#777 |
Sarcastic SOB
Hmmm on the V1 kit the recirculating valve is inside the bumper, pain in the ass to remove for inspection.
What are telltale symptoms? Is the valve not closing fully (leaking boost)? My kid busted my tablet and I can't seem to calibrate the boost gauge in Torque on my phone. It shows -22 at idle and when revving climbs to -10 psi thereabouts. Defintely wrong. I can tell that I am getting boost, just not sure if I am hitting targets or leaking somewhere. Perhaps if I knew what idle vacuum is I could just do the math.
#778 | |
#779 | |
#780 | |
#781 | |
#782 |
Sarcastic SOB
Mine's running great for now. Absolutely minimal traction at rear wheels when shifting at 4500 RPM lol.
I am treating it as a power enhancement in moderation. I won't push it, keep from revving high and make sure for example that throttle fully off when pressing clutch. My gut feeling was the annulus threads were loaded by high RPM and possibly quick rev climb as might occur with pressing clutch while throttle engaged or just neutral revving. Even more so if you have a lightweight crank pulley. Also the traction fluid needs to be proper viscosity based on average driving temperatures in your area. There's thicker stuff for hot climates and thinner stuff for cold climate use. People that store their vehicle in the winter will want to use the thicker summer stuff if the temps will be warm to hot during driving season. But if you drive in freezing temps with the thicker fluid that might also put extra load on the annulus thread. I suppose pressure against the compressor creating resistance is going to "overscrew" the threads.
#783 | |
Drives: s2k supercharged
if the new one dies this time, then its obviously not the compressor surge, BUT i am doing very very limited mileage anyway these days |
#784 | |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| Five Axis Edition FR-S Owners Thread | digital_assassin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 563 | 07-08-2015 09:22 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
| Supra Owners Build Thread | BoostJunkie | Other Vehicles & General Automotive Discussions | 164 | 03-12-2012 09:37 AM |
