Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: Car
OFT Stage 2 but still getting O2 Sensor CE
Hi, I installed a UEL on my 14 FRS, and flashed the ROM with an OFT Stage 2 UEL ots tune. Everything was good at first, but over the last 2 weeks I have gotten four different check engine lights all pointing to issues with the second 02 sensor.
Things i have done: Used OEM new gaskets on all exhaust components for header and overpipe. Replaced 02 sensor Verified torque on header to head Verified torgue on header to overpipe Drivetrain Mods: HKS airfilter 1320 headers 1320 overpipe stock front pipe Manzo M2 catback I was under the impression that the stage 2 tune eliminated the 02 sensor reliance. Is that not the case? Anyone else have this problem? |
#2 |
Drives: Crapcan
I don't have my laptop in front of me and am kinda drunk right now bu go to CEL's and see if p0420 is enabled.
#3 |
Drives: GT86 2013
I had the same issue. Just email a copy of the tune file you are using to customer support at openflash. They will fix it
#4 |
Drives: FT86
If your getting cel codes relared to rear o2 sensor then it likely the sensor was damaged during header install
Or you may have exhaist leaks do you have ltft over 10%. If you intake is stock then its very unlikly its a tune problem . List of codes would help Last edited by steve99; 03-07-2018 at 06:53 AM. |
#5 |
Huge E85 fan!
Drives: 2016 Scion FRS
what are the CEL's specifically. List them.
#6 |
Drives: Car
Error codes are p0139, p2097, p2098
The o2 isn’t damaged as it’s a brand new 02 sensor. Getting codes a day after install. Getting codes on other o2 as well. I just reflashed my ecu with uel stage 2 again. I’ll see if maybe a bad flash |
#7 |
Drives: frs
Try to undo everything
#8 |
Drives: Car
Here are two data logs. One before i reflashed and it was running like a dog (but no check engine lights). One after i just reflashed.
#9 |
Drives: Car
Bump. Still having the problem. Have replaced the o2 and new gaskets. Nothing keeps it from coming back.
#10 |
Drives: 10 Series #974 6m/t
#11 |
Huge E85 fan!
the tune disables the P0420, that's it. It does not effect the operation of either O2 sensor. One of them is not even an o2 sensor, it's an Air Fuel sensor.
Just because your O2 sensor is new, does not mean it is working right. Get it tested at a shop that can look at the output of the sensor. Also, it could be a case of damaged wiring. |
#12 |
Drives: GT86 2013
I had the exact same problem, turned out to be an issue with the tune. Openflash modified the tune and now it works.
#13 | |
Drives: FT86
If you removed the rear 02 completly that wont work unless you modify tune. the standard tunes just disable the cat converter check function, if you complety remove rear 02 you need to make other adjustments to tune |
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help | Johnders2586 | Issues | Warranty | Recalls / TSB | 9 | 04-04-2023 03:32 PM |
Windband sensor location with OFT stage 2 | randomthoughts | Software Tuning | 2 | 04-02-2017 04:36 PM |
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 06:39 PM |
