Old 03-06-2018, 04:20 PM   #1
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Unremoveable nut!
Hey guys,
I am trying to install my radium catch can kit but one screw on the driver side by the strut bar seems unremoveable. I attempt to unscrew but it just spins in place. I took a picture of the under side there seems to be something strange there. None of my tools could seem to grab a hold of that under side.(space is tight) any suggestions?
top side pictures
under side picture
Elliotw is offline   Reply With Quote
Old 03-06-2018, 04:45 PM   #2
norcalpb
norcalpb's Avatar
Needle nose crescent wrench
Old 03-06-2018, 04:50 PM   #3
fika84
fika84's Avatar
The bottom is supposed to be tack welded... not sure how that would've come undone..
But you'll need to grab ahold of it and then use something like vise grips on the top to get it off, then replace it all with new nut/bolt that fits since the tack welds came off..
Then get yourself a set of non 12 point wrenches for normal use.
Are you sure the bottom square nut is spinning?? It doesn't look like it's at all been spinning from the bottom pic you sent, but the bolt looks stripped...
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
strat61caster (03-06-2018)
Old 03-06-2018, 05:24 PM   #4
Elliotw
Elliotw's Avatar
I used the wrench and I can see the bolt spin. But it wasn't raising up any. I was working at it to try and get it undone. It is quite beat up.
Old 03-06-2018, 05:45 PM   #5
Elliotw
Elliotw's Avatar
I believe the thread on the screw has failed. I took a video under the bolt while I turned it. Just the bolt is moving but its not unscrewing. suggestions?
Old 03-06-2018, 05:58 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Smaller wrench?
Old 03-06-2018, 05:59 PM   #7
Grady
Grady's Avatar
It looks like the nut is still tack welded in place. 90 deg die grinder and cutoff wheel, grind the head off so you can see what is going on. Once you do that try to drill it out the bit may catch and take the bolt out from the back side.
Old 03-06-2018, 06:19 PM   #8
Elliotw
Elliotw's Avatar
lol Im not sure I'm confident in my wrenching skills enough to pull this off.
Old 03-06-2018, 06:22 PM   #9
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Have someone push up on the bolt from the bottom while you try to unscrew it. If that does not work, whip out a Dremel and cut the bottom off the bolt level with the nut.
JimmyMac is offline   Reply With Quote
The Following User Says Thank You to JimmyMac For This Useful Post:
Elliotw (03-06-2018)
Old 03-06-2018, 06:48 PM   #10
Gunman
Drives: 2019 Mazda Miata RF
Clamp a vice grip on it, so you can pull up, while turning it
The Following 2 Users Say Thank You to Gunman For This Useful Post:
Elliotw (03-06-2018), humfrz (03-07-2018)
Old 03-06-2018, 06:58 PM   #11
GrantedTaken
The bolt spins, and the weld nut is not spinning?
Yet, the bolt does not unscrew itself?
GrantedTaken is offline   Reply With Quote
Old 03-06-2018, 07:00 PM   #12
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Either the bracket broke its welds or the bolt stripped the threads so it cant progress out. If you don’t want to drill n tap or cut it off then vice grips on the bracket if that is broken from the welds or use a hammer or crowbar action to press the bolt out as you rotate it.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 03-06-2018, 07:03 PM   #13
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Hey guys,
Sell the catch can.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Brink (03-06-2018)
Old 03-06-2018, 07:53 PM   #14
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Originally Posted by BirdTRD View Post
Sell the catch can.
Sell the car!
JeremyR is offline   Reply With Quote
