Old 03-05-2018, 07:47 PM   #16605
OfficeWorker
Drives: 2018 WRX STI
I threw on Pilot Sport A/S 3+'s. And by "I" I mean "somebody else"
(I also gave away the stockies for the promise of beer)
OfficeWorker is offline   Reply With Quote
The Following User Says Thank You to OfficeWorker For This Useful Post:
Is Always Angry (03-16-2018)
Old 03-05-2018, 07:53 PM   #16606
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by Tonezorz View Post
Installed my custom anarchy motive shift knob. Tried everything I can think of. This is as close to perfect as I can get it.
So much for simple mods.
I'm sorry, but that is pretty funny.
Tonezorz (03-05-2018)
Old 03-05-2018, 07:57 PM   #16607
Brink
Drives: 2017 BRZ
Sounds like a good price on the stockies, I may have to find somewhere around here that will give me that for them when I swap mine out. Planning on having it done sometime in the next couple months.
Brink is offline   Reply With Quote
Old 03-05-2018, 08:10 PM   #16608
OfficeWorker
Initially I was thinking maybe hold on to them or sell them for $25/pop given they were essentially new...my buddy suggested being artsy and making a creative endtable. Except literally I have nowhere to put an endtable, plus I am not sure how I would get them home (I really don't want to put dirty tires in my new car, and even if I wrap them up that's a recipe for an interior mess) so I defaulted to the next best thing: a commitment for beer.
But I can't complain...I really disliked the stock rubber and I am glad they are gone.
Brink (03-05-2018)
Old 03-05-2018, 09:09 PM   #16609
johan
Drives: '14 981CS, '99 NB1
I'm not sure how to fix it!
Grab a piece of paper and tear off a small bit, fold it over and over and over until it makes a spacer. Once paper compresses enough, it's rock hard. If it doesn't line up, pull the paper out and tear off a small bit... rinse repeat.
johan is offline   Reply With Quote
The Following 3 Users Say Thank You to johan For This Useful Post:
Leonardo (03-06-2018), new2subaru (03-05-2018), Tonezorz (03-05-2018)
Old 03-06-2018, 12:03 AM   #16610
devonr
Drives: 14' E85 BRZ
UEL headers, dual resonated front pipe, nvidia n1 exhaust, new tune. Cold start is loud af I need to turn it down a bit but honestly couldn't be happier. Loud when you want it and quite when you need it and doesn't sound ricey at all.
devonr is offline   Reply With Quote
Old 03-06-2018, 01:39 PM   #16611
JMon85
JMon85's Avatar
Drives: 2019 WRX
Makes for a better anti-theft device. Even if the would-be thief knows how to drive a stick they won't be able to find the gears with this mod.
Had me Rollin
JMon85 is offline   Reply With Quote
Old 03-06-2018, 03:54 PM   #16612
Zoid
Zoid's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWP
Bought and installed a new battery after mine died last night.
Zoid is offline   Reply With Quote
Old 03-06-2018, 07:38 PM   #16613
TorqueMan777
TorqueMan777's Avatar
Drives: 13 BRZ, 18 STI
Today I replaced my oem battery with a Braille B2015 AGM battery, and a Ptuining battery mount kit. Saved me somewhere in the neighborhood of 15lbs.
Install wasn’t as straightforward as I would have liked though. Only because the radium catch can is a little too close to the battery to connect the negative terminal the normal way. Ended up having to mount the negative terminal sideways to clear it.
Unfortunately that created another issue. The grounding wire that comes off the negative wire, which normally attaches close to the strut tower, would no longer reach the standard mounting point. I ended up sandwiching the grounding wire between the two plates of the battery mount.
Racecar spelled backwards is racecaR, because RacecaR
TorqueMan777 is offline   Reply With Quote
Old 03-06-2018, 09:03 PM   #16614
ctmandu
ctmandu's Avatar
Drives: 2017 860
added a sho-n-go removable plate frame holder and rear louvers. here is the video of the plate mount
ctmandu is offline   Reply With Quote
The Following User Says Thank You to ctmandu For This Useful Post:
e30kawi (03-06-2018)
Old 03-06-2018, 10:22 PM   #16615
Brink
Drives: 2017 BRZ
Fed my BRZ some $3.80/gallon 91 octane today.
Old 03-07-2018, 02:24 AM   #16616
Lococholo84
Drives: Celica, Frs
picked up my door numbers today and took the car for its first service
Instagram @machine_type
Lococholo84 is offline   Reply With Quote
The Following User Says Thank You to Lococholo84 For This Useful Post:
Clipdat (03-07-2018)
Old 03-07-2018, 06:40 PM   #16617
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Turned 50K, yesterday actually....
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
Clipdat (03-07-2018), MJones_RB (03-09-2018)
Old 03-08-2018, 02:24 AM   #16618
TheRoops
Matched up Valenti tails. The Tom's weren't doing it for me.
Sent from my SM-G950U using Tapatalk
TheRoops is offline   Reply With Quote
