#141 | |
Drives: #337 2017 Toyota 86
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
#142 |
Drives: 2013 FRS
The lots I run are moderate. Personally I expect that more compliance than one gets with 400/400 would be faster but I guess i'm just wondering how the majority ended up favoring the 400/400.
#143 | |
Drives: '13 FRS - STX
Start jacking in the camber, be willing to do anything with swaybars and you end up in a different place than 400/400. http://www.ft86club.com/forums/showthread.php?t=9936 http://www.ft86club.com/forums/showthread.php?t=120099 oinojo in that second thread won STX Nats last year fwiw, and others have put their cars top 10 with 400/400 and similar. It's certainly not 'put those springs on and win' because I've got similar rates (325/500) and I can't get my car set up for the life of me (much less drive it well) but that's part of the fun of Street Touring.
#144 |
Drives: 2013 FRS
Interesting stuff. Thanks for that second link. I had not come across that one before. It sounds like it comes down to experimentation and personal preference to a large extent.
#145 |
I think spring changes just come with experience and what you want the car to do where and when.
I ran 400/400 last year, but after reviewing what the car was doing to me...I decided to make a spring change for this year to combat that without effecting other car setup (IE - Same height/bars/camber...etc)
Kyle H. - #89 STX
#146 |
Drives: FRS
recommended tire psi for 235/40 federal 595ss with tein street flex and 17x9 +38 offset? first time ever autocross today and I didn't know what psi to run. so just did 38 psi all around cold. oversteered quite a bit... should I lower it?
#147 |
Drives: 2013 FRS
38 is definitely high for most tires. I'm not familiar with your tire but I'd advise to start around 32 and go from there. Maybe someone that has run them before can be more specific.
#148 |
Drives: 2017 BRZ
Any recommendations for stock tire PSI setup?
#149 |
Don't be too worried about it, you'll gain way more time thinking about your driving than whatever the tires are. For simplicity I'd say 34-35 psi cold, before your runs, after you start feeling confident drop 2-3 psi out of the front or rear if you feel like you lack grip on one end of the car, don't overcomplicate it, but if the change was too much drop the other end a bit to compensate. I think the tires might be a little grippier at lower pressures, maybe about 32 psi hot, but you may have to pump them back up before driving home or just ignore the tpms light and be fine rolling around on 27ish psi.
#150 |
Drives: Red BRZ
What would good starting tire pressures be for a D-Street BRZ on 225 Rivals?
Stock suspension. Thanks. |
#151 |
Drives: 2017 BRZ
I start at 26-28 square on 245 rivals on an STX car. I'm not sure how that translates, but don't be afraid to go low. Just be really attentive to how the tire is being worked, and drop pressures over a few runs while chalking the sidewall.
#152 |
Drives: Many
You can run low pressures on an STX car because of camber, though. Wouldn't go that way on camber-challenged stock car.
#153 |
Drives: 2022 Toyota GR86
start at 30-32 psi at both ends and then adjust from there.
Eric
2022 Toyota GR86 Steel |
#154 |
Drives: 2024 GR86/ 2015 FRS
I am 400/350
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
| Official DTM Autobody Services Thread for FT86Club! | DTMAUTOBODY | Southern California | 9 | 12-31-2013 02:09 PM |
| Official FT86Club Chatroom? | wrxgoose | Site Announcements / Questions / Issues | 13 | 09-15-2012 05:26 PM |
| Official FT86Club decal idea? | Hanzo | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 06-21-2012 08:09 PM |
| Official FT86Club decal ideas? | Hanzo | BRZ First-Gen (2012+) — General Topics | 46 | 06-04-2012 01:15 PM |
