Old 03-02-2018, 01:51 AM   #1
NJNCFRS
Drives: 2014 FR-S
Clutch feels soft? Easier?
I went out for a little bit of a spirited drive the other day and since then my clutch has felt different to say the least. The clutch feels softer when engaging yet slightly easier to get into gear. Aside from the clutch, the car feels a little different, almost like it's lacking just a little bit of the power. Time for a new clutch? Some other mechanical problem? Or something that just happens? I have really no idea, I'm not the most mechanically inclined car person.
NJNCFRS is offline   Reply With Quote
Old 03-02-2018, 02:53 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well, don't know what to tell you.
Does it smell of burnt clutch? You know a foul odor and/or smoke coming from the engine bay.
If your clutch was going out it would be harder to get into gear.
Maybe you got some shitty gas, dirty air filter, loss some air in your tires,??
Maybe your butt dyno needs recalibration.
Old 03-02-2018, 03:00 AM   #3
You must be plum out of Civics ....... //
Old 03-02-2018, 03:12 AM   #4
Well, NJNCFRS, first off ...... WELCOME to ye ol forum .......
Questions:
* do you have any power mods?
* how many miles on your car?
* is the clutch the original OEM clutch?
* what is the last thing you did (mechanically) to your car?
* did you buy the car new?
* has anyone ever adjusted the clutch?
I would suggest that you first check the clutch fluid reservoir level and top it off if necessary.
The next thing I would suggest is that you have the hydraulic clutch system bled (their might be air in the system).
Come back after you have checked out those things ......
guybo (03-02-2018)
Old 03-02-2018, 08:50 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
how many miles on that clutch?
guybo is offline   Reply With Quote
Old 03-02-2018, 09:53 PM   #6
NJNCFRS
Drives: 2014 FR-S
Well thank you guys so much!!
I have no power mods whatsoever (yet...)
The car has about 43k on it, original clutch I presume, and I am the second owner of this vehicle. Little annoying since I do not know the habits of the previous owner of course.
I haven't had the clutch adjusted at all. From my little bit of research yes, I did find that those could be some options in resolving this problem, or as I had just gotten off the phone with a friend, maybe the clutch has reached a new level of wear that has become noticeable.
I'll definitely try topping it off first followed by bleeding it to see if that can fix the problem.
Thanks!
The Following User Says Thank You to NJNCFRS For This Useful Post:
humfrz (03-02-2018)
Old 03-02-2018, 10:31 PM   #7
oaroyale
Drives: Black BRZ
The clutch on the 86 is softer than a lot of other vehicles. For example the clutch on the WRX feels like a brick comparing to the 86. I guess it all depends on what vehicle you are used to. I think it also has to do with the clutch spring that is installed in our vehicles.
oaroyale is offline   Reply With Quote
Old 03-02-2018, 10:39 PM   #8
Thanks!
Yep, do that, then get back to us.
Old 03-02-2018, 11:54 PM   #9
Thanks!
If the clutch reached a new level of wear fast enough for you to notice then something is wrong someplace. Wear should not come in noticeable jumps. Once the car is in gear then the clutch has no effect at all on power unless it is really slipping badly in which case you would know it. As said check the fluid level. If really low then crawl under the car and see if you can tell where it went. The level will drop very, very, very, slowly as the clutch wears but if you lose a lot in a short time it went someplace.
humfrz (03-03-2018)
Clutch feels rough during depression BayBRZ Issues | Warranty | Recalls / TSB 4 11-02-2017 01:29 AM
HELP! Clutch feels funny dsteezy86 Northern California 2 08-09-2017 01:08 AM
Clutch pedal feels super light Euphues Issues | Warranty | Recalls / TSB 33 09-17-2015 03:43 PM
Every other frs driver thinks my clutch feels different Yruyur Scion FR-S / Toyota 86 GT86 General Forum 4 11-15-2012 10:12 PM
Soft Clutch fix Billy2224 Cosmetic Modification (Interior/Exterior/Lighting) 10 07-01-2012 06:03 PM
