Old 01-29-2018, 05:40 PM   #29
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
/me gives up.
/me unsubscribes
dowroa is offline   Reply With Quote
Old 01-29-2018, 05:55 PM   #30
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by fatoni View Post
I just wanted to know why he wanted to get rid of body roll
because racecar
Old 01-29-2018, 06:15 PM   #31
fatoni
Originally Posted by dowroa View Post
/me gives up.
/me unsubscribes
You can drop it which is cool. I never understood your point of contention. You even refer me to some other members post but as far as I can tell, i agree with him and vice versa. He even like my original post that seemed to bother you.
Drive upgrades. Don't buy them.
Old 03-01-2018, 07:40 AM   #32
teppei
Drives: 86 GTS
i read from somewhere about the rear swaybar from 2017 model is 1mm larger than pre-2017 models. can anyone confirm?
teppei is offline   Reply With Quote
Old 03-01-2018, 08:46 AM   #33
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It is 1mm larger, but the rear spring rates are softer.
Old 03-01-2018, 12:17 PM   #34
justinco
justinco's Avatar
Drives: 2022 GR86
It's actually 2mm larger. 16mm in MY17+ and 14mm on earlier cars.
EDIT: Correction, the MY17 rear bar is 15mm as stated. Not 16mm.
justinco is offline   Reply With Quote
Old 03-01-2018, 04:42 PM   #35
wu_dot_com
Drives: accord
Are you certain?
2008 2.5WRX, 2017 brz 15mm pn: 2045FG002
2017 Toyota 86 rear is 15mm pn: SU00306461
2008 is the only year where the wrx had 15mm. 2009 the wrx went to 16mm with different pn
Would 16mm work. Yes. But is it OEM MY17+ Spec, I don’t think so.
wu_dot_com is offline   Reply With Quote
Old 03-01-2018, 04:46 PM   #36
wu_dot_com
Drives: accord
Rear spring Softer compare to ? Brz or FRS?
Based on my research, it’s probably harder than MY13 BRZ, but softer than MY13 FRS
Old 03-01-2018, 05:05 PM   #37
norcalpb
norcalpb's Avatar
You are most likely understeering from the lack of camber in the front, until that’s fixed you really need to be entering corners slower and focusing more on your corner exit. Once you add the camber you may discover you need a slightly stiffer front spring rate (or sway bar rate) to reinforce the added camber.
I’d personally go with RCE springs (truly the best) and put the idea of sway bars out of your head until you think you need to change the balance of the car at the maximum level. Sway bar upgrades are awesome on certain cars, like it was adding an rs4 rear bar to my Audi a4. On this car, it’ll just make it stiffer which you should’ve just done with spring rates.
Old 03-01-2018, 05:09 PM   #38
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
I'll have my 86 on the lift this weekend, I'll check the front and rear sway bar with a caliper.
Lincoln Logs is offline   Reply With Quote
Old 03-01-2018, 06:13 PM   #39
justinco
justinco's Avatar
Drives: 2022 GR86
Originally Posted by wu_dot_com View Post
Are you certain?
Pretty certain. I have both bars at home off the car, I'll measure them tonight.
Old 03-01-2018, 07:15 PM   #40
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
I know the PP on the 17 Yellow has a 1mm larger rear sway bar. Not sure if it is included on the non PP?
Old 03-01-2018, 08:19 PM   #41
justinco
justinco's Avatar
Drives: 2022 GR86
Nope, I'm wrong. The 2017 rear bar is 15mm as shown per the part #. Wonder why I had it confused...
Pre MY17 first photo.
MY17 second photo.
Old 03-01-2018, 09:12 PM   #42
Gunman
Drives: 2019 Mazda Miata RF
I like my adjustable Hotchkis bars.
FYI, body roll, and weight transfer: http://www.beyondseattime.com/weight...y-roll-part-1/
GroupBuy CUSCO Suspension Enhancement Parts - Braces, Strut Bars, Rear Sway Bar Elite Performance Groupbuys 4 10-29-2015 12:31 AM
FR-S stock sway bars compared to TRD bars babydriver Scion FR-S / Toyota 86 GT86 General Forum 3 12-01-2014 09:12 PM
FS: OEM suspension, strut bars and rear sway bar DrewIsAmus Brakes, Suspension, Chassis 1 02-26-2014 04:01 PM
