Old 02-27-2018, 09:06 AM   #1
alexsantillan
alexsantillan's Avatar
Drives: '14 Monogram FR-S
Tail light help
Due to annoying condensation on my left tail light, I have consider buying a set of aftermarket lights. The ones that got my attention are the Valenti Sequential Red edition. I saw on the description of ft86speedfactory that the light are DOT approved. Is this true? I have looked everywhere for info regarding this and it’s really outdated. Can you guy help? If the Valenti are a no, what other light do y’all recommend that’s on the same price range ($350 or so)?
Thank you!
alexsantillan is offline   Reply With Quote
Old 02-27-2018, 09:17 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Which ever lights you end up buying, be sure to also buy a set of Ninja gaskets. This alleviated all my condensation issues.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
dnieves (02-27-2018), funwheeldrive (02-28-2018)
Old 02-27-2018, 09:24 AM   #3
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Valenti lights are DOT approved and states so on the light itself. Make sure you get the matching fourth brake light to complete the look if you go with the Valentis! I've had mine for almost two years now and they've held up great with no issues whatsoever.
DaBoBo21 is offline   Reply With Quote
Old 02-27-2018, 09:43 AM   #4
Trollhart
Trollhart's Avatar
Drives: 2013 Subaru BRZ Sport
Also make sure that you don't overtighten the bolts inside the trunk.
Hand tight is enough - otherwise you will damage the gaskets and get water ingress or condensation again.
Trollhart is offline   Reply With Quote
The Following User Says Thank You to Trollhart For This Useful Post:
Tcoat (02-27-2018)
Old 02-27-2018, 09:50 AM   #5
Ensure that you have the proper flasher module or you can mess things up.
Old 02-27-2018, 10:34 AM   #6
NAEightySix
Drives: 2015 Scion FRS 6MT (Asphalt)
I have those exact ones, and while I do love them, I’m planning on getting new ones sometimes in the near future. No condensation issues whatsoever in the year and a half I’ve had them, however about a month or two ago, two LED’s died on the driver side turn signal. Not a huge deal to me tbh... I do plan on replacing them with clear TOM’S taillights.
NAEightySix is offline   Reply With Quote
Old 02-27-2018, 10:34 AM   #7
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
I have sequential valenti's with the stock flasher and they work fine. They are advertised as plug and play.
I have recently upgraded my front blinkers to led and then I added an aftermarket flasher.
fx1mark is offline   Reply With Quote
The Following 3 Users Say Thank You to fx1mark For This Useful Post:
DaBoBo21 (02-27-2018), NAEightySix (02-27-2018), Tcoat (02-27-2018)
Old 02-27-2018, 10:35 AM   #8
NAEightySix
Same, I didn’t need a new flasher till I got switchback turn signals.
The Following User Says Thank You to NAEightySix For This Useful Post:
Tcoat (02-27-2018)
Old 02-27-2018, 10:41 AM   #9
Perfect. Didn't hurt to confirm that.
Old 02-27-2018, 07:20 PM   #10
Audio
Drives: 16 FR-S Raven
Does Valenti/Helix=Valenti??
I got the smoked Valenti Helix and was under the assumption it wasn't DOT Certified...
If it is, great, I wont have to change them out for inspection.
Audio is offline   Reply With Quote
Old 02-27-2018, 08:46 PM   #11
dnieves
Drives: FR-S 10 Series
Though pricier, the OEM 2017+ Toyota 86/BRZ tail lights look great, they are warrantied, and use longer lasting LEDs (I went through this scenario with our tC).
dnieves is offline   Reply With Quote
Old 02-27-2018, 09:12 PM   #12
fx1mark
fx1mark's Avatar
according to ft86speedfactory they are.
Old 02-27-2018, 11:10 PM   #13
Audio
Yeah I read that but I also saw that they were saying they were fake so....
Sent from my Pixel XL using Tapatalk
Old 02-28-2018, 12:01 AM   #14
fx1mark
fx1mark's Avatar
I thought you were asking if smoked valenti's would pass inspection.
tail lights
Valenti tail light signal light issue djdnz Cosmetic Modification (Interior/Exterior/Lighting) 70 12-03-2017 12:49 AM
4th brake light blew tail light fuse? wat? Xaftos Cosmetic Modification (Interior/Exterior/Lighting) 5 11-20-2017 03:06 AM
Helix / K Shade Tail Light - Pics and Functional Overview - NEW Tail Lights FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 12 09-29-2015 04:49 AM
Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 nigel-jdmparts Exterior Parts - Lighting 14 06-23-2015 06:32 AM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
