Old 02-25-2018, 11:03 PM   #1
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Trying to buy Rocket Bunny V2
I’ve been eye balling the rocket bunny V2 kit for a long time now and I finally have a very valid excuse (need) to replace my front bumper. I went right away to my local dealer to purchase the front bumper portion of the kit only to be told that is it currently discontinued.
I really don’t want to go any other route (or with a v3) and finding a used one is going to be difficult and tedious.
Does anyone have any experience with any of the rep kits out there?
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 02-28-2018, 01:44 PM   #2
dobbrz
Drives: RB v1 FRS
I think I remember reading somewhere that you have to order the RB kits directly through Greddy now and not through other distributors. Might be worth trying to go through them directly. Other than that I'm not sure...
PROPΔGΔNDΔ
DRIVEN TO INFLUENCE
instagram: @andrewdobbie93
dobbrz is offline   Reply With Quote
The Following User Says Thank You to dobbrz For This Useful Post:
brzzy (02-28-2018)
Old 02-28-2018, 02:17 PM   #3
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
I have a fiberglass replica V2 kit that i purchased from Ikon Motorsports at a fraction of what the authentic Greddy cost. I would have never been able to afford the kit otherwise.
I'm extremely happy with the kit, no real fitment issues. As long as you have a competent installer you wont be able to tell its a replica.
This is the rep i would recommend at the moment, as i think Ikon is only selling a ABS version now. (although im not seeing the front bumper)
http://www.kd-aerostop.com/for-ft86-...ers_p5887.html
VIP BRZ is offline   Reply With Quote
Old 02-28-2018, 02:22 PM   #4
brzzy
@anthonysestito
brzzy's Avatar
This is the rep i world recommend at the moment, as i think Ikon is only selling a ABS version now. (although im not seeing the front bumper)
The aerostop stuff is actually really really decent all things considered. But doesn’t look like they have just the front bumper - in fact no one is really selling JUST the front bumper not even ikon right now or Greddy direct.
I ended up purchasing one from vsaero last night at a decent price. It’s FRP, which I’m not crazy about but even a real Greddy one would’ve been. But it seems it’s my only option right now if I want one so we’ll see how it goes.
IG: @ANTHONYSESTITO
Old 02-28-2018, 02:41 PM   #5
VIP BRZ
VIP BRZ's Avatar
I bet it will look great! update us with some pics once you get it on
The Following User Says Thank You to VIP BRZ For This Useful Post:
brzzy (02-28-2018)
Old 02-28-2018, 02:43 PM   #6
brzzy
@anthonysestito
brzzy's Avatar
Will do!
IG: @ANTHONYSESTITO
Old 03-16-2018, 12:20 AM   #7
brzzy
@anthonysestito
brzzy's Avatar
Well, to update everyone.
Bumper came in on Tuesday and I’ve been racking my brain trying to figure out what I’m going to do here.
As of right now, this is the closest I can get the kit on and I’ve been trying for days.
In order to come this far, I’ve had to do the following:
- Remove headlight brackets
- Remove bumper clips from fenders
- Remove ALL under trays underneath the crash bar
- Tuck (will likely have to remove) fender liners
As you can see in the photos the fitment around the headlight is horrendous. Like there’s almost an inch gap or more in some areas. The corners by the fenders I can definitely line up no problem but I didnt want to force anything into place for fear of damaging the part of I have to send it back.
Clearance around the headlight is a major problem. Even then, lining up the top section of the bumper to bolt it into place where the hood gasket is, is next to impossible. The lip where you would have to drill holes thru doesn’t sit flush and it’s almost as if the whole top section sits narrower than it should so the bumper has to be almost forced open vertically to even get it to sit where it is.
The mounting tabs on the bottom of the bumper obviously don’t even attached to anything because well, the under tray doesn’t exist anymore.
Not %100 sure what to do. I’ve emailed the seller/manufacturer to see if there’s been a batch error. All the research I’ve done on VsAero shows that alot of there other products are actually quite good. But this one missed the mark and sending it back is going to be a nightmare.
If anyone can recommend another kit (front bumper only) replica or real, new or used I’ll gladly consider it as I don’t even have a stock bumper to fall back on - it was destroyed by a snow bank. Also considering non rocket bunny at this point even though an RB V2 kit has been a total dream of mine since purchasing the car.
Any advice helps.
IG: @ANTHONYSESTITO
Old 03-16-2018, 04:23 PM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Looks like typical bodykit problems to me.
Old 03-16-2018, 04:52 PM   #9
brzzy
@anthonysestito
brzzy's Avatar
Should I keep going with it? Really what worries me is the gap in the headlight areas (underneath and in the corner) and the fitment of the top section under the hood gasket - it doesn’t sit flat.
I have no problem moving forward with it, if it looks like it’s a workable piece.
Anyone with FRP Experience think that applying heat will help in shaping some areas?
IG: @ANTHONYSESTITO
Old 03-16-2018, 05:24 PM   #10
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
A stock front bumper replacement would be easy to source and fit correctly. Plus, added advantage of looking great!
If you wanted another route a 2017+ upgrade could be done.
Old 03-16-2018, 05:25 PM   #11
brzzy
@anthonysestito
brzzy's Avatar
Too easy lol. I’ve always wanted RB or at least something different.
IG: @ANTHONYSESTITO
Old 03-16-2018, 05:32 PM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Rocket bunny is really common though? This is a prime time for a 2017 conversion, especially in the aesthetics department.
The Following User Says Thank You to Summerwolf For This Useful Post:
Cole (03-21-2018)
Old 03-16-2018, 05:37 PM   #13
brzzy
@anthonysestito
brzzy's Avatar
Also something I’m considering if this doesn’t pan out tbh.
IG: @ANTHONYSESTITO
Old 03-16-2018, 05:42 PM   #14
VIP BRZ
VIP BRZ's Avatar
I think its workable, even an authentic kit will need some work fitting
Start tightening things down up top and i think the gap under the headlight will go away.
The gaps at the corners of the headlights is normal, there will always be a gap there. i can take a picture of mine if you'd like to see how it sits.
i think my kit even had to be trimmed slightly to clear the headlights (i didn't do the install myself)
Rocket Bunny derekgrant Cosmetic Modification (Interior/Exterior/Lighting) 21 05-17-2017 01:47 PM
[WTB] Rocket Bunny FRS kingkoopa Want-To-Buy Requests 1 05-12-2017 01:03 PM
Rocket bunny Epic_integra Want-To-Buy Requests 1 06-22-2015 12:55 PM
Rocket bunny style DRL without the rocket bunny kit. ducky369 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-22-2014 06:38 PM
Rocket Bunny kit (just lip) encity5 Cosmetic Modification (Interior/Exterior/Lighting) 8 11-01-2013 10:01 PM
