Old 02-22-2018, 03:26 PM   #631
celek
Resident Gear Head
celek's Avatar
Originally Posted by Williampreza View Post
@celek- If this is not proprietary info, how did you go about sourcing custom pistons, as in how do you know if you've got things like compression ratio, valve locations/lift clearance, etc. right? Sorry if this is a vague question, I'm just learning this stuff.
Thanks!
Will
Lots of math and calculations.
You can measure anything and reverse engineer anything.
celek is offline   Reply With Quote
Old 02-25-2018, 11:56 AM   #632
fika84
fika84's Avatar
My turn for a potentially dumb question. What's the maximum compression we could run on our motors if we only used the DI at higher RPM's? I'm confused because I know that boosted dynamic compression can go pretty darn high (like 16+:1), granted they retard the hell out of the timing to avoid detonation, and with DI we're controlling exactly when the fuel gets put into the piston, so doesn't that also remove the worry for detonation at higher compression? Can we run 15:1 or higher on 93oct with DI?
fika84 is offline   Reply With Quote
Old 02-25-2018, 03:04 PM   #633
sato
sato's Avatar
Drives: Dodge Patitas
Not sure if I'm answering anything here, for sure not on topic, but I've read of some Edelbrock supercharger build that INCREASED static CAR to 13.5:1. It was fully built though...
Sent from my Pixel 2 using Tapatalk
sato is offline   Reply With Quote
Old 02-25-2018, 03:27 PM   #634
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
That is @Sargy's build
- The Ancient BRZ Sacrament
by Zaku
Old 02-25-2018, 06:55 PM   #635
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
14:1 compression all motor Civic with a 2.5L stroker.
[ame="https://www.youtube.com/watch?v=9Wc_q_4blyw"]330 HP All Motor 2007 Honda Civic - One Take - YouTube[/ame]
I bet 15:1 could be done. I don't know how long it would last. Build the lower end with lightweight, high compression piston/rods...go stroked for torque or destroked for revs...I personally would like revs for NA and tracking. ITB, ported and polished, quality headers, get some lightweight valve train going. Flex fuel setup, run some ethanol.
Old 02-26-2018, 10:29 AM   #636
fika84
fika84's Avatar
You're pretty much on target with my goals. High revving, high compression N/A setup. Not in for torque, but for high rpm track fun. The lightweight internals path is the route. I'm in Denver and know that SCR Performance can do some awesome head work on the FA20's as he's proven in the past. Just waiting for @celek to get his $#!^ together and build us some ITB's!!!!
I'd also like to push the limits of DI and CR with this engine.. Hence the question. If I'm going to have custom pistons built, I'd like to go as high CR as possible.
Old 02-26-2018, 12:07 PM   #637
Pat
Pat's Avatar
Drives: 2023 BRZ
Oh man, if you end up going down that path I would LOVE to have a look at it sometime. What has SCR done with these? I know about the Revvolution(?) car, but what else is there? Do you know of any build threads with details?
Old 02-26-2018, 12:17 PM   #638
fika84
fika84's Avatar
Hey Pat,
The Revvolution is the thread I'm referring to (he claims to get about 30% more flow on intake side!), however my wife and Mark over at SCR go way back and he's been involved in building Subaru Boxer engines for different series as well.
I'm slowly but surely on my way that way Got the spare heads sitting in the garage, just trying to put together my parts wish list first before I pull the trigger. @celek, what are you doing for head flow/upgrades?
For those that aren't familiar with that thread - https://www.revvolution.com/blog/201...the-bottom-end
Old 02-26-2018, 01:02 PM   #639
Irace86.2.0
Im pretty sure E85 will be a necessity but if that isn’t a problem then I bet it can be done. It may not be too streetable either but if tgis is a dedicated track car then cool.
Old 02-26-2018, 02:23 PM   #640
Pat
Pat's Avatar
Drives: 2023 BRZ
Hey Pat,
Thanks. I've known Mark quite a while, too. Actually, the only reason I have a BRZ now is because the E30 I bought from him done blowed up on me. I loved that car.
Anyway, I know SCR pretty well, but don't know any significant engine work they've done on the FA20 other than the Revvolution car. But that's different than we're talking about in this thread, as it has forced induction. So really, what have they done to an FA20 that improves power significantly other than the typical header/tune/etc.?
Old 02-26-2018, 02:30 PM   #641
fika84
fika84's Avatar
Honestly I'm just in it for the head work.. I haven't been there in a while, but when I was there he mentioned how he builds Subaru engines for race series as well which intrigued me.. I can't find any info on it online except this excerpt from the revvolution article "SCR also has a productive history with building race-oriented Subaru boxer engines,...". I know he'd do a much better job porting the heads than I would and I don't want to ship it anywhere to get it done. I plan to build the rest of the engine at home.
Old 02-27-2018, 02:54 AM   #642
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Even if 14:1 or 15:1 comp were possible, you gotta ask yourself how much more hp you're even gonna make over an already sky high 13:1 or 13.5:1 ratio. You're risking a lot for minimal gains imo.
cyde01 is offline   Reply With Quote
Old 02-27-2018, 03:14 AM   #643
churchx
churchx's Avatar
Drives: 2014 GT86
It's easy to get such compression. Just swap in cummins diesel
Old 02-27-2018, 10:28 PM   #644
fika84
fika84's Avatar
When going the NA route.. all gains are desired and it all costs a crap ton of money. So even if it's minimal gains, if I'm putting the money into it, I want all of it!
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
