Old 09-05-2017, 09:30 PM   #15
Qc86
Drives: 2017 Toyota 86 M6
here is mine.. dont mind the missing push pin at the top. not the best looking but will do for the moment. Ill remove the seatbelts next, was too lazy to do it at the same time lol
Qc86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Qc86 For This Useful Post:
Akuma-ZN6 (11-10-2017), Hyper4mance2k (12-20-2017)
Old 09-06-2017, 07:45 PM   #16
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
picture not working for me bro I wanna see
SuperTom is offline   Reply With Quote
Old 09-06-2017, 09:54 PM   #17
Qc86
strange... does this work ?
or this is the link https://imageshack.com/i/pm18oiLLj
Old 09-06-2017, 10:13 PM   #18
new2subaru
Weight Weenie
Drives: 15 FR-S
I can see it fine, Tom.
Old 09-07-2017, 06:05 PM   #19
SuperTom
SuperTom's Avatar
yeah that works, looks good
The Following User Says Thank You to SuperTom For This Useful Post:
Old 02-24-2018, 11:37 PM   #20
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
@SuperTom or @Qc86
Sorry about the necro, but Im planning something like this and was wondering what thickness of coroplast was used and how it has held up? Im thinking of going straight coroplast (no cardboard) and maybe a bit thicker for a bit more structure to support some weight without extra bracing.
Old 02-25-2018, 10:28 AM   #21
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
One thing that isn't mentioned but is a nice benefit is that removing all that crap lifts the car up just enough so that is doesn't scrape on anything but the worst rain gutters. I scraped on everything stock, even just going across some roads because the peaks are so high since it can rain like crazy. Taking all that stuff out made a huge difference to that for me.
why? is offline   Reply With Quote
Old 02-25-2018, 11:42 AM   #22
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Very nice
Lunatic is offline   Reply With Quote
Old 02-26-2018, 09:10 PM   #23
SuperTom
SuperTom's Avatar
@SuperTom or @Qc86
Don't remember exactly maybe it was 1/4" thick. You could glue together to double up or use a light wood bracing underneath. Certainly these kits can be as strong as you want them to be. Downside being more weight will be added back in unless you use exotic materials (carbon fiber ect.)
Edit here is the link to home depot looks closer to 1/8" thick
https://www.homedepot.com/p/Coroplas...896S/205351385
Spuds (02-26-2018)
Old 02-26-2018, 10:08 PM   #24
Spuds
The Dictater
Spuds's Avatar
Yeah, I wound up doing a mock-up/test with some of that 4mm stuff from the hardware store and I think im going to need 10mm for my purposes, maybe with some 4mm for bracing if I need it. 10mm isn't cheap though...
Planning on forgoing carpet for paint or coating of some sort so that should keep weight down.
Old 02-27-2018, 07:04 AM   #25
new2subaru
Weight Weenie
Drives: 15 FR-S
Building a skeleton underneath for support, similar to below, would add plenty of strength and can remain lightweight, based on material choices.
Old 02-27-2018, 12:46 PM   #26
Spuds
The Dictater
Spuds's Avatar
My thoughts exactly. 4mm coroplast oriented with the flutes vertical should hold quite a bit of weight. Probably only need one rib in each direction if I also use the tunnel and rear armrests for support.
Debating between removable ribs in case I want to put something underneath, or arched ribs so there is some amount of space. I'll probably have to try them both out...
The Following User Says Thank You to Spuds For This Useful Post:
new2subaru (02-27-2018)
Old 07-08-2018, 02:20 PM   #27
SuperTom
SuperTom's Avatar
Originally Posted by JazzleSAURUS View Post
The exposed fasteners is 100% what has kept me from doing this.
I imagine a velcro installed trim piece, or those interior fasteners that are fixed to the plate would dress up this otherwise awesome DIY really nicely.
Finally got back to this just made a strip an added a TRD badge to jazz it up a bit.
JazzleSAURUS (07-09-2018)
Old 10-24-2018, 04:43 PM   #28
SuperTom
SuperTom's Avatar
Forgot that I remade this using only coroplast, aluminum rivets & carpet. Came out cleaner and only weights 3.5lbs total
DIY: Shrader Performance Rear Seat Delete Kit & Rear Seat Removal PoorMansRacing DIY (Do-It-Yourself) Guides 98 10-10-2023 04:51 PM
Track car weight reduction Irace86 BRZ First-Gen (2012+) — General Topics 17 06-11-2016 05:21 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
the weight reduction of FR - S? raiden8383 Scion FR-S / Toyota 86 GT86 General Forum 22 11-30-2012 06:10 PM
Rear seat question, version 2.0 8987846 BRZ First-Gen (2012+) — General Topics 29 06-05-2012 06:13 PM
