Old 02-22-2018, 03:50 PM   #29
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by gtengr View Post
Right, but the assertion that high compression has a strong correlation to the FA20's dip is still off base. You're relying on Mazda's very simple comment about a "drop" to mean a "dip" when they could mean that the torque drops off altogether in lower rpms, which is the more plausible scenario with extremely high compression, 87 octane, and low rpm knock problems. Look at something like the BMW S65. It has high compression, port-only injection, and 4-1 headers and it's one of the flattest NA torque curves out there. This is probably not the thread for continuing this tangent, but if you'd like to discuss more I'd be glad to in your engine thread.
Did you look at Figure 1? They are showing how the motor is detuning itself to avoid knock, and that torque is lost across the rev range, but more significantly at lower rpms. This is probably because the engine is breathing better at higher rpms, so there is less knock due to less heat buildup because of better flow.
Except you are ignoring the evidence that the Ace 350 header has a long 4-2-1 setup, and it not only removes the torque dip, but improves low end torque the best. Is the logic for certain? No, but it seems very reasonable to conclude that there is a correlation.
I can't speak on every engine, but while we are throwing out some random V8 engine examples, here is the Coyote vs Voodoo (11.0:1 vs 12.0:1) and LS7 vs Voodoo (11.0:1 vs 12.0:1), looks like the Voodoo has a drop/dip sub 3500, Ferrari:
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Hades (03-02-2018)
Old 02-22-2018, 04:37 PM   #30
n0thing
Drives: Subaru BRZ
Would OFT be sufficient to tune an Ace?
n0thing is offline   Reply With Quote
Old 02-22-2018, 05:00 PM   #31
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I mean, yea you could make OFT work with an ACE header. But, I would not recommend that at all. ECUtek is a much more capable and feature filled platform. It would be a total waste to skimp on the tuning, if you are buying an ACE header.
Not to mention, CSG & Delicious have a lot of time and testing with this package, so it is well optimized.
justinco is offline   Reply With Quote
Old 02-22-2018, 05:31 PM   #32
CSG Mike
CSG Mike's Avatar
Anecdotal examples that meet your needs for the sake of argument, but you're ignoring WHY those cars have "dips" at the low end versus the comparison engines.
Sorry, but you've rendered your own point invalid.
You might as well say the F20C/F22C has a "dip" before VTEC too.
gtengr (02-23-2018)
Old 02-22-2018, 05:38 PM   #33
Irace86.2.0
Correct, which was my point of throwing out a few dynos. Anecdotally individual examples are useless. Someone would have to design a lower conpression FA20 to know for sure. The FB20 is close but the stroke is longer, so all we have is conjecture and educated guesses.
What we know is there is a torque dip and headers improve it, and the Ace long 4-2-1 header works the best to improve it. I’m just giving context for a possible reason why it exists, and to why Toyota n Subaru doesn’t fix it with all their RnD research and money. Could I be wrong? Yes.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
CSG Mike (02-22-2018), gtengr (02-23-2018), Hades (03-02-2018)
Old 02-22-2018, 05:47 PM   #34
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Nameless is a 4-2-1 and has the dip.
http://www.ft86club.com/forums/showthread.php?t=107412
I have been using an oft to tweek a OTS stg 2 91 tune with mine. I have had to pull a bunch of timing out of the 2600-3k rpm range.
Old 02-22-2018, 06:26 PM   #35
CSG Mike
CSG Mike's Avatar
Wow, that wrap job on that first post is
Way, way better than the one I did on my manifold.
Old 02-22-2018, 06:58 PM   #36
Irace86.2.0
Maybe not enough back pressure at low rpms because catless? I dunno. Torque dip area compared to stock looks stronger than the top end, so something right is going on there.
Old 02-22-2018, 07:02 PM   #37
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Back pressure...... ffs
The Following User Says Thank You to Summerwolf For This Useful Post:
Calum (05-15-2018)
Old 02-22-2018, 07:05 PM   #38
Irace86.2.0
Thats a nice wrap job!
Repost
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
CSG Mike (02-22-2018), strat61caster (02-23-2018)
Old 02-22-2018, 07:52 PM   #39
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The nameless FP I am running is the catted 2.5. I can really still feel it, car does not pull well until 3700-4k. I was expecting a little better though I did not really look at many dyno sheets for this setup before I went for it. I do still have stuff to tweek with the OTS tune but I don't think I am really that far off.
Old 02-23-2018, 04:20 AM   #40
Harey
Drives: 2013 Toyota 86
The was a dyno on here with OEM headers with the cat hollowed out and the dip was gone.
Do any of the catted headers get rid of the dip?
Harey is offline   Reply With Quote
Old 02-23-2018, 08:18 AM   #41
DarkSunrise
DarkSunrise's Avatar
Here's a dyno from the FT86SF catted header. Catted 4-1 design.
The gains from 3200-4500 RPM are noticeable on the street. (I've had this header, as well as a JDL catless on my car).
2022 BRZ Build
2013 FR-S Build
Old 02-23-2018, 09:50 AM   #42
bfrank1972
Drives: 2013 FR-S Argento
Good advice - I think one of the bigger benefits of buying the ACE headers is you get a tune that has been well vetted by Delicious, vs a generic one-shoe-fits-all solution.
In general the OFT model fits people who don't want to spend a lot of money on tuning and want to be able to recoup their investment, i.e. you can buy a used OFT, use free tunes with no tuner investment, and later sell the OFT for little to no loss. It's a good solution and for most people out there it's functionally just as good as EcuTEK, though your tunes will never be as good as a custom tune, or even a canned tune designed for a specific header.
Conversely, the ACE setup is for people who don't mind spending a lot of money to get one of the most optimized NA setups out there.
Really they're two different markets - if you want to spend for ACE, go EcuTEK as that's where the support is, and you won't be disappointed.
If you want to pinch pennies (like me ), then buy a good long tube used header like JDL, P&L, Nameless, etc. and use an OFT - big bang for the buck.
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
gtengr (02-23-2018), justinco (02-23-2018)
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 04:09 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
