Old 02-17-2018, 07:25 PM   #911
gahooligan
Drives: 2017 BRZ Premium
The whole thing can be done in about 6 hours if you are used to wrenching and familiar with how the bumper comes off. Just figure a day, start early in case you have issues. Make sure you use the correct torque on the manifold and tighten down in the correct criss cross sequence. Warning, some bolts are a pita and need little hands lol.
Sent from my SM-N950U using Tapatalk
gahooligan is offline   Reply With Quote
Old 02-17-2018, 07:27 PM   #912
gahooligan
Question. What boost should I be seeing in my torque app on the standard pulley? My elevation will decrease this number by about 1 psi. Just want to know what i should be making.
Old 02-17-2018, 07:35 PM   #913
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I believe the base pulley produces 7-8 psi. But I could be wrong.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
gahooligan (02-17-2018)
Old 02-17-2018, 08:03 PM   #914
gahooligan
I was seeing 4.5-5 today which would put it at 6psi. Assuming the torque app actually reads the boost correctly... i dont think i have an issue. Anyone run the torque app and can confirm what they see on the torque vac/boost guage?
Old 02-18-2018, 01:37 PM   #915
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
The whole thing can be do e is about 6 hours if you are used to wrenching and with hiw the bumper comes off. Just figure a day, start early in case you have issues. Make sure you use the correct torque on the manifold and tighten down in the correct criss cross sequence. Warning, some bolts are a pita and need little hands lol.
there's no need to remove the bumper though, if you can get the car high enough just the access panel off from underneath
Matt@Cosworth is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
gahooligan (02-18-2018), weederr33 (02-18-2018)
Old 02-18-2018, 03:53 PM   #916
gahooligan
Good point Matt. I swapped the radiator and installed a perrin CAI at the same time.
Old 02-20-2018, 11:14 PM   #917
weederr33
weederr33's Avatar
@Matt@Cosworth this makes me nervous...
http://www.gt86ownersclub.co.uk/foru...opic14658.html
Please don't give up!
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
muckypuppy (02-21-2018), nikitopo (02-21-2018)
Old 02-21-2018, 01:48 PM   #918
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It was a matter of time. I am afraid that Matt cannot do anything about it ...
Old 02-21-2018, 04:00 PM   #919
Matt@Cosworth
all things must come to an end I'm afraid and the Dev car has probably had its time
we're still selling kits and will continue to support our product for the forseeable but we'recurrently re-assessing our position within the aftermarket
nikitopo (02-22-2018), weederr33 (02-21-2018)
Old 02-21-2018, 04:23 PM   #920
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Please continue to provide support, I just picked up the car on Sunday. I am planning to get it install when the deals come again. I will be extremely upset if the kit is discontinued. Please wait for me!
https://www.instagram.com/p/BbzekeoBbT5/
botbs is offline   Reply With Quote
The Following User Says Thank You to botbs For This Useful Post:
Old 02-21-2018, 04:36 PM   #921
weederr33
weederr33's Avatar
Guess I better take a loan out to get mine bwahahaha
botbs (02-21-2018)
Old 02-23-2018, 12:02 PM   #922
pjp
Drives: frs
Just in Time
I am glad its Now HERE!
Please Stage III!!!!
$$$$ To SPEND
pjp is offline   Reply With Quote
Old 02-25-2018, 03:40 PM   #923
weederr33
weederr33's Avatar
$$$$ To SPEND
Start with the smaller boost pulley
https://www.fensport.co.uk/parts/toy...ulley-upgrade/
I don't think "Stage 3" would yield much good unless it included a larger crank pulley to overdrive the supercharger (coupled with the smaller SC pulley). Otherwise forged internals could be had from elsewhere.
Old 02-27-2018, 11:35 PM   #924
botbs
botbs's Avatar
Are you guys using 0W-20 or did you guys change to 5W-30 oil ?Thanks!
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
