go_a_way1
Old 02-07-2018, 03:23 PM   #4369
CSG Mike
CSG Mike's Avatar
Originally Posted by jonperezinsd View Post
Are you going to be at the shop tomorrow? Ill be in garden grove arpund noon and can come by and talk on my way ack to west covina
Sent from my SM-N950U using Tapatalk
CSG is open to the public by appointment only; did you want to talk to me personally?
-Mike
Old 02-07-2018, 03:33 PM   #4370
jonperezinsd
Drives: Subaru BRZ [San Diego 86 Club]
-Mike
Doesnt necessarily need to be you, just wanted to pick someones brain about the kit and corresponding mods i ould need when ready to pull the trigger.
jonperezinsd is offline   Reply With Quote
Old 02-07-2018, 05:04 PM   #4371
CSG Mike
CSG Mike's Avatar
PM'd.
Old 02-17-2018, 02:25 PM   #4372
mrg666
pessimistic skeptic
mrg666's Avatar
Just to update. 10K miles, no problems. Never refused to start in the extreme colds in upstate NY. Snow, ice, rain, or shine ... never driven anything else. Still running great. Oh, maybe just a bit on the cons side, it is a little more tiring to control the boosted car in snow ... maybe because I only had four-season tires
The Following 6 Users Say Thank You to mrg666 For This Useful Post:
CSG Mike (02-18-2018), CxG (03-27-2018), Jackson Racing (02-19-2018), S. Snake (02-17-2018), twag4 (02-17-2018), wheelhaus (02-17-2018)
Old 02-17-2018, 10:15 PM   #4373
ExpertZero
Drives: FR-S 2015 Halo
https://imgur.com/a/6AYBR
290 whp to 340 spending on the dyno. Check imgur.
JRSC c38. Using a different BOV listed in the thread few months ago
DT Flex fuel
Crawford intake spacers
Grams throttle body
iD 1050
Koyorad Radiator
HKS intercooler
Perrin oil cooler
AT oil cooler
Hks spark plugs
JDL UEL Headera
JDL front/over pipe
deathewerks 300cc fuel pump
Perrin engine mounts
ADVAN Rg3 18x9.5
All I can think at the moment. I'll update with thoughts tomorrow.
ExpertZero is offline   Reply With Quote
The Following 3 Users Say Thank You to ExpertZero For This Useful Post:
CSG Mike (02-18-2018), CxG (03-27-2018), twag4 (02-17-2018)
Old 02-17-2018, 11:22 PM   #4374
wheelhaus
wheelhaus's Avatar
I haven’t seen this particular question yet (apologies if I missed it) but for someone who doesn’t have huge hp goals is there any benefit to going with the C38 kit over the C30 in regards to overall system operational efficiency etc? I guess more specifically- does the larger impeller at lower rpm change power delivery in any appreciable ways?
Edit- or reduced wear & tear due to lower rpm?
Old 02-17-2018, 11:29 PM   #4375
vpt
Drives: 2015 Scion FRS RS-1
Hi Folks,
My belt snapped and also damaged the idler pulley. I need one idler pulley ASAP. I bought the belt from 86 speed factory. Anyone know where I can get the idler pulley. And can I use the stock idler pulley?
Thank you
Vish
vpt is offline   Reply With Quote
Old 02-17-2018, 11:30 PM   #4376
twag4
Drives: frs
You will love the c30 kit! I ran it until I added flex fuel tune, then blew my engine. Now I am swapping to the c38 and a different transmission. Going the full monty! I believe the c30 with standard pulley actually edges out the c38 on a standard pulley in terms of output- Obviously tune dependent. The c38 just has way more overhead, and is more suited to high boost pulley without running on the ragged edge. I believe this all to be true, someone will correct me if I am wrong, I’m sure!
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
wheelhaus (02-18-2018)
Old 02-18-2018, 02:04 AM   #4377
CSG Mike
CSG Mike's Avatar
Originally Posted by vpt View Post
Hi Folks,
Thank you
Vish
The stock idler you removed can be used in a pinch, but not ideal. You can order from CSG or direct from JR.
Old 02-18-2018, 02:04 AM   #4378
CSG Mike
CSG Mike's Avatar
There is not. Go with the C30! The C38 has not proven to have any additional resale value on the secondary market.
PM when you're ready to get your order going!
Old 02-18-2018, 08:00 AM   #4379
vpt
Thank you. I see a high boost pulley in CSG. I have a flex fuel kit installed do I still need a tune if I use this? And will the tune pass in MA?
Old 02-18-2018, 05:20 PM   #4380
CSG Mike
CSG Mike's Avatar
I can't comment on your local smog laws, as I don't live in MA. You should get a touch up on your tune with a HBP.
vpt (02-18-2018)
Old 02-18-2018, 07:06 PM   #4381
mrg666
pessimistic skeptic
mrg666's Avatar
MA requires CARB. So ... you figure out.
The Following User Says Thank You to mrg666 For This Useful Post:
vpt (02-18-2018)
Old 02-18-2018, 09:21 PM   #4382
vpt
Do you have the regular idler pulley in stock. I see the HBP but not the regular one.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
