Old 02-15-2018, 10:34 PM   #3501
Vital
Drives: 2015 BRZ
Originally Posted by ApexEight View Post
Are the regular '17 dampers any different than the '13-'16? My '14 is past 80K miles on what I believe are the stock dampers. They still feel good. Throwing on TRD springs soon which I would imagine would degrade their performance a little quicker but not willing to drop the money on Bilstein or Koni.
No, they are not any different the only thing that was changed was the spring rates. So you can go ahead and just get any OEM dampers with low miles or get the SACHS dampers from a PP BRZ.
The Following User Says Thank You to Vital For This Useful Post:
ApexEight (02-16-2018)
Old 02-16-2018, 08:28 AM   #3502
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
To my knowledge this is incorrect.
The normal dampers where also updated, with different damping characteristics and I believe a supplier change as well. Even if you read all the 2017 model update articles they mention changes to both spring rates and dampers. From what I've heard they feel slightly better on track and significantly better on the road.
My car also has a lot of miles (86k+) so the update made sense to me.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post:
strat61caster (02-16-2018), Vital (02-16-2018)
Old 02-16-2018, 09:48 AM   #3503
Vital
Drives: 2015 BRZ
Ah ok, i always read that they changed the spring rates and also 2017 BRZ had stiffer rear sway bars as well. Did not know about the dampers but it makes they would have tweaked those too.
Old 02-18-2018, 10:50 PM   #3504
Brzandt
Drives: 2014 BRZ Limited.
Sorry can’t read through 250 pages so I’ll just ask. It’s a 3rd car driven hard 90% time. Upgraded rims and tires,rpf1 17x9 245/45/17, and the car gets bouncy at times. Rear strut is leaking. I’m on eibach springs now and would like to be around that ride height. Also I plan to boost soon. Would like to stay around $1000 give or take?
Brzandt is offline   Reply With Quote
Old 02-19-2018, 02:44 AM   #3505
churchx
churchx's Avatar
Drives: 2014 GT86
"Driven hard" - daily driving or track? What tires? What result you wish to get? (more comfort/compliance/less bouncy, or less roll, body movement mid curves?)
Old 02-19-2018, 10:42 AM   #3506
Pat
Pat's Avatar
Drives: 2023 BRZ
If you like your current springs, buy Bilstein B8s.
Also, you may want to reexamine the tire size you're using. A 40-series might be a better option for that width.
The Following 2 Users Say Thank You to Pat For This Useful Post:
strat61caster (02-20-2018), Teseo (02-19-2018)
Old 02-19-2018, 09:01 PM   #3507
Brzandt
Driven hard on back roads. No track yet but plan to try it eventually. I want it to handle as good as possible without riding to harsh. Wouldn’t want it to be much more harsh than stock. I do run errands in it, really I take an chance I can to drive it.
Old 02-19-2018, 09:48 PM   #3508
carlovestela
Drives: 2015 Firestorm FRS
If i install tein flex z. Will i need LCA and rear toe arms?
Need coils because i want rays 18 9.5+38
Currently im using trd springs
carlovestela is offline   Reply With Quote
Old 02-19-2018, 10:40 PM   #3509
cjd
cjd's Avatar
Drives: 2017 BRZ
For normal alignments? No. If you want even camber you probably need rear LCA, but no guarantee. Toe arms stock have plenty of range almost always with sane camber numbers.
Old 02-19-2018, 11:14 PM   #3510
carlovestela
I see. Just want factory alignment. Lol. Probably will need lca.
How about the 18 9.5 38. Some said it will fit on normal suspension. Im using trd springs
Old 02-20-2018, 08:45 PM   #3511
Brzandt
I just got the tires so got ride them out a while.Bfg GForce comp2 I believe. I think I’m gonna hold off on boost and get suspension best I can since it’s peaking and needs to be dealt with. That’s main reason I got this car anyway!! So what would be better springs with B8? Or would coil overs be better?
Old 02-21-2018, 10:00 AM   #3512
rick s
rick s's Avatar
Drives: 2013 FR-S Ultramarine 6MT
Spring rate question. I will be switching over to ISC N1 coilovers from my current set up of TRD lowering springs and Bilstein shocks. The shop says that the coilovers come with 10/7 rates. Does this seem reasonable? The car is a DD but is also run as an STX autocrosss car. The guys at the shop have run a BRZ and they said they had good results with the 10/7 set up. I believe the TRD are stiffer in the rear and a little concerned about stiffer front on the coilovers. They will do different spring rates if need be.
Comments, suggestions?
Thanks for the help. And I don't need advice on different brands of coilovers as I have an ISC sponsorship deal.
Cheers!
rick s is offline   Reply With Quote
Old 02-21-2018, 11:05 AM   #3513
Racecomp Engineering
Cheers!
10 kg/mm up front is too stiff. You don't need that much front spring IMO. And too much front spring bias.
It can feel fast, but a softer set up will be easier to drive, more consistent over different types of surfaces, have a better balance, and be more comfortable as a DD.
- andrew
Pat (02-21-2018), strat61caster (02-21-2018)
Old 02-21-2018, 11:30 AM   #3514
86league
Drives: '13 BRZ Limited
My '13 BRZ is mostly track use, but some street with ~300+ mile drives to some of the tracks so I want to keep it street friendly.
I'm on RCE yellows, stock shocks/sways - camber bolts and plates up front with SPC LCA's out back to get to -3.5F/-2.4R with 0F / 1/16in R toe. SX2 (200TW) tires, rest stock.
Tires are now wearing relatively uniformly across the tire with this camber setup (MPSS shoulder's absolutely got killed at very similar camber). No consistent reading on tire pyro after I drive off track and back to the pits (cools off a lot) - but nothing that looks bad either -- so I can mostly only go by wear for now...
Pictures from the track show a lot of roll ... e.g. http://www.hart-photography.com/phot...#image=4111227 -- inside front tire contact patch looks to be at 1/3 width or less in lots of the turns.
Will stiffer sway bars improve my cornering traction significantly, or just a little? I think the real answer would be stiffer springs, but that means shocks too so I'm into coilover money... not wanting to go there yet...
I like the car as is and am having fun and tire wear with the SX2's is good across the tire - getting ~10 track days out of a set with proper rotation... But, I kind of like to tinker, and if a (relatively) cheap set of sway bars would improve things a fair amount I am willing to try them...
Also - would stiffer sways mean I'd likely need to (get to) dial out some of the static camber?
Thanks !
86league is offline   Reply With Quote
The Following User Says Thank You to 86league For This Useful Post:
Shark_Bait88 (02-21-2018)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
