Old 02-16-2018, 01:13 AM   #379
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
This is an option if you don't feel like dealing with getting the OEM unit painted.
http://www.ft86speedfactory.com/carb...-s-brz-86.html
Originally Posted by Brink View Post
Yeah, guess I didn't clarify this but it is a stud so the stock riser core would have to be replaced. It's all OEM parts concerned though, the Drambeenie parts are still fully intact and can be transferred over once I get the new part from Subaru. New spoiler comes unpainted so I'm just gonna rip the cores out of the risers on it (may as well replace both if I have to take it off again anyway) and keep my original wing.
Originally Posted by humfrz
I'm old and lazy
Old 02-16-2018, 01:23 AM   #380
Brink
Drives: 2017 BRZ
Good to know, I don't plan on getting anything painted though. Just gonna pull the riser cores out of the new spoiler and swap them into mine, no need to paint any of it.
Brink is offline   Reply With Quote
The Following User Says Thank You to Brink For This Useful Post:
Clipdat (02-16-2018)
Old 02-16-2018, 07:33 AM   #381
Grady
Grady's Avatar
Well Subaru says I have to order a whole new spoiler, they don't sell the parts of it separately. $462 lol. Don't shear off your bolts guys.
It is molded into the plastic. No worries on repair. Find a bolt same size. Get a Dremmel and grind out the old bolt. Bond in the new bolt using a good epoxy. My suggestion is Hysol EA9309. Or for ease of access JB Weld should work.
https://www.aeropartsnow.com/product...yABEgIap_D_BwE
The Following User Says Thank You to Grady For This Useful Post:
Drambeenie (02-16-2018)
Old 02-16-2018, 07:54 AM   #382
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
That spoiler doesn’t have the inner cores you’d need. You’ll need OEM.
Drambeenie is offline   Reply With Quote
The Following User Says Thank You to Drambeenie For This Useful Post:
Brink (02-17-2018)
Old 02-16-2018, 07:00 PM   #383
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Finished the install today with the help of my dad @jmark. Everything went relatively smoothly and thanks to @tehShirt for the different approach to the installation.
Instead of attaching the risers to the spoiler then bolting the assembly to the trunk I attached the risers to the trunk loosely then sat the spoiler on top adjusted everything till the holes lined up and tightened everything down. This method seemed to eliminate some problems other guys have mentioned.
Overall I am very happy with the finished product and will have HQ pictures once we get some good weather/wash the car. Only downfall I have is now the aggressive look needs a front lip or splitter to match.
derekbrz24 is offline   Reply With Quote
The Following 8 Users Say Thank You to derekbrz24 For This Useful Post:
ATL BRZ (02-28-2018), Drambeenie (02-16-2018), jmark (02-17-2018), johan (02-17-2018), Racecomp Engineering (02-18-2018), spike021 (02-16-2018), Tcoat (02-17-2018), tehShirt (02-17-2018)
Old 02-16-2018, 07:08 PM   #384
spike021
spike021's Avatar
Looks awesome on WRB!
I also have the same issue. I'd wanted a lip before but now it definitely needs one to round out the car
spike021 is offline   Reply With Quote
Old 02-17-2018, 03:43 PM   #385
Brink
Drives: 2017 BRZ
Spoiler looks so nice in the rearview now, especially with the Intec high mount brake light and PWJDM shelf with the brake light delete to clean up the view.
Color match isn't perfect, risers are definitely whiter than the car, though that might be due in part to the risers not being waxed yet (and being fresh paint vs. a year old) so maybe waxing and a bit of time will bring it closer to a match. It's not something that stands out unless you're right next to the car looking at them though, and even then I feel like it only stands out in certain lighting conditions (and maybe even then just because I'm looking for it, hard to say how noticeable it would be to someone not checking out the color match on that particular part).
New spoiler should be coming in on Tuesday, hoping to swap out the parts I need on Wednesday. I never did get that broken stud/nut out of the trunk but it's stopped rattling around now, must have wedged itself in somewhere. Maybe when I have the spoiler off on Wednesday I'll see if I can shake it loose and get it out.
The Following 3 Users Say Thank You to Brink For This Useful Post:
Drambeenie (02-17-2018), spike021 (02-17-2018), Tcoat (02-17-2018)
Old 02-17-2018, 07:18 PM   #386
spike021
spike021's Avatar
Posted a full review on the vendor subforum just now: http://www.ft86club.com/forums/showt...25#post3045825
Again, thanks Stephen for doing such a wonderful job with these.
I think it was well worth it.
The Following 3 Users Say Thank You to spike021 For This Useful Post:
Drambeenie (02-17-2018), Tcoat (02-17-2018), tehShirt (02-17-2018)
Old 02-17-2018, 09:01 PM   #387
That combo would rock!
Ya, white is hard to match even when the pros are blending it so painted separately will usually show some difference. Waxing may help but they should even out after weathered a bit.
Drambeenie (02-18-2018)
Old 02-18-2018, 02:06 PM   #388
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Drambeenie Risers MEGATHREAD.
I haven't seen anyone with a CWP car get the matte black option. I installed mine today, love them! The risers are almost a perfect color match for the wing.
mjanmohammad is offline   Reply With Quote
The Following 4 Users Say Thank You to mjanmohammad For This Useful Post:
Drambeenie (02-18-2018), tacos (02-28-2018), Tcoat (02-20-2018), tehShirt (02-18-2018)
Old 02-20-2018, 01:08 PM   #389
Drambeenie
Drambeenie's Avatar
Were you using a 10mm socket wrench when the bolt sheared?
Old 02-20-2018, 03:14 PM   #390
Brink
Drives: 2017 BRZ
Yeah
Old 02-20-2018, 07:29 PM   #391
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
first pic after install.
Elliotw is offline   Reply With Quote
The Following 5 Users Say Thank You to Elliotw For This Useful Post:
dhuang (02-23-2018), Drambeenie (02-20-2018), spike021 (02-20-2018), Tcoat (02-20-2018), tehShirt (02-20-2018)
Old 02-21-2018, 02:06 AM   #392
Akuma147
Drives: 2017 DGM BRZ Limited
Just got my risers in, and hope to get them installed this weekend. Is there a definite answer which method would be best to use for installation?
Akuma147 is offline   Reply With Quote
removal, spoiler, trunk, wing
Remove trunk spoiler clips? Drambeenie Member's Car Journals 0 05-09-2017 11:31 PM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 12:49 AM
2017 BRZ without spoiler? vroomvroom1 BRZ First-Gen (2012+) — General Topics 9 07-18-2016 10:46 AM
Remove spoiler for Rocket Bunny one? xrinnenganx Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 10:28 AM
Is there a way to remove the spoiler? rapier7 BRZ First-Gen (2012+) — General Topics 15 08-21-2013 10:58 PM
