Old 02-15-2018, 03:57 PM   #365
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Something I’ll mention as well that I hadn’t before. I don’t know exactly what kind of treatment was done on the risers after painting, but I ended up putting 3 or 4 coats of light wax on them the night before the install. Not a requirement by any means but just an added nice thing to do if you care about that kinda stuff.
Originally Posted by johan View Post
Everyone should do this, they definitely should be waxed.
The risers are very very freshly painted, so please hold off on any wax for at least 30 days as the off-gassing can get trapped under the wax and prevent the clear coat from fully curing. It can also lead to other paint issues
Drambeenie is offline   Reply With Quote
Old 02-15-2018, 04:44 PM   #366
johan
Drives: '14 981CS, '99 NB1
I was going to mention this myself, but you posted that they'd been painted as of 1/17-1/18, so that's about 30 days. So it should be fine now.
johan is offline   Reply With Quote
Old 02-15-2018, 05:25 PM   #367
spike021
spike021's Avatar
Can you confirm when the CWP risers were painted?
spike021 is offline   Reply With Quote
Old 02-15-2018, 06:20 PM   #368
Drambeenie
Drambeenie's Avatar
I can’t be 100% certain on the painting of exact colors. The only information I have after I said that they were being painted was an email from my supplier on January 31st saying all of them have been finished painting.
Old 02-15-2018, 06:30 PM   #369
Brink
Drives: 2017 BRZ
Hate myself right now. Was so close to being done installing my risers, then pop! Bolt sheared off somehow, didn't feel like it was that tight or cross threaded or anything but there it went. Waiting to hear back from Subaru on parts, hopefully they sell just the piece I need separately but I might have to get a new spoiler.
Also, found a good tool for popping the inner core out of the riser. This little thing that came with a kit of trim tools was perfect, just stick it in the side and lever the inner core sideways, slides right out.
Noticed a bit of a flaw in the paint on the left riser - didn't see it until I had mounted the spoiler and opened the trunk to bolt it on so the riser was right in front of me at eye level
Brink is offline   Reply With Quote
Old 02-15-2018, 08:00 PM   #370
Brink
Drives: 2017 BRZ
Well Subaru says I have to order a whole new spoiler, they don't sell the parts of it separately. $462 lol. Don't shear off your bolts guys.
Old 02-15-2018, 09:40 PM   #371
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Can you call a different dealer, or look up part numbers on https://subaruonlineparts.com/ ?
The way that Subaru likes to assign part numbers to literally everything, I can't imagine that the bolts wouldn't be available for purchase separately.
Originally Posted by humfrz
I'm old and lazy
Old 02-15-2018, 10:46 PM   #372
Brink
Drives: 2017 BRZ
I looked online before contacting the dealer, it just showed spoiler assembly. Some of the little stuff like the gaskets or clips they list separately, but the spoiler isn't broken down at all.
Old 02-15-2018, 10:48 PM   #373
johan
It's not a bolt. It's a stud molded into the plastic.
Old 02-15-2018, 11:33 PM   #374
Clipdat
Proud of BOXER
Clipdat's Avatar
Ah, nevermind then. Sucks.
I'm old and lazy
Old 02-15-2018, 11:40 PM   #375
Brink
Drives: 2017 BRZ
Yeah, guess I didn't clarify this but it is a stud so the stock riser core would have to be replaced. It's all OEM parts concerned though, the Drambeenie parts are still fully intact and can be transferred over once I get the new part from Subaru. New spoiler comes unpainted so I'm just gonna rip the cores out of the risers on it (may as well replace both if I have to take it off again anyway) and keep my original wing.
Old 02-15-2018, 11:40 PM   #376
Drambeenie
Drambeenie's Avatar
A whole spoiler?? Maybe bring the piece to a body shop and ask them to weld the piece back on.
Old 02-15-2018, 11:50 PM   #377
Brink
Drives: 2017 BRZ
I'd rather not have any welding done. A new spoiler is an unexpected expense but I'd rather go that route than have the spoiler welded on.
Everything seems pretty solid right now though, drove a bit with it as is and the only rattle was from the broken stud/nut rolling around in there since I haven't been able to fish it out yet. I have a magnetic grabber thing but it can't fit through the opening so I'll have to figure something else out. I think I'm lucky it was the rear bolt so should see less force than the front bolt in general, the way its angled. Keeping it under 45 mph as a precaution (not a problem for me since I work close to home and can stay off freeway easily) but no problems driving with it so far. A bit loose when closing the trunk but otherwise good.
Old 02-15-2018, 11:56 PM   #378
Drambeenie
Drambeenie's Avatar
Oh I meant to weld the little piece that broke off back onto the riser.
But the VHB tape is really really strong so after it cures it should be solid but can’t really guarantee it’s security. I will say I recently removed my spoiler to test some parts, and removing the risers was almost impossible. The VHB was stuck on so well that the hinges of the trunk started pulling up lol but that had been stuck on for months. VHB tape is strong but def nice to have that last bolt attached for added security.
removal, spoiler, trunk, wing
Remove trunk spoiler clips? Drambeenie Member's Car Journals 0 05-09-2017 11:31 PM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 12:49 AM
2017 BRZ without spoiler? vroomvroom1 BRZ First-Gen (2012+) — General Topics 9 07-18-2016 10:46 AM
Remove spoiler for Rocket Bunny one? xrinnenganx Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 10:28 AM
Is there a way to remove the spoiler? rapier7 BRZ First-Gen (2012+) — General Topics 15 08-21-2013 10:58 PM
