Old 02-12-2018, 05:52 PM   #15
Flateightysix
Drives: 2013 Ultramarine Scion FR-S
Originally Posted by Clash0901 View Post
I actually just ordered an is300 rear diff. LSD and 3.73 with 115k miles from Cali so rust free as well.
Hopefully this is enough and hopefully it bolts right on as people claim.
Hopefully everything swaps pretty easy. good luck let us know how it goes.
Flateightysix is offline   Reply With Quote
Old 02-12-2018, 08:26 PM   #16
fika84
fika84's Avatar
Originally Posted by Flateightysix View Post
I know there are a few write ups on here where people have swapped either a mark four Supra diff internals, or swapped the pumpkin and internals from an is300 that has an lsd and have lowered the final drive to 3.7 or 3.9, but there are no detailed write ups on the Supra conversion or swapping the is300 diff. I do know that it has been said the is300 diff mounting pints are the same as ours. I think @mrk1 or @mr1k had the is 300 diff on his car.
I bought a used is300 pumpkin and swapped weir 4.88 gears for the Supra 1986.5-92- ALL on their website along with the solid spacer instead of crush washer and MFactory Mechanical LSD. Then it's just a matter of ordering a bunch of shims and taking your time to set the preload and backlash. I still have my stock pumpkin intact sitting in the garage. All in all it goes smoothly as long as you take your time. So to answer your question. Yes you can take the gears and/or lsd out of the is300 and also use it in our pumpkins. They are identical on the inside.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Flateightysix (02-15-2018)
Old 02-12-2018, 08:27 PM   #17
fika84
fika84's Avatar
See above, but it will bolt right up
Old 02-15-2018, 03:22 PM   #18
Flateightysix
Awesome that is perfect
Old 02-15-2018, 03:27 PM   #19
Flateightysix
One other thing I think would be interesting would be to see if you could swap diff covers on the is300 diff also. For example use the Cusco diff cover or the GReddy high capacity one and still make everything fit
Old 02-15-2018, 05:40 PM   #20
fika84
fika84's Avatar
You can, they're literally identical pumpkins. One day I'll drop $500 on the damn covers for more capacity and the option for a diff cooler.. the mechanical LSD can get quite hot.
DIY - Differential and Ring & Pinion Swap Dustin DIY (Do-It-Yourself) Guides 126 07-01-2019 11:29 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 03:21 AM
WTB ring and pinion Salemate Canada Classifieds 0 03-13-2016 03:07 PM
3.9 final gear - ring and pinion PantsDants Engine, Exhaust, Bolt-Ons 5 11-08-2013 04:06 AM
MFactory Ring and Pinion Sets JMPoole Engine, Exhaust, Bolt-Ons 14 07-31-2013 01:09 PM
