Old 02-15-2018, 08:52 AM   #295
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I've had the Vortech V3 for 4 years now, although in those 4 years I've only clocked 10,000km on the car. No problems aside from a pulley squeaking sound when the engine is cold and goes away in a couple of minutes once the engine is warm.
HRTROB is offline   Reply With Quote
Old 02-15-2018, 01:45 PM   #296
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Does anyone else go through belts like, 1 a year?
My belts start to squawk after what seems like just one summer. And I buy the Gates blue option, and those fuckers are like $50 a whap.
I have almost all aftermarket pulleys, including the crank pulley, so I'm thinking they might be a bit deeper ribbed than the stock ones because it seems that the valleys of the ribs are the down to bare metal.
I'm changing back to the OEM crank pulley as I rebuild this time, but just seeing what everyone else is experiencing.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following 2 Users Say Thank You to Gopherboy6956 For This Useful Post:
AJPG (02-15-2018), new2subaru (02-15-2018)
Old 02-15-2018, 02:46 PM   #297
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
There's an easy and inexpensive solution for belt squawk, just give the belt a light dusting (ribbed and flat side) with talcum power while the engine's idling. Should shut it up for a week or two. The product I use over here in Africa is Johnson's Baby Powder. Don't know if you get it in your neck of the woods. I keep it in the car, and use when necessary. Takes a few secs to sort a noisy belt out.
Only downside is it looks like you spilt your cocaine stash in the engine compartment, but a light rinse or a blast of high pressure air will sort than out.
I last had to put powder on about 6 months ago. My belt is 4+ years old, and seems to have settled down nicely now. No more squawks...
Fish Eagle is offline   Reply With Quote
The Following User Says Thank You to Fish Eagle For This Useful Post:
AJPG (02-15-2018)
Old 02-15-2018, 07:19 PM   #298
AJPG
Drives: 22RE, FA20, 4G63
So you’re squawking your belts in couple of months! Haha I would like to see that mad driver in action.
Anyway,
Depending on the driving, belt could last very short or they normal life (that you already know), the problem is the additional mass and the change in direction during shifting. Especially downshifting, due to the position or the belt tensor, (so the belt loss tension during downshift and squawking begins)...
So how in the world I could solve that problem? Well you will need a machine shop, spare pulley (for practice) and one way bearing. This I been using for the last 18 to 20 months with ridiculous good results.
Hope this helps but if not please don’t hesitate to ask.
AJPG is offline   Reply With Quote
Old 02-15-2018, 07:59 PM   #299
Gopherboy6956
Anyway,
Can you elaborate on that last part? How does that work? I actually row down through the gears in town vs just let the clutch in and then hit neutral, so that might have something to do with it.
Sent from my SM-N950U using Tapatalk
Old 02-15-2018, 10:17 PM   #300
AJPG
You dirty little scar face
Old 02-15-2018, 10:33 PM   #301
AJPG
Vortech Owner Thread & Setup Questions
One way bearing. On one way freewheel (that will be down shifting) and full attach at engine acceleration.
Old 02-15-2018, 10:38 PM   #302
Gopherboy6956
One way bearing.
No idea what you mean.
Old 02-15-2018, 10:40 PM   #303
AJPG
Sorry was editing
Old 02-15-2018, 10:45 PM   #304
AJPG
There you go buddy!
[ame]https://m.youtube.com/watch?v=QjR7dimpSJA[/ame]
I do not work or have any activity with renold, do like quality
Old 02-16-2018, 01:25 AM   #305
Gopherboy6956
So which pulled to you replace? you have to MAKE one of these then, you're saying? But even during downshift, the belt is still moving in the same direction.
I guess I still don't fully understand.
Old 02-16-2018, 04:39 AM   #306
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
I'm back on here after a few years and I see this old thread got brought back to life. I installed my kit almost 5 years ago and everything is still running solid. That being said I still haven't even hit 30,000 miles in my FR-S as I've had a second vehicle most of the time so it spends most of it's days in the garage. I'm tuned for both pump and E85 and haven't had any issues. I'll be drifting my FRS soon at events with the Vortech kit so we'll see how that goes.
reyruiz191 is offline   Reply With Quote
Old 02-16-2018, 08:50 AM   #307
AJPG
The one way bearing will be use on the sc pulley and you are completely correct the belt should continue in the same direction but at the moment you try to decelerate the engine speed the freewheel action will save the belt of trying to change direction (or at least the rapid deceleration).
Note, after reading my post I did explain it wrong, sorry. The problem is with up shifting and sudden drop on rpms.
I buy a couple of pulleys with the desire diameter and almost completely don’t care about the in side (that side will be machined to accept the one way bearing). Also have to make some minor modifications to the sc shaft to accept and hold the one way bearing.
The idea in simple terms is to spin the blower in one direction only (the direction of making boost, that is the same of the engine when accelerating) and if anything happens that try to reduce speed of the blower it will freely and gently decrease speed without hurting the belt until rpms match and boost resumes.
Old 02-16-2018, 12:43 PM   #308
Gopherboy6956
Interesting. Not sure i'm up for that project though.
Thanks for the info.
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 05:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 03:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 01:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 03:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 12:09 PM
