Old 01-20-2018, 08:55 AM   #1695
Somerandom18
Drives: 2017 manual BRZ
Found out the misfire parameter changes even with the engine off.. but only for cylinder 2. Normal?
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 01-25-2018, 10:37 PM   #1696
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
noob to tuning, i was wondering if someone can take a look at this log for a Stage 1 OFT tune. KN filter, stock headers with catless front pipe and invidia n1 cb. is there any advise i can do to polish up my tune? thank you!
https://datazap.me/u/mizzta21/log-15...3&zoom=360-419
mizzta21 is offline   Reply With Quote
Old 02-04-2018, 03:36 PM   #1697
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Just got OFT and am running St2 EL E85 on stock car... I have likely typical noob questions..
It looks like I didn't log KC Learned and didn't get any smooth pulls like you guys are finding ways to record. I recorded driving on freeway, then on some side streets to check figures after going through the first half tank of e85 very cautiously and slowly. Maybe it's due to the length of the recording that you need to zoom in on one section to analyze as easily as it sounds?
Also, around 4k rpms under load it sounds like angry bees or a raspy honda sound for a short period now, wasn't hearing that before, but I don't see huge AFR fluctuations, crazy fuel trims, or evidence of knock, or am I mistaken?
Thanks for any insight
https://datazap.me/u/toyarzee/first-...data=1-5-10-12
https://datazap.me/u/toyarzee/first-...ta=1-5-8-10-12
Toyarzee is offline   Reply With Quote
Old 02-14-2018, 01:00 PM   #1698
bababooey
Drives: BRZ SWP Limited -6MT
those links dont load
bababooey is offline   Reply With Quote
The Following User Says Thank You to bababooey For This Useful Post:
Toyarzee (02-14-2018)
Old 02-14-2018, 05:02 PM   #1699
Toyarzee
Shibby!
Toyarzee's Avatar
That's weird, worked elsewhere, not sure what I did. Maybe this one will work if copy paste from my phone is okay:
https://datazap.me/u/toyarzee/tank-3...-2-8&mark=3230
Old 02-14-2018, 06:07 PM   #1700
bababooey
total disclaimer, im not the numbers guru, im still learning how to interpret these logs.
the flkc & knock corrections dont look too worrisome, from feedback received from my logs some low rpm partial throttle will produce those events. when you were up @ high rpms the afr seemed to be in the ballpark of safe. i havent dove too deep into the fuel trims, so no help there.
ive read the el tune has been reported to have that raspy sound right around 4k. something with vvt changes as compared to uel tunes.
Toyarzee (02-15-2018)
Old 02-15-2018, 11:54 AM   #1701
Toyarzee
Shibby!
Toyarzee's Avatar
Thank you kind sir. I've been doing some more hw on the matter as well and am seeing the same reported noise and question popping up elsewhere. It's worrisome sounding, but understandable (not annoyed, but don't like tracking a car without feeling confident I can bury the pedal at w/e rpm.) I also don't mind running a tad rich in some areas for safety at the cost of leaving some ponies on the table, and the catted header won't stay for too long. Long story short, I appreciate the supporting piece of mind on a non oem tune
Old 02-22-2018, 03:34 AM   #1702
chargedup
Drives: SC BRZ
can someone tell me what in the shit is going on here. my logs say im running like 60+ degrees of timing. none of it is making sense to me..
https://datazap.me/u/gbrz/log-151928...og=0&data=6-12
chargedup is offline   Reply With Quote
Old 02-22-2018, 03:53 PM   #1703
Kodename47
Kodename47's Avatar
Drives: UK GT86
What's wrong with that log?
Stock tune logged with EcuTek?
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-23-2018, 01:53 AM   #1704
steve99
Drives: FT86
Hmm what mods ?? Lookks like ltft disabled and its running very rich for na car is it supercharged ??
Old 02-23-2018, 04:51 AM   #1705
chargedup
Drives: SC BRZ
is that stock tune..? does that mean I somehow loaded stock back on there?
It's sprintex supercharged on e85. Always has ran very rich, only get 12mpg ish.. let me try to find another log and upload.
Old 02-23-2018, 05:44 AM   #1706
steve99
Drives: FT86
Ok seems very rich if its on e85 its running richer than 11 which looks like the limit of scaling on 02 sensor when the commanded afr is about 12 or 13.
Something seems wrong
Old 02-23-2018, 06:41 AM   #1707
chargedup
Drives: SC BRZ
That seems like the least of my worries... with this log manifold pressure hits 20psi, timing hits 60*, both of which are pretty impossible. I'm not sure if im logging the correct tune or what.. other dude said this was the stock tune
Old 02-23-2018, 06:49 PM   #1708
steve99
Drives: FT86
If it was stock tune on e85 it would run very lean
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
