Old 01-30-2018, 01:21 AM   #1317
CSG Mike
CSG Mike's Avatar
Originally Posted by Crashdummy View Post
Good to know!
Do you know what front pipe was on that RS1.0 in the video?
Stock!
It's amazing how much good flow changes the induction noise.
Old 01-30-2018, 10:50 AM   #1318
Crashdummy
too much is never enough.
Crashdummy's Avatar
Drives: 2015 FR-S RS1.0, 2005 Corolla XRS
Stock!
Excellent! thanks!
Too much is never enough.......
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon
Nanako's Mod Thread
Crashdummy is offline   Reply With Quote
Old 02-01-2018, 12:24 PM   #1319
maicolp
Drives: toyota gt86 1st edition
i drove my car for 400km since installation and mapping.. those headers are awesome! i suggest to check nut tightness after a wile because its impossible to reach three of them with an torque wrench. so doing it by hand in a small space may result in undertorqued nuts.
maicolp is offline   Reply With Quote
Old 02-01-2018, 06:17 PM   #1320
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Put torque stripes on them!
https://www.amazon.com/Dykem-Tamperp...EYQ8E10EF7821F
Ganthrithor is offline   Reply With Quote
Old 02-08-2018, 04:24 AM   #1321
maicolp
retightened everyting. better then before! sound and performance is top choice for el headers
Old 02-08-2018, 02:33 PM   #1322
justinco
justinco's Avatar
Drives: 2022 GR86
Good info. I will check mine in a few weeks as well as I just got it installed!
justinco is offline   Reply With Quote
Old 02-08-2018, 03:30 PM   #1323
gtengr
Drives: 2017 BRZ
After I installed mine, I left the car on stands with the underpanel off and heat cycled it a few times, then re-checked all the nuts.
gtengr is offline   Reply With Quote
Old 02-08-2018, 03:34 PM   #1324
justinco
justinco's Avatar
Drives: 2022 GR86
I probably should have done that. Oh well, only takes a few minutes to get the under panel off and do it.
Old 02-08-2018, 04:02 PM   #1325
CSG Mike
CSG Mike's Avatar
This is a great best practice for all parts, especially ones that see deep heat cycles and vibration like exhaust components!
Old 02-14-2018, 09:08 AM   #1326
Chamaco
Drives: Silver FR-S
Here it is Guys, took it to the dyno yesterday to tune the car with the header and this are the results;
1st pic is with the OFT v3.0 tune I had there before the header.
2nd is my tuner map
3rd is a run just after a few minutes of cool down and no tuning.
Sent from my SM-G950U using Tapatalk
Chamaco is offline   Reply With Quote
Old 02-14-2018, 09:09 AM   #1327
Chamaco
Drives: Silver FR-S
2nd is my tuner map
The most important thing I wanted to know is the Torque, but the guys at the dyno didn't connect the RPM signal wire to the coils.
Old 02-14-2018, 11:28 AM   #1328
Lantanafrs2
Drives: 2013 frs red
Is the first graph stock header?
Lantanafrs2 is offline   Reply With Quote
Old 02-14-2018, 03:07 PM   #1329
Chamaco
Drives: Silver FR-S
No, weird right! Gotta be the header don't like the OFT tune. Or maybe heat soak? Like what happened in the last run where the car gained 5whp.
Old 02-14-2018, 03:54 PM   #1330
Pat
Pat's Avatar
Drives: 2023 BRZ
What?
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
