Old 02-11-2018, 09:27 PM   #1
ChacetBRZ
Drives: 2013 Brz
Question about Wheels
I just purchased some wheels and they are 18x9.5 +40 Wheel on 235/40r18 tires will this fit on stock suspension without rubbing? or do i need to put coil-overs and add camber? never played much on suspensions.Thanks for any help.
ChacetBRZ is offline   Reply With Quote
Old 02-11-2018, 09:46 PM   #2
ChacetBRZ
Drives: 2013 Brz
the guy i bought them from had them on a Brz just didnt get a chance to ask him what his suspension setup was.
Old 02-11-2018, 09:53 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I would imagine coilovers, because if it fits, it will be with basically ZERO clearance to the spring perch, and no room for ANY camber. And without camber, those wheels will poke significantly in the front at that offset.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 02-11-2018, 09:53 PM   #4
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=15007
BirdTRD is offline   Reply With Quote
Old 02-12-2018, 06:06 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Read post 213 and 214.
http://www.ft86club.com/forums/showt...=28017&page=16
Read page one of the Meaty tire thread.
http://www.ft86club.com/forums/showthread.php?t=41083
I LIKE TIRES!
ChacetBRZ (02-17-2018)
Old 02-13-2018, 08:28 AM   #6
oaroyale
Drives: Black BRZ
I am pretty sure you can only have up to +38 on stock suspension with 9.5 width, otherwise it will rub the spring perch.
oaroyale is offline   Reply With Quote
The Following User Says Thank You to oaroyale For This Useful Post:
Old 02-17-2018, 08:25 PM   #7
ChacetBRZ
Drives: 2013 Brz
Thanks this helped a lot.
The Following User Says Thank You to ChacetBRZ For This Useful Post:
Leonardo (02-17-2018)
Question about wheels. lupindub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-05-2015 04:39 AM
If I want many wheels? + Serious question Mikeez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 01-26-2015 11:18 PM
Question regarding my wheels? koyv90 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-19-2014 01:27 PM
Question: Does Light Wheels = Weak Wheels Gary in NJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 06-29-2013 10:08 PM
Wheels Question Tsinoy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-19-2012 01:45 AM
