, dpfarr
Old 02-12-2018, 06:50 PM   #2661
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
With proper supporting mods, the kit is rock solid at the track.
For the occasional track day, I have no oil cooler, but I think it does depend on typical ambient conditions and how long and hard the vehicle is run. I have the Delicious Tune, but otherwise she is stock.
Sent from my Moto G (5) Plus using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 02-12-2018, 06:53 PM   #2662
CSG Mike
CSG Mike's Avatar
Unless you're keeping the RPMs low, I would consider an oil cooler to be a mandatory mod for the health of your engine.
Old 02-12-2018, 06:57 PM   #2663
paiceyfan
paiceyfan's Avatar
Interesting... because you're the one who said I didn't need an oil cooler when I asked for your advice, originally, but I understand that your view may have changed over time
Old 02-12-2018, 07:03 PM   #2664
CSG Mike
CSG Mike's Avatar
It's completely dependent on your usage. As a commuter car that sees redline every once in a while, you don't need one.
If you're sustaining high RPM for more than a few minutes at a time (e.g. being on track for a 20 minute session), then an oil cooler is vital to proper lubrication, whether you're boosted or not.
Teseo (02-21-2018)
Old 02-12-2018, 09:43 PM   #2665
paiceyfan
paiceyfan's Avatar
Not making a big issue out of this, but...
Old 02-13-2018, 12:14 AM   #2666
CSG Mike
CSG Mike's Avatar
You miss the context.
For someone with zero to minimal experience, who won't be sustaining high revs on track, it's totally fine. Anything more than that will mandate an oil cooler.
Old 02-13-2018, 12:37 AM   #2667
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Reserved for CSG's review and data.
Waiting for-e-ver.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Hades (02-14-2018)
Old 02-19-2018, 02:14 AM   #2668
adamghoffman@gmail.com
LagunaSeca86
Drives: No stone left unturned
Big power on track
Seems to be a lot of people daily driving this kit, anyone routinely driving it hard on track with a built motor and one of the smaller pulleys?
adamghoffman@gmail.com is offline   Reply With Quote
Old 02-19-2018, 01:11 PM   #2669
CSG Mike
CSG Mike's Avatar
Several, although they don't regularly post on the forums. Cool the car according to the output level, and you'll be just fine.
Old 02-20-2018, 11:46 PM   #2670
gahooligan
Drives: 2017 BRZ Premium
Are the 2017 kits released yet?
Sent from my SM-N950U using Tapatalk
gahooligan is offline   Reply With Quote
Old 02-21-2018, 12:23 AM   #2671
CSG Mike
CSG Mike's Avatar
Not yet!
Old 02-21-2018, 01:44 AM   #2672
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
Not yet!
Hey Mike, I'm assuming you and your crew have tweaked around with this kit long enough to know the ins and outs of what to do and what not to do.
I've decided to go with a 2.5" full exhaust system where the header is EL catless, aftermarket OP, and non-resonated with HFC FP. Next I'm looking to get the Jackson Racing DR/OC + The Edelbrock D Box.
I don't have any affordable access to e85 so FF is out of the question. I have looked at Water/Methanol injection which my local area has access to, but unfortunately I'm not certain about it's capabilities and longevity on our cars; especially a 2017 model.
One of last thing I've considered so far is to change out the boost pulley from the stock 3.25" (10psi) to the 3" pulley. (12psi) (Correct me if I'm wrong)
I am planning to keep the stock motor nor do I plan on building it as my goal for this car is DD and the weekend warrior where I do at the most 5 or 6 drag races.
I am aiming for at the most 350whp and ~250wtq
I figure the 2.5" EL full exhaust setup + JR DR/OC + Edelbrock D Box will get me close if not over 300whp on 92 octane, but will getting a higher boost pulley with this setup on a 2017 AT 86 be a really bad idea on the stock CR?
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 02-21-2018, 02:08 AM   #2673
CSG Mike
CSG Mike's Avatar
12 is doable with a good header. If you tune for water/meth,and your system fails and/or runs out, it pretty much guarantees a blown engine, so I don't recommend that.
350whp will only be possible with race gas, if ethanol isn't available to you.
ThatAsianBradah (02-21-2018)
Old 02-21-2018, 02:16 AM   #2674
ThatAsianBradah
Do you have the part # on hand for the 3.00" pulley and other related parts necessary?
I've checked out the Edelbrock website and Summit Racing website but no solid on the 3.00 pulley that's the specific fit for the frs/brz/86 model
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
