BoostedBRZ
Drives: Turbo BRZ
Catch Can Setup
I was gifted this catch can:
https://www.mishimoto.com/compact-ba...RoCVSEQAvD_BwE For some background info: I will be running a JDL turbo kit with a GTX2860r with ethanol, will definitely see the track. I did some research and I was planning on capping off the vacuum nipple on the intake manifold as well as replacing the PCV with a straight through valve. Then with the "Out" port on the catch can that would obviously be VTA. Lastly, with both ins, I would run the PCV and then the CCV into one can since the Mishimoto one I have is a three port. The one thing that concerns me is that Mishimoto's build thread states that they couldn't tie it to one system upon initial development for their catch can due to differential pressures... I ran into a thread about the D3PE catch can and that setup is exactly what I was planning on doing with my Mishimoto can. Also, looking at Verus' AOS, they also send it to one can and VTA if choose to do so. Am I missing something here or the setup above should work just fine and I'm just over thinking? Thanks!
#2 |
Drives: Asphalt 2015 FRS
With Mishimoto worried about pressure differentials, it might be possible to just put check valves on both of the input lines.
Under vacuum, air should be coming in from the crankcase breather and out through the PCV. That would be my best guess based on my [limited] knowledge. It seems most, if not all, people run 2 catch cans if they want to vent both the PCV and CCV on this platform. I'm sure someone else with a lot more knowledge of how this all works will chime in, but that might be able to get you started. Excited to learn more about the way this system works myself. Here is a good jump-off point: http://www.agcoauto.com/content/news/p2_articleid/197
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101096
| FS: Radium Dual Catch Can Setup | Mr671grains | Engine, Exhaust, Bolt-Ons | 7 | 07-21-2017 12:33 AM |
| Radium Dual Catch Cans on NA setup | xstatic | Engine, Exhaust, Transmission | 7 | 05-14-2017 12:31 PM |
| Oil Catch Can for Turbo Setup | tonytduc | Forced Induction | 15 | 03-23-2016 11:16 PM |
| FS: Radium Universal Catch Can - BRZ/FR-S Setup | F1point4 | Engine, Exhaust, Bolt-Ons | 8 | 04-09-2015 01:08 PM |
| High HP turbo catch can setup | Dan@AWD | Forced Induction | 32 | 08-06-2014 08:52 AM |
