Old 04-27-2017, 07:26 AM   #29
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Originally Posted by Kodename47 View Post
Simple rule of thumb, increase boost, reduce ignition advance..... don't go doing both
Did I say add , i ment modify.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-27-2017, 08:57 AM   #30
Tor
Tor's Avatar
Drives: Toyota GT86
I got ecutek just for the map switching, but i use it to switch fuels with 95 ron 98 ron , E 40 and e85 maps in the 4 slots, saves me reflashing all the time and cheaper and easier than full flex. I ws able to sell my oft for goid price and picked up a secondhand cabke kit cheap. I probably would not do it just for lc ffs and auto blip on na car.
Is it possible to have different timing per gear?
Tor is offline   Reply With Quote
Old 04-27-2017, 11:05 AM   #31
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes
.: Stealth 86 :.
Kodename 47 DJ:
Tor (04-27-2017)
Old 04-27-2017, 04:58 PM   #32
Tor
Tor's Avatar
Drives: Toyota GT86
Yes
This seems like a feature alone that would make Ecutek worthwhile. Is it available without Racerom?
Old 04-27-2017, 05:00 PM   #33
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, it would have to be done in Custom Maps.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-29-2018, 10:46 PM   #34
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Nice to see james martin still doing unlocked tunes
I was recently tuned by James went i went FI. I have an OFT that I am trying to sell. So if James tunes are unlocked, which I will double tap on, it should be as easy as flashing ECUTEK to stock, then connecting OFT and flashing back stock to unmarry it, and then flashing back my ROM?
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 01-30-2018, 12:18 AM   #35
steve99
Drives: FT86
Unfortunatly no
James tunes are unlocked meaning you can view and ecit his tunes using ecutek, but ecutek still locks the ecu if a non stock tune is in ecu.
If you flash back stock rom with ecutek it will unlock ecu, and you could write with oft but dont as you will loose yoyur ecutek licience.
Talk to james to see if he could re issue ecutek licience
Old 02-05-2018, 03:08 PM   #36
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
@steve99 - Is it possible to use EcuTek to log your stock tune?
I want to log my tune to see if I need a custom tune. Trying to figure out if I have to pay the $300 license fee for that to work.
TofuJoe is offline   Reply With Quote
Old 02-05-2018, 07:24 PM   #37
steve99
Drives: FT86
You dont need licience in ecu to log, base pro ecukit will log any brz\86
TofuJoe (02-05-2018)
Old 02-05-2018, 08:25 PM   #38
TofuJoe
Ohne Titel
TofuJoe's Avatar
That is great news. Thank you!
Old 02-07-2018, 07:59 PM   #39
TofuJoe
Ohne Titel
TofuJoe's Avatar
@steve99 - I was able to borrow an EcuTek cable today and do a log. Let me know what you think: https://datazap.me/u/jreifer/2017-br...12-16-21-29-30
Trim the datalog to between about the 8 through 24 time s marks to see the pull. I couldn't figure out how to get this view permanently.
Some things I noticed (I'm a beginner here, so these are more observations/questions than answers):
Long Term Fuel Trim is steady at -1.6 during the pull.
Ignition timing takes a slight dip between 4400-4800 (normal?).
Actual Lambda is about .90-.86 until the end of the run when it dips to .75.
AFR actual takes a second to get in line with the target AFR.
Lambda actual and target take a second to get in line and then are very close.
I'm sure there are a ton of things I'm missing here. Interested to hear your thoughts. Thanks!
The Following User Says Thank You to TofuJoe For This Useful Post:
mistople (02-22-2018)
Old 02-08-2018, 03:34 AM   #40
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just and FYI AFR Target and Lambda Target are the same thing. Same for AFR/Lambda Actual.
So long as there's no real FLKC (Ign Correction - Fine) then it's OK, but I can't see that you logged that.
It looks like a loss of traction at 6.5k RPM?
Engine load would possibly explain the loss of ignition timing, but you didn't log that either.
.: Stealth 86 :.
Kodename 47 DJ:
TofuJoe (02-08-2018)
Old 02-08-2018, 06:36 AM   #41
steve99
Drives: FT86
+1 on what @Kodename47 said
on stock tune the 02 sensor only reads down to 11.2 even if actual afr is much richer.
look at the throttle their is a big dip round 6400 as kode said look like trac kicked in and closed throttle.
I don't think ecutek logs IAM if you don't have racerom in ecu for some reason.
looks like stock tune to me judging by target afr in 10 range, so looks pretty normal for a stock tune
Old 02-08-2018, 09:43 AM   #42
TofuJoe
Ohne Titel
TofuJoe's Avatar
Thanks, guys! Yes, there was a loss of traction. And @steve99 you are correct that IAM wasn’t an available parameter on the stock tune (no ECUTek license).
@Kodename47 I’m not sure if FLCK or engine load were available as I was borrowing a computer and cable, and it was set up for me with a default set of parameters.
The point of the log was to make sure that going to a 2013-2016 airbox on my 2017 doesn’t necessitate a tune. This swap was needed to allow room for an oil cooler.
I saw recently on Facebook that the OFT will now log 2017 cars, but I haven't confirmed. If the OFT works for IAM, FLKC, etc., maybe I'll get one and do some more logging.
PTUNING Plug and Play WMI (Water/Methanol Injection) System and ECUTek Tuning ptuning Forced Induction 71 02-27-2019 07:55 AM
Works Axle Back Muffler Review (Works ABM) ButeraFRS Engine, Exhaust, Transmission 16 03-15-2018 06:23 PM
WORKS Exhaust System - Development 86_ZN6 Engine, Exhaust, Transmission 305 02-24-2014 04:57 AM
Borla UEL Header, works automotive parts and ecutek tune clayrush Engine, Exhaust, Transmission 14 06-27-2013 03:37 PM
subaru brz navigation system wire diagram? watching movies usb works !! SgtBolt Audio/Visual, Electronics, Infotainment, NAV 3 06-21-2012 11:31 PM
