Old 02-03-2018, 08:03 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by evoto86 View Post
Run velocity stacks please, i need stacks in my life haha.
Design me a full intake plenum with stacks! I will gladly buy one if it looks promising and test it.
Old 02-04-2018, 03:44 AM   #16
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Not seeing any specs on the SARD unit. I'll take measurements...
In the pdf, where it says 45φ, pretty sure that's diameter in mm.
cyde01 is offline   Reply With Quote
Old 02-04-2018, 09:03 AM   #17
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
I'm still hoping for measurements because that can give us information about the runners/airflow tract.
For example, is the it tapered (doesn't look like it)? How smooth is the transition between the runners and the silicone connectors? Are there smooth entries to the runners inside the plenums of both brands?
Did they tell the truth about the TB diameter? Did they both measure in the same spot (at the TB butterfly)? How's the finish inside the runners?
Does the shape change from the 45/48mm round TB to the oval-ish intake port result in an increase or decrease in cross-sectional area? By how much? The more data, the better AFAIC.
So, win/win for measuring.
Williampreza is offline   Reply With Quote
Old 02-04-2018, 11:29 AM   #18
86_IT
86_IT's Avatar
Can't wait for the data as this is a huge part of my planned build.
Instagram: 86_IT Twitter: 86_IT_BRZ Facebook: 86itbrz Youtube:86 IT
86_IT is offline   Reply With Quote
The Following User Says Thank You to 86_IT For This Useful Post:
Trust86 (06-27-2018)
Old 02-04-2018, 03:59 PM   #19
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Not necessarily available but, the WELD FR-S had been running custom ITB's for a while. I'm posting as it may be useful in some way even if a bit light on specifications. I do believe it was removed as it was never correctly running.
So that meant throwing the cheap and nasty plastic intake manifold in the bin and fabricating a one-off crossed item from aluminium piping. Onto this Johnny bolted Toyota AE111 4A-GE mechanical throttle bodies with a set of billet velocity stacks. And check out the XSA RC wheel mounted onto the throttle shaft! 380cc/min injectors from a 1JZ were then mated to a pair of custom fuel rails. The whole set up is controlled by a Vi-Pec ECU, which Trust fitted and then tuned. This was actually the biggest headache of all, as the wiring and setting-up of the quad throttle conversion turned out to be a real nightmare. But Johnny and the guys got there in the end and the car sounds and feels impressive.
Images
The Following User Says Thank You to Kiske For This Useful Post:
CSG Mike (02-05-2018)
Old 02-04-2018, 06:19 PM   #20
Hawk77FT
Drives: GTS 86
@celek is also working on an ITB solution for 86/brz.
Hawk77FT is offline   Reply With Quote
Old 02-27-2018, 06:40 PM   #21
Snake
Drives: ADM Toyota 86 GT
Any update on this? Super keen to see the results.
Snake is offline   Reply With Quote
The Following User Says Thank You to Snake For This Useful Post:
why? (03-01-2018)
Old 02-27-2018, 06:57 PM   #22
CSG Mike
CSG Mike's Avatar
real R&D (and progress) is slow.
It'll be months before any concrete results are published.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
86_IT (02-28-2018), Snake (02-28-2018), Teseo (03-01-2018), Williampreza (02-28-2018)
Old 02-28-2018, 02:02 AM   #23
86_IT
86_IT's Avatar
I'll be waiting here anxiously!
Old 02-28-2018, 03:03 AM   #24
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Subscribed.
Old 03-01-2018, 06:01 PM   #25
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
it will be interesting to see what they offer. The sard one is being advertised for 3k on 86 worx. Can it really be worth that much money?
As cool as the idea is and as hopeful as I would be they would increase response, is this what the other kits are going to cost as well?
why? is offline   Reply With Quote
Old 03-11-2018, 06:35 PM   #26
Grimnor
Drives: 2017 Toyota 86
If these ITB's can get me to ~220 wheel hp with the Ace a350 and e85 I think it would be worth it for me and my car and I would certainly order it. I think that's going to be more power than can be had out of these but I also have unreasonably high hopes.
Grimnor is offline   Reply With Quote
The Following User Says Thank You to Grimnor For This Useful Post:
SuperTom (02-05-2020)
Old 03-11-2018, 08:14 PM   #27
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Agreed, I could see myself going ITB's in the future if this is the case
Barefootdan is offline   Reply With Quote
Old 03-11-2018, 09:54 PM   #28
CSG Mike
CSG Mike's Avatar
It'll cost as much as a SC with that type of setup, but the throttle response will absolutely be superior...
In for the long haul Ultimate NA build thread. celek Engine, Exhaust, Transmission 683 06-07-2020 07:26 PM
TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL Andrew666 AUSTRALIA 8 11-19-2018 05:24 AM
RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** RallySport Direct Transmission and Driveline 92 09-01-2015 01:17 PM
RallySport Direct's Ultimate Interior Thread! RallySport Direct Interior Parts (Incl. Lighting) 45 03-25-2015 02:12 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 06:25 PM
