Old 01-23-2018, 02:38 PM   #43
StraightOuttaCanadaEh
Wes
You mean a Subaru??
now it makes sense lol
Instagram: @gt86ws
Old 01-23-2018, 02:50 PM   #44
Yes. I don't just think it. I clearly said it.
I have no trouble with this transmission. I know exactly what is happening when it's cold and I deal with it.
Do those same professional drivers complain to tire manufacturers about the lack of traction when their tires are cold?
It's not just this transmission. All manuals sharing a couple key characteristics behave exactly the same way. There is no 'fix.'
Keep in mind you are talking to a bunch of guys that are used to a couple of feet of cables, rods and linkages that serve to mask all resistance with a built in sloppiness. The difference between that and a few inches of lever hooked up directly to the tranny are magnified in the cold. It takes about 5 minutes of driving for the tranny to warm up enough for smooth shifts but this is the age of instant gratification so that is too long for some. Even in the coldest weather this thing shifts like butter compared to some of my old cars with a tranny mounted shifter.
Old 01-23-2018, 02:58 PM   #45
Originally Posted by Pat View Post
Deal with what? There's nothing to deal with if the transmission works as it should, right?
Works as designed. With understanding comes realistic expectation. I know you don't go balls out on your first lap.
Old 01-23-2018, 03:05 PM   #46
How it should've come from the factory.
Old 01-23-2018, 03:30 PM   #47
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You mean a Subaru??
Toyota.
https://kaizenfactor.wordpress.com/2...n-or-is-scion/
ineedyourdiddly
Old 01-23-2018, 04:11 PM   #48
JD001
JD001's Avatar
Drives: Subaru BRZ
Mixing components, risky business. Ask anyone into bitsa hi fi systems..
Old 01-23-2018, 04:25 PM   #49
reeves
Pentosin's still working wonders for my 2nd gear shift/feel.
It's been below freezing here recently too.
Old 01-23-2018, 04:32 PM   #50
Wes
I'm down to give it a try next time around. Been hearing good things.
Instagram: @gt86ws
Old 01-23-2018, 09:35 PM   #51
There is a fix, it's called 'compromise'
And it leaves everybody unhappy.
Which gen? The F56 one is crap, the knob has come off in my hands three times on course and it's vaguer than a passive aggressive lover.
hmmmm.......would you like to expound on that analogy .....??
Old 01-23-2018, 10:23 PM   #52
strat61caster
Sorry, I'm not skilled enough to teach an old dog new tricks
ineedyourdiddly
Old 01-23-2018, 11:27 PM   #53
Old 02-03-2018, 11:23 PM   #54
highway7
Drives: FRS 2013
Well I don't think the issue is resolved if it takes an adjustment to the driver. That's what we call a work around. I say we should look at the root cause and address that, which is clearly not the driver.
This. One thing I notice on this forum are 86 owners who can't criticize the car one bit.
Yes you can 'fix' the 2nd gear cold weather lock out as a driver by;
-Double clutching to 2nd
-Shifting out of 1st earlier at a lower RPM
-Avoiding 2nd and lug in 3rd for a few seconds
-Drive slowly for 5-10 mins for the fluid to warm up
-etc etc etc
But why should we have to do any of this on a supposedly 'sports car' where smooth shifting is essential; when my 14 year old civic (Economy car) can be shifted with a pinky finger at -35C into any gear at any RPM?
Some of you fanboys are so delusional that the torque valley dip which is incredibly noticeable at anything above 50% throttle is a 'feature' to you
Don't get me wrong, I love my FRS and would buy it again, but not addressing the faults this car has and blaming owners for 'not being able to drive' for voicing out their perfectly valid complains is just damn childish.
highway7 is offline   Reply With Quote
Old 02-04-2018, 12:24 AM   #55
-etc etc etc
Old 02-04-2018, 03:24 PM   #56
Zentec
Drives: 2017 Toyota 86
Look if it’s cold out let the car warm up. If it’s warm out let the car warm up. Then drive. When your making coffee in the morning do you put your coffee grounds in the cup with what ever else and add cold water then drink it? No you warm up the water put that in with the grounds brew or press the coffee pour and drink it. Do you your self spring out of bed run in shave or ect rush to work and have a happy and full of energy No you wake up drag your self out of bed get coffee and it takes you at least half hour before your conscious of the world around you. Mechanicals are the same way everything should be operating at the correct level before you put stress on it.
How can it not be the driver everyone who is having the problem is clearly driving wrong. It’s not a work around it’s clearly some people learned to drive wrong. I have never had any issue of putting this car in gear or shifting I think it’s actually one of the smoother shifting transmission I’ve had. My car is compleatly stock. If you can’t figure it out get an automatic still not happy get another car! Every car is a little different it’s up to you to adapt and drive the car not have to car change to suit you. That’s why your the DRIVER!
Zentec is offline   Reply With Quote
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 11:54 AM
Down shifting into 2nd gear when cold Flame9020 Issues | Warranty | Recalls / TSB 27 12-22-2016 04:24 PM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 06:17 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
