Old 02-03-2018, 05:21 AM   #1
smudge
Drives: Supercharged GT86
V8 plug and play ECU
Needing some help with ECU's for my 1UZ V8 swap
I know that the Motec is an ideal solution but it's just way out of budget
I've been reading on here about various solutions:
- Hydra EMS
- Link
- Haltech
- Emtron KV8
Is there anything other than Motec that has the same function to run everything on the CANBUS? We already have a custom loom made up for the V8 but the issue is getting the car's electronics working obviously
smudge is offline   Reply With Quote
Old 02-03-2018, 05:22 PM   #2
In4kickz
Drives: 2015 FRS
I emailed element tuning about the hydra. It seems like a great setup for me because I’m looking to do a LS3. Although after talking to them, this system will work with the LS1 and LS2, they just have to set the triggers in the EMS for the older style motors. I suggest calling/emailing them.
info@elementtuning.com
tel(240)246.0302
In4kickz is offline   Reply With Quote
Old 02-03-2018, 06:26 PM   #3
smudge
tel(240)246.0302
Thanks
I've contacted Phil through messenger as I've talked to him before about a few bits
Also been reading that Emtron have developed something for the 86 and has a few 2JZ and LS swaps running on their KV8 system
Old 02-03-2018, 06:39 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The options are detailed in this thread (they do need a bit of an updated but for the most part they’re still pretty accurate).
CAN Bus solution database (what works/what doesn't work)
https://r.tapatalk.com/shareLink?sha...5&share_type=t
There is no magical wand on this. If you want your setup to have everything to work like it was from factory, the only option is Motec from Pure Automotive. If you are willing to have a few systems not working, (e. g. traction control, (Motec does it better than the stock control), A/C, ABS, to name a few then you can select from any of the others that have the systems working you absolutely need.
Old 02-03-2018, 08:42 PM   #5
smudge
Thanks! I knew this was somewhere but couldn't find it
I wish Motec was within my budget but I can't justify over £4k for it...especially when I'm not bothered about CC, TCS or A/C
Think the Emtron might be a good middle ground for my application
Old 02-04-2018, 05:01 AM   #6
BRX
BRX's Avatar
Drives: Toyota GT86
Contact Gerald: http://www.geraldjustprojects.com
He made my CAN BUS translator for my 3UR swap. Great guy and very responsive. I don't think the 1UZ had CAN BUS so it should be much easier for him to convert analog signals to the FT86 CAN BUS IDs. He has all the required IDs for the BRZ/86 side to make all the following work: power steering, temp gauge, tachometer, and ABS. AC too even if you have the dual climate one. However cruise control and traction control don't work and I don't really care to be honest.
Sent from my Pixel 2 XL using Tapatalk
BRX is offline   Reply With Quote
Old 02-04-2018, 02:20 PM   #7
smudge
Thanks
Yeah the 1UZ is a fairly simple engine, no CANBUS.
And I'm the same as you, TC and CC aren't something that I need, more interested in having the full cluster working, ABS, power steering etc
What ECU are you running with the 3UR?
Old 02-04-2018, 02:23 PM   #8
BRX
BRX's Avatar
Drives: Toyota GT86
Thanks
Stock so far. Only thing left to figure out are the air injection pumps. I'll be bypassing them soon to make the engine work at 100%.
Where to get plug and play HID Burrcold CANADA 16 12-21-2016 02:45 PM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
ECU Plug and Play Mo707 Engine, Exhaust, Transmission 8 08-26-2012 11:21 AM
HID Plug 'n Play Kit JW89225 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 07-31-2012 12:17 AM
Which hid plug n play kit? huma Cosmetic Modification (Interior/Exterior/Lighting) 11 07-20-2012 11:10 PM
