| Engine Swaps Discussion of engine swaps. |
Drives: 2017 WR BLUE BRZ
Input on building ls headers
I’ve been looking at the different ways it’s been done and of course the biggest problem I see is getting around the steering shaft.
Weapons grade and JDL put the header primaries and collectors in the engine bay and then run a 3” out around the outside of the steering shaft. Biggest drawback I see with this setup is heat in the engine bay and maybe this hurts flow a bit with the pipes not being a straight shot back? It appears on the JDL set up they added heat shielding around the headers, I wonder if things were melting? ![]() ![]() ![]() ![]() ![]() Even on the synergy motor they put the headers in the engine bay ![]() Vorshlag and a few others have run the header primaries back and around the steering shaft to the collectors along side the transmission. I like this method for flow and getting heat out of the engine area but it’s super tight, looks like it will put a ton of heat on the rack and pinion where the shaft goes in and also super tight with the collectors next to the transmission. ![]() ![]() ![]() ![]() ![]() ![]() Thoughts/input? |
#2 |
Drives: 2015 FRS - FFR GTM
I'm not sure I have much to add,,, but have you looked at a Tri-Y header?? Maybe 2 pipes into 1 in the engine bay,,, then the remaining 2 into a collector by the tunnel. 2 - 2" tubes by the steering shaft will still be snug I'm sure.
https://www.corvetteforum.com/forums...y-headers.html
2015 FR-S - One Day I'll Finish The Swap |
#3 |
Drives: 2013 FRS / 2013 427 Vert
In my case I've decided to go the LS route as well after too many issues with the FA20 in high G load conditions. However my power goals are 475- 500 crank maximum which I think I can achieve with just an LS3, mild cam and oem exhaust manifolds which should make fitment interference much less of an issue. Am I missing something?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#4 |
Panda Trueno
Drives: No twin now.
I dont know off hand of any commonly used ls longtubes that keep the collector in the engine bay. I would try and follow the path of a large gain header company as close as possible in designing the header and exhaust in general. I used kooks 1 7/8 headers two times and was impressed with the results and fitment. I bought a third set too but never put them on before selling the vehicle, lol. I would try and emulate that as close as possible.
#5 | |
I’m using the pvc method, building a set putting the collector after the steering shaft, see how that looks |
#6 | |
Drives: 2013 Ultramarine FR-S
#7 | |
Looking at it from different angles, the whole point is to have long tubes. If I build the whole header to fit before the steering shaft they won’t be that long and they will be too close to the peripheral components possibly melting things. So yeah, I think you’re right about trying to follow what the header companies do. Interesting to note in examining all the big names in Corvette headers B&B was the only one I found out of all of them that sequenced the header primaries by firing order.
#8 |
Roughly put the “problem side” together.
Getting the tubes perfectly equal is going to be next to impossible....and not important enough to risk the hot tubes being to close to something that shouldn’t get too hot. Shortest tube will be within 4-5 inches of the longest tube. Looking at what I’ve got...I’m seeing that the easiest way to get these in will be to support the motor and drop the cradle. Headers going up from the bottom. ![]() ![]() ![]() Also looking at what I’ve got, I’m trying to decide if it would be better build them with air gaps in between the primaries or tighten up the whole unit? Thoughts on tightness of the tubes? |
#9 |
![]() Headers came out great |
#10 |
I Love custom Turbo kits
Drives: Limited BRZ
#11 |
So change of plans. The pvc method looked promising but I think I had a bit of luck. A buddy of mine suggested I contact a local header company and see if they could build my headers. I knew of the company but I didn’t know they were local.
Sanderson headers, I called them up and sure enough backlogged until April...unless I could bring the car right now, they had a cancellation. Yep! Called another buddy with a tow truck and took the car down. They had just finished building the headers for this ford. ![]() ![]() So I think I’m in good hands. Would have been fun to build my own but these guys do this for a living lol Even got a tour of the factory In case you ever wondered how they made the ceramic coated headers shine They said they should have it done in about a week. |
#12 |
Panda Trueno
Oh wow..... not only the locality but the opening.... lucky. They will definitely sort something out!
#13 |
I just Drive.
Drives: in the womb still
So your name is going to be on the kits they sell after mocking yours up now right
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
#14 |
Haha, mine will most likely only work with vorshlag mounts...so not sure how many they would be selling....also... I’m going to be the one finalizing the design on these things. The whole system didn’t quite turn out as I wanted so I need to make some changes.
| Building the perfect car -14 Brz | chris.toferrr | Member's Car Journals | 1 | 12-11-2017 03:36 PM |
| Building Sophie | Justinyuen16 | Member's Car Journals | 27 | 08-19-2014 03:34 AM |
| building the fa20 | ggiddix | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 08-02-2014 12:04 PM |
| Building our second BRZ Limited | heptoman | Member's Car Journals | 89 | 01-14-2014 10:58 PM |
| Building my FR-S | Gillams | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 09-06-2013 12:37 PM |
