Old 02-02-2018, 08:01 PM   #1
Eazy-V
Full 3” exhaust vs half 3” with 2.76” on FI
So, my car is FI tuned up to E75 with 3” downpipe, 3” overpipe, 3” catted frontpipe and 2.76” catback exhaust, so would changing to 3” catback make a big difference?
Also, I know that air can only move as fast as the narrowest part of the exhaust, so is it safe to say that the 3” portions I have make no difference since my catback is 2.76”?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 02-02-2018, 08:16 PM   #2
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
no...it depends on how often and long you are at load...
The real answer is "It Depends"....
At what point do you have a bottleneck? do you have an open wastegate or does it feed into the exhaust stream? How long are you at a high enough load to cause restrictive backpressure?
The fluids(in this case exhaust gases) will open up into the 3" portion and then at the 2.76" portion they will start to back up. The longer you have enough load to create enough back pressure through the whole pipe to limit power, the less power you'll make.
This is because the bottleneck will force the fluid in the 3" portion to start to back up but it has to get all the way back to the turbo/engine before the engine will recognize the restriction.
If you are no longer at enough load for the back pressure to increase all the way back to the engine(in a truly discernible way, technically the backpressure will START to increase immediately), and the gases can flow freely through the 2.76" section without unduly increasing back pressure, there should be no noticeable or even measurable difference.
Jaden
Jaden is offline   Reply With Quote
Old 02-03-2018, 07:53 AM   #3
gtengr
Drives: 2017 BRZ
Tough to answer. Exhaust cools and contracts as it flows through the system, so a 2.76" rear section may not be as restrictive as 3" coming out of the turbo. On E75 the 3" pipe is probably restrictive too.
gtengr is offline   Reply With Quote
Old 02-03-2018, 11:16 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
That is a common misconception. Exhaust gasses will actually flow faster through a narrower pipe, and have a lower local pressure at the same time. The problem is that smaller diameter pipes have greater losses to friction because of a higher surface area to cross-sectional area ratio.
Another thing to think about is the transition between the 3" and 2.7" sections. If this is abrupt, that's where most of your losses would come from. You are essentially stopping a portion of your exhaust flow, making it turn 90 degrees, pushing it into the rest of your flow, and turning it 90 degrees again before continuing.
So does 3" vs 2.7" make a difference, yes. More so in FI cases because more air means higher rate of loss for a given length. However, most folks in the real world don't see much of a difference from a catback on NA at least. Haven't looked much at FI exhaust comparison myself.
GREDDY SpeedMaster 3" Catback Exhaust - HALF OFF RETAIL! ZeroTo86 Engine, Exhaust, Bolt-Ons 1 12-28-2016 10:56 PM
SOCAL: Full Exhaust/Parts: Tomei UEL, Berk Hi-Flow Catted FP, Perrin 2.5 Reso Exhaust Scubasteeve Engine, Exhaust, Bolt-Ons 12 03-27-2016 04:33 AM
Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? fooddude Engine, Exhaust, Transmission 39 12-15-2013 02:05 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
