Old 01-30-2018, 03:33 PM   #3459
wu_dot_com
Drives: accord
So I’m finally done with my suspension spec out for my 13brz. Looking for some advise
Bilstine B6, OE BRZ front spring 2.7k, OE FRS rear spring 3.8K, OE front sway 18mm (+1 if require), 15mm rear sway, Enkei rpf1 17x8, +45mm, on 225x45x17.
Plus whiteline rear subframe blushing insert.
Total parts cost w/o tires is under 2K.
I’m hoping to achieve minimal drop, little more grip (stock engine), better balance towards oversteer.
It’s mostly for DD, but eventually like to do track.
Thanks.
wu_dot_com is offline   Reply With Quote
The Following User Says Thank You to wu_dot_com For This Useful Post:
bhmax (01-30-2018)
Old 01-30-2018, 05:08 PM   #3460
Racecomp Engineering
Thanks.
Sounds solid. What type of tire?
- Andrew
wu_dot_com (01-30-2018)
Old 01-30-2018, 05:24 PM   #3461
wu_dot_com
Drives: accord
- Andrew
Hey Andrew thanks for the quick reply. Long time no talk.
Michellen PSS, it’s 120/ tire at Costco when it’s on sale.
Old 01-30-2018, 05:31 PM   #3462
That'll be fun. You'll have a little body roll so you'll want some negative camber. Up front -2 would be great for a DD, or at least -1.5.
- Andrew
Old 01-30-2018, 05:53 PM   #3463
wu_dot_com
Drives: accord
- Andrew
Perfect, this is exactly what I’m looking for, -2 to -1.5 for the front camber. Since I’m planning to use OE top hat, can this adjustment be done with $50 camber bolts?
Please advise.
Old 01-31-2018, 12:11 AM   #3464
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Please advise.
SPC 81260 bolt in the lower hole, take the bolt from the lower hole and put it in the upper hole, $20 + alignment, over -2 should be easily possible. Go straight to -2.0 if you are headed to the track, on OE suspension I had the front camber up at -3.2 before I felt happy with the balance (camber plates).
https://www.amazon.com/Specialty-Pro...ords=81260+spc
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Racecomp Engineering (01-31-2018), wu_dot_com (01-31-2018)
Old 01-31-2018, 10:55 AM   #3465
And just be sure you take it to a good competent alignment shop.
- Andrew
strat61caster (01-31-2018)
Old 01-31-2018, 11:46 AM   #3466
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
- Andrew
^THAT
Old 01-31-2018, 12:40 PM   #3467
Azzudien
Drives: 2017 Series Yellow BRZ
- Andrew
Easier said than done, this has been a pain point for me. Albany NY has no decent alignment shop.
Azzudien is offline   Reply With Quote
Old 02-09-2018, 12:08 PM   #3468
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
hey guys, new to the forum and modding but ive had stock long enough and want to change. i have a 2014 frs with 95,000 km and was looking at lowering springs but after reading they have a chance to blow and not to blow but since i have many miles on it should i get the new 2017 shocks to go with some springs(rsr/eibach/tein 1.2-1.4") or just buy aftermarket shocks? thanks
JustSomeGuy is offline   Reply With Quote
Old 02-09-2018, 12:20 PM   #3469
Vital
Drives: 2015 BRZ
the stock shock and strut will most likely hold up to springs that lower the car 1" or less. RCE, RSR, TRD, Eibach Pro-Kit and Hotchkis all lower 1" or less. If you want to lower more than that than yes an aftermarket shocks are ideal or just get coilovers.
Old 02-09-2018, 12:53 PM   #3470
JustSomeGuy
A Nobody
Drives: FRS
is also upgrading to 2017 shocks a viable option? just asking cause since they would be cheaper? not for permanent cause eventually i do wanna get bilstein
Old 02-09-2018, 01:09 PM   #3471
Vital
Drives: 2015 BRZ
The 2017 are still OEM and were not exactly designed for aftermarket springs unless you get the Sachs dampers from the BRZ PPs. Using 2017 dampers is most likely not going to be any different than using dampers from 2013-2016. Also, the RCE Yellows are a good option as they were designed for OEM shocks and struts and they only lower the car 20mm
Old 02-09-2018, 01:16 PM   #3472
JustSomeGuy
A Nobody
Drives: FRS
ah okay gotcha, i was just curious since they would have a lot less mileage on them that oem 2017 would last a year or so at least then i could upgrade to coils or aftermarket shocks
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
