Old 12-15-2017, 09:41 PM   #141
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2300LB FRS
Anyone running the StopTech 355x32 Front with an 18x9.5 wheel?
ShibusaTouge is offline   Reply With Quote
Old 01-18-2018, 09:58 PM   #142
EvoPrecision8
Drives: 2015 BRZ Sport Tech
Does the CSG Brembo GT kit have any confirmed fitment for 17" wheels? Specifically wondering about TC105Ns.
EvoPrecision8 is offline   Reply With Quote
Old 01-30-2018, 03:33 PM   #143
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
The CSG Brembo GT kit is similar in dimentions to the BBK on the Performance Pack which has confirmed fitment on 17x9 TC105N.
Lynxis is offline   Reply With Quote
Old 02-01-2018, 12:49 PM   #144
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
AP sprint
Enki rpf1 +45 need a 10mm spacer but fit fine.
Sent from my Pixel using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 02-18-2018, 02:31 PM   #145
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Stop Tech 328 BBK with ST40 Calipers
Clears Rays 57DR 17X9 +38 by a huge margin. Like almost 3/4 of an inch.
Clears stock wheels with 10mm Spacer by about 3/16 at the closest point.
Also, using the 50mm Nismo studs allows you to use stock lugs on the stock wheels with spacer. Without spacer with the 57DR's my PMU Super 7's will tighten all the way down and hold the hat in place.
Old 02-28-2018, 08:03 AM   #146
Jackal84
Jackal84's Avatar
Drives: Toyota GT86
Hi all,
There is any template about the Brembo STI WRX 2008+ with 326 30 discs?
I would like to know if clears these alloys:
Enkei RPF1 17x8 +45
Rays 57DR 18x8.5 +38
Jackal84 is offline   Reply With Quote
Old 02-28-2018, 10:16 AM   #147
churchx
churchx's Avatar
Drives: 2014 GT86
There are very few that retrofit non native designed brakes on twins. I'd guess you might be more successful in wrx/sti related forums regarding clearance of specific wheels.
Old 03-16-2018, 07:30 PM   #148
Nedschmidt
Drives: Hot lava frs
Does anyone know if the wilwood 6 piston bbk will fit 17x8 +45 rpf1"s?
Nedschmidt is offline   Reply With Quote
Old 04-04-2018, 06:48 PM   #149
stlgrym3
does 17X9 +35 fit Brembo GT 326 BBK?
stlgrym3 is offline   Reply With Quote
Old 08-01-2018, 03:32 PM   #150
Guest
Drives: 2017 BRZ PP
Looking at picking up some RS05RR's in 18x9.5 +43.
Anyone know if that would clear the performance package Brembo's?
Guest is offline   Reply With Quote
Old 09-19-2018, 04:39 AM   #151
thornad
Drives: 2016 GT86 N/A
RPF1 17x7.5 +48mm
Does anyone know if RPF1 17x7.5 +48mm fit StopTech 4pot (328x28mm) front kit ?
Originally Posted by Hags86 View Post
Hi
I wanted to keep the stock offset and similar width (don't ask me why, it seemed like a good idea at the time). My Enkei RPF1 17x7.5 +48mm arrived today and I can confirm the following:
Stock: Fits with lots of space
Essex Sprint: Fits easily with the closest part to the spoke being 5mm
Essex Endurance: Tight, but fits. The closest part to the spoke being 2mm
AP Racing Formula Front: Good clearance to spokes but only 3mm to the outside rim. A wheel weight would NOT clear.
AP Racing Formula Rear: Good clearance to spokes but only 3mm to the outside rim. A wheel weight would NOT clear.
Wilwood BBK Front: Does not fit. No way, no how.
Wilwood BBK Rear: Good clearance to spokes but only 4mm to the outside rim. A wheel weight would NOT clear.
thornad is offline   Reply With Quote
Old 01-06-2019, 09:17 PM   #152
brandon525
Drives: 2014 frs (someday)
Originally Posted by post_break View Post
Finally able to show proof that the TSW 17x8 +45 fits no problem.
Are you on stock suspension? Just curious. Glad to see that it fits the TSW Nurburgring.
Sent from my Moto G (5) Plus using Tapatalk
brandon525 is offline   Reply With Quote
Old 01-14-2019, 01:53 AM   #153
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
Outside of the RFP1 what Enkei rims can fit a BBK as a 17 inch diameter and 8 to 9 inch width?
Ryan GT86 is offline   Reply With Quote
Old 01-22-2019, 05:36 PM   #154
Dumpster Dan
Drives: 2018 BRZ PP
In my search for wheels for my 2018 BRZ with Performance Package, I ended up measuring my car and creating a clearance template. My initial measurements weren't super accurate; I used a combination square and dial calipers in some crazy orientations in a 20 degee parking garage. However, I printed the template out a few times to double-check on the car and made modifications as needed. I would say it's accurate to about a millimeter. I figured I would post the thing if it might help anyone out, just remember it was created by some idiot on the internet. As with any clearance template, print full scale and verify a few of the dimensions before cutting out. Make sure there's at least 3mm clearance between the template and the wheel.
Now the tricky part is checking wheels that I don't have yet. Any chance someone has TSW Nurburgrings in 17x8 +35 or +45 that they would be willing to check?
Dumpster Dan is offline   Reply With Quote
The Following User Says Thank You to Dumpster Dan For This Useful Post:
churchx (01-22-2019)
big brake kit, brembo, essex, stoptech, template
Dyno Database E92M3Guy Engine, Exhaust, Transmission 33 04-17-2013 10:20 AM
The *Official* BRZ Pre-Ordered Database Thread Zaku BRZ First-Gen (2012+) — General Topics 727 03-17-2013 07:29 AM
We should start a dealer BRZ order database eikond BRZ First-Gen (2012+) — General Topics 13 03-01-2012 12:56 PM
