Old 01-15-2018, 07:22 AM   #743
churchx
churchx's Avatar
Drives: 2014 GT86
Yes. Supposedly to make impression of more powerful engine.
But i guess that many tuning ecu also do throttle remap for easier fine throttle control, instead of it coming in fake lump as stock. Given that i often need to balance with throttle in mid curve understeer/oversteer bias, i'd rather prefer low & mid being not that progressive and often resorting to pulsating pedal instead of giving just enough for smoother control with such custom linear mapping.
Old 01-29-2018, 03:55 PM   #744
CSG Mike
CSG Mike's Avatar
More independent results.
91 octane tune via CSG/DT.
Ace A/350 + Ace front pipe.
Same car, same dyno, w/out header w/out tune vs tuned w/ header + fp.
Car has a Grams 72mm throttle body and Skunk2 Powerbox CAI
*edit*
As always, ignore the numbers themselves, and look at the % gains. This dyno shows about a 20% gain in horsepower output. 184whp is very solid, when you consider that the stock baseline is 153whp.
*edit 2*
Car has a Grams 72mm throttle body and Skunk2 Powerbox CAI for both dynos.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
bhmax (01-29-2018), Code Monkey (01-29-2018), new2subaru (01-29-2018), ThatAsianBradah (01-29-2018)
Old 01-29-2018, 04:18 PM   #745
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
Same car, same dyno, stock vs tuned w/ header + fp.
Everything 3k RPM and higher just looks amazing 👌 I'm especially impressed with 5.5k---->7500 RPM power with the A350 + Ace FP vs Stock. Pair this baby up with a P/D Supercharger and you got major torque and power all across the power band 😍👍
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
The Following User Says Thank You to ThatAsianBradah For This Useful Post:
CSG Mike (01-29-2018)
Old 01-30-2018, 07:41 AM   #746
Chamaco
Drives: Silver FR-S
Finally got mine 2 weeks ago and installed on Saturday. Will report back after I get it tuned.
**Edit** don't know why the pictures were posted all screwy.
Chamaco is offline   Reply With Quote
Old 01-30-2018, 07:52 AM   #747
bfrank1972
Drives: 2013 FR-S Argento
*edit*
Sorry but this is misleading Mike - just confirmed with the original owner that the 'before' tune is a car with a stock tune, but bigger MAF and bigger airbox, which can cause issues with the stock tune.
I know dynos are relative but Just look at the *shape* of the curve past 6k on the 'before' graph - a 100% stock car does much better than that on the top end, and the point of falloff is well before a stock car hits peak HP. Comparing his un-tuned setup before to just about any decent header out there will show big gains.
That said, ACE is a great header for sure - look at that flat torque curve... but let's not use cars with tune issues as baseline comparisons and call them stock.
The Following 3 Users Say Thank You to bfrank1972 For This Useful Post:
Pointmutation (02-01-2018), Tcoat (01-30-2018), Trueweltall (01-30-2018)
Old 01-30-2018, 09:23 AM   #748
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Where are these headers made?
Old 01-30-2018, 09:30 AM   #749
Taiwan
nikitopo (01-30-2018)
Old 01-30-2018, 11:00 AM   #750
Lantanafrs2
Drives: 2013 frs red
If the op had air "straightener" sleeve in the skunkbox it shouldn't hurt the performance on a stock tune imo. The delta would probably remain the same.
Lantanafrs2 is offline   Reply With Quote
Old 01-30-2018, 12:55 PM   #751
CSG Mike
CSG Mike's Avatar
I'm only reporting what I was told. Don't shoot the messenger. I have zero control over 3rd party results.
Old 01-30-2018, 01:17 PM   #752
FunnyGopher
Drives: 2015 BRZ Limited
It's not a larger MAF. Stock MAF and stock MAF housing size. In fact, Delicious told me the AFRs matched stock AFR levels extremely well, and only had to do a touch of MAF scaling with the new tune. What I mentioned in the other thread was that my guess (I'm not an expert, pls teach me) for the weird HP dip was the air velocity in the intake not being so great in the top end, because the piping after the MAF was so big. The actual MAF housing is stock sized.
This exactly, which is what Delicious also confirmed with me.
My guess is as good as anybody's though. It was either the massive intake piping, or the larger throttle body. Either way, the new tune is amazing.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 01-30-2018, 01:32 PM   #753
bfrank1972
Just look at your old top end, was not normal. Changing the intake definitely can throw your MAF scaling off. MAF scaling being off, load calculations will be off, cam timing/ignition timing/afr will be off. Could very much explain that curve - obviously I have no idea what Delicious did but I do know while your old bottom end looked ok, you were loosing a lot on your top end compared to a 100% stock car. Once tuned/rescaled, all that goes away plus the benefits of your new header so you're good to go. It's just not valid for indicating power gains an ace header will provide over a stock car, or even a tuned stock car. Just raising awareness and keeping it real, not trying to shoot the messenger Enjoy your new power
Sent from my SM-N920V using Tapatalk
Old 01-30-2018, 03:10 PM   #754
n0thing
Drives: Subaru BRZ
Is there any to gain with ACE FP (3" pipe & 2.5" flange) vs other aftermarket catless FP (2.5" pipe)?
n0thing is offline   Reply With Quote
Old 01-30-2018, 03:24 PM   #755
bhmax
Drives: 13 BRZ, 17 Focus RS
I love the feel of the car with my Ace header. I’ve toyed with the idea of the Ace FP. Would like to keep a cat though. Curious how a 3” cat welded in would help or hurt Ace’s intended flow of the FP.
bhmax is offline   Reply With Quote
Old 01-30-2018, 03:49 PM   #756
Hades
Hades's Avatar
Drives: 2013 Scion FRS
For those that have gone with this header, how has it satisfied your desire for power? Do you still long for F/I?
Hades is offline   Reply With Quote
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
