Old 01-26-2018, 08:52 AM   #4537
CSG Mike
CSG Mike's Avatar
Originally Posted by ryejeff View Post
At the risk of rehashing old/well-known content, will you elaborate?
You responded pretty strongly with a sentiment to get a newer car. I thought I heard (but I'm not an expert) that later 2013 cars included fixes. Is there any 2013 that would be acceptable? If so, how would I recognize a 2013 that was built late enough?
I was under the impression that the early build date 2013s suffered from a few things that were fixed. Are these the problems that make you recommend a 2014+? Are there additional things I'm missing?
  • Weak TOB (aside: was this ever fixed? when?)
  • Coil packs prone to heat problems (again, when was this fixed, if ever?)
  • Fuel filler hose internal collapse
  • Moisture intrusion into taillights (though I wouldn't expect this to cause a problem on track)
I am hoping to get a twin at some point and want to make sure I get the best fit for my intended use. Thanks for the info!
DI seal issues as a result of a bad factory tune.
You cannot undo the damage that has resulted from that tune, and you will have other issues, including those you've mentioned above (although most are not pertinent to tracking).
My recommendation remains that you avoid a first year car completely.
Old 01-26-2018, 09:06 AM   #4538
ryejeff
Drives: Miata
Oooh. First I have heard of that. Seems like a bad thing. Thanks for bringing it up.
Okay. Are all of your concerns addressed with a 2014?
ryejeff is offline   Reply With Quote
Old 01-27-2018, 02:38 AM   #4539
CSG Mike
CSG Mike's Avatar
Mostly, yes.
Old 01-29-2018, 04:00 AM   #4540
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
So if tracking a first year car would changing the DI seals help any? Is there more risk if they are damaged or is it just the damage to the engine from their issues that a problem? I have been running a new tune for most of the cars life (even got an updated ECU but still right before the good tunes I think (3/13 date on the new ECU iirc).
I don't plan to sell my car to update and will just get a newer powertrain when this one fails. But wondering if any steps might help prolong that lol
Old 01-29-2018, 02:55 PM   #4541
CSG Mike
CSG Mike's Avatar
If you change the DI seals, and have an updated tune, then the problem will not happen again, but by the time you pay for all that, you would have easily covered the difference in cost to say... a 13 to a 15, which not only carries the DI seal fix, but many other QC issues.
In your case, just address the issues as it happens; my previous statement is primarily for people buying used cars.
Old 01-29-2018, 03:11 PM   #4542
finch1750
finch1750's Avatar
Got it. Thanks for the info.
Old 02-01-2018, 09:19 AM   #4543
brianxxx
Drives: 86
Hi mike do you have the part number for HC800 for front and rear? in Australia here we have gt and gts model and the part number for the rear seem to be R914-HC800 and R916-HC800 respectively. Front seems to be F914-HC800. However, I'm not sure if thats correct and just wanna make sure i order the correct parts.
Thanks in advance,
Brian
brianxxx is offline   Reply With Quote
Old 02-01-2018, 04:01 PM   #4544
CSG Mike
CSG Mike's Avatar
Thanks in advance,
Brian
916 is the larger rear. I do not know for the smaller.
I don't recommend you attempt to track on the HC800 at all.
Old 02-01-2018, 08:28 PM   #4545
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Is there a specific reason why? I have seen plenty of threads on these pads that you have commented on and not mentioned this before.
Old 02-01-2018, 08:44 PM   #4546
CSG Mike
CSG Mike's Avatar
Better to have more pad than you need to grow into, than have a pad that you'll outgrow, and effectively have just paperweights.
Old 02-11-2018, 07:34 PM   #4547
86Craze
Drives: 2016 FR-S
What tires to run in SM class? I am currently on RE71s, should I stick with it ?
86Craze is offline   Reply With Quote
Old 02-11-2018, 08:49 PM   #4548
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
SM allows Hoosiers, but if you don't want to go all the way to slicks then stick withe the Bridgestones.
14stu is offline   Reply With Quote
Old 02-12-2018, 12:01 PM   #4549
finch1750
finch1750's Avatar
Has anyone done a comparison of Harry's Lap Timer with phone GPS compared to an external or AiM? I will be buying Qstarz before my next track day but am curious/trying to settle an argument lol
Old 02-12-2018, 12:49 PM   #4550
jjaisli
jjaisli's Avatar
Drives: 2013 Scion FR-S Firestorm
I did a few years ago with an iPhone 6. Surprisingly the times were within about .2 of a lap or less over 3 laps vs an AIM Solo in the car.
IMO, for out right timing, Harry's and a modern smart phone do a surprisingly good job. Where it falls short, is when you export the data and try and work with it. The data overlay is improved if you use an OBDII dongle, but when you're dealing in 0.1, between on/off throttle, the amount and frequency of data points being collect by Harry's falls short. I remember looking at data collected at the bus stop at WGI 2 years ago, trying to compare a brake trace [Edit: between multiple laps] (Harry's doesn't, at least not on a twin) and looking at throttle tip in, there just wasn't enough data points to really do a proper comparison.
EDIT: My ultimate conclusion is this: Harry's Lap Timer does a good job if you want to time yourself. And it will give you relatively accurate lateral g loading. You can look at your laps and see where you can maybe push a bit harder here or there. Where it falls short is if you want to actually work with that data and compare multiple laps and really see where you're gaining or losing time.
jjaisli is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
