Old 01-25-2018, 09:53 AM   #85
omg why do you have summer tires on in the winter?! lol
I take mine off in october and put them back on in april or so. They have a fairly unforgiving operating range. They do well in wet weather (more so when they're newish), but the tread pattern is not blockish enough to grab onto snow covered roads. There is nothing to displace snow. If you look at the tread blocks on your tires, they're rounded off. Winter tires have square blocks with plenty of space in between. In cold temperatures, they get real hard too and you're actually harming them.
Many people like to focus on tread pattern but the ability of the compounds to deal with cold is the much greater factor. A really soft squishy winter compound with the same tread as the summer tires would work far better than a hard summer compound with a snow tread.
stevesnj (01-25-2018), StraightOuttaCanadaEh (01-25-2018)
Old 01-25-2018, 09:54 AM   #86
stevesnj
stevesnj's Avatar
Explains the high insurance rates there.
Here in NJ, someone hits you and it's their fault the victim's insurance goes up too.
My 2016 Build thread
Old 01-25-2018, 09:55 AM   #87
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
The cold affects tires far more than snow. The summer performance tires are designed hard so that in hot weather they soften up for traction. Anything even approaching freezing can firm them up into hockey pucks. All season tires deal with the cold a little better but are of course a compromise between being hard and soft so that they can deal with a wider range of temperatures. Winter tires are very soft so that when it gets cold out they can still retain traction even though they do firm up. Earlier in the year We had a run of sub zero temperatures here (-4 to -6 Fahrenheit) where even my winter tires got hard enough to lose traction on bare pavement.
Thanks man!
I'm curious, does the snow or salt hurt the summer tires in any way or cause its traction or deteriorate? I know it sounds crazy but I think I heard someone say it can wear out the residue/compound on the performance tires that adds extra grip?
dinfern22 is offline   Reply With Quote
Old 01-25-2018, 09:58 AM   #88
dinfern22
dinfern22's Avatar
...Makes sense. I'd buy the winter tires with the car if i'd lived in Canada. But here in Maryland the weather is confusing as shit. One year it can snow hard while another year its barley cold.
The Following User Says Thank You to dinfern22 For This Useful Post:
Old 01-25-2018, 10:01 AM   #89
Originally Posted by dinfern22 View Post
Thanks man!
No. It has no different effect than driving on pavement. There is no magical chemical reaction between rubber and salt.
Old 01-25-2018, 10:04 AM   #90
If I lived in Maryland I would just run a decent all season. They can handle the slight deviations you have with ease. You could run summer tires for most of the year and just use the all seasons during the worst of the winter. I run all seasons for most of the year and just use the winter tires for the bad part of winter so you would just be dropping a level with the same effect.
Old 01-25-2018, 10:29 AM   #91
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Originally Posted by Celica00 View Post
I'm bored so here we go. Converting the OEM tire 215/45/17 dimensions to inches would be ~8.5in x 24.5in. Get the area of the circle with pi x radius^2 => 3.14 x 12.25^2 = 471.2. Then volume of a 8.5in cylinder 471.2 x 8.5 = 4005.2
Now minus the rim area which is about 1928.4 making the area of the tire about 2076.8 cubic inches or 1.2 cubic feet
Let's compress this shit to idk what max is... 51 psi?
(psi x cubic feet)/ earth's atmosphere pressure
(51 x 1.2)/14.7 => 4.16 cubic feet per tire x 4 = 16.64 cubic feet
Each cubic foot of helium has a lift of .069 pounds.
If my partially drunk math is correct, then .069 x 16.64 = 1.15 pounds of lift.
Totes worth.
Imperial units makes my head hurt.
But, it looks like you're saying that pressurized helium produces more lift than helium at 1 atm, and that can't be right?
Old 01-25-2018, 10:36 AM   #92
Wes
Just to add my experience to this, I drove in bad snow in all season Michelin AS3 and had a lot of trouble taking off. Endless wheelspin, and terrifying braking distances. That was in a FWD Mini. Considering I get endless wheelspin in bad snow even with snow tires on in the 86, I doubt a performance all season tire would bring much improvement. One leaning towards good all weather traction would probably serve best.
Instagram: @gt86ws
Old 01-25-2018, 10:53 AM   #93
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
One thing to keep in mind - I've read discussions from the tire engineering types that the compounds used in high end summer tires can be irreparably damaged if they are even exposed to very cold temps. To drive those tires in the cold is claimed to effectively destroy them. WFTW
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Tcoat (01-25-2018)
Old 01-25-2018, 11:34 AM   #94
This ^ I should have mention this! Salt won't hurt them but cold can and will. Goes right back to how hard they can get. Chunks can and will chip right off. Storage isn't that big a deal if they are supported properly.
Old 01-25-2018, 12:17 PM   #95
Wes
what does that mean
Instagram: @gt86ws
Old 01-25-2018, 12:25 PM   #96
what does that mean
JohnJuan (01-25-2018)
Old 01-25-2018, 12:33 PM   #97
Riftur
Riftur's Avatar
The message I sent you came off wrong. After i reread it I noticed it might have come off wrong. It was more about me growing up and not about threats. I reread it and saw that was not the point i was trying to make.
Riftur is offline   Reply With Quote
Old 01-25-2018, 12:56 PM   #98
Wes
*runs to the garage to flip wheels around*
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Tcoat (01-25-2018)
Am I the only one that feels bothered by this (R.S 1.0) 1GiantTurtle Scion FR-S / Toyota 86 GT86 General Forum 22 12-11-2014 08:18 PM
Rear LCA Install Help/Something feels off srizzors25 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 10-28-2014 10:52 PM
18's or 19's ... What looks and feels best on FR-S. Jon1084 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 65 07-19-2013 06:42 PM
Everything else feels like driving a bus! BRZnut BRZ First-Gen (2012+) — General Topics 42 01-21-2013 08:30 PM
Feels like christmas! yeabude BRZ First-Gen (2012+) — General Topics 3 06-11-2012 01:59 PM
