Old 01-22-2018, 03:30 PM   #3025
autoXracer
Drives: 2013 WRB BRZ
Originally Posted by oinojo View Post
For around $2k or less can get you revalved (my valving) AST 4100s similar to what I ran at Nationals. I would contact MANN Engineering and speak to Jan.
I just recently did a set for an SFR SCCA member and was very happy with the ride and performance.
Would love to hear your thoughts on the 5/9kg setup over a more traditional 7/9kg spring setup?
autoXracer is offline   Reply With Quote
Old 01-22-2018, 05:56 PM   #3026
M0nk3y
7/9k is traditional?
That’s new to me
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
DocWalt (01-22-2018)
Old 01-22-2018, 06:02 PM   #3027
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Try it out and see if it works for you.
G_Ride is offline   Reply With Quote
Old 01-22-2018, 06:54 PM   #3028
autoXracer
That’s new to me
I wasn’t very clear. What I meant was spring rates in the range of 7 to 9k. Example a square setup or somewhere in the range of 7/8k to 7/9k front/rear. I know everyone has their preference in spring rates, and sway bars have a big impact. I thought of trying out RCE T2’s 7/9k setup with 22m front and 16mm rear.
Old 01-23-2018, 05:52 PM   #3029
oinojo
Suspension Nerd
oinojo's Avatar
Drives: 2019 Mazda MX-5
Swaybars are a speed sensitive device in terms of rate, springs are not - they are linear. Often times if you run more front spring than is needed (ride), you end up on the softer end of swaybar settings. This is good for lower speeds, but often ends up hard to drive and less confidence inspiring at higher autox speeds. You also end up with a setup that is site sensitive when too extreme (extreme high rate/small bar).
Swaybars work exponentially. The more the bar twists, the more rate it will provide to a point. The front bar does a fair job of keeping stability as speed increases. However, the swaybar won't work as well if you limit its movement with stiff springs.
How do you find out what is too much spring? Simple. Figure out the ride frequency. There is enough aftermarket support for this platform that you should be able to tune over/understeer with the swaybars and shocks rather than springs. The springs should just be firm enough to give better response but not compromise ride quality. (2.1-2.2 front / 2.4-2.5 rear)
OS Giken / Bridgestone / Lot-USA BRIDE
oinojo is offline   Reply With Quote
The Following 8 Users Say Thank You to oinojo For This Useful Post:
AFRichZC6 (02-02-2018), autoXracer (01-23-2018), cjd (01-24-2018), DocWalt (01-23-2018), G_Ride (01-24-2018), justinco (01-23-2018), NJ10 (02-26-2018), strat61caster (01-24-2018)
Old 01-23-2018, 10:49 PM   #3030
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by Simmons View Post
What seat bracket are people using?
Simmons
You want the Buddy Club mounts. 9lbs each.
Buddy Club Racing seat rail, left/driver side
Buddy Club Racing seat rail, right/passenger side
justinco is offline   Reply With Quote
Old 01-23-2018, 11:10 PM   #3031
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I have 2 events on the 5k/9k setup so far. It is a little different, but I do not feel it was a drastic change from my 7k/7k square setup I ran at Nats. Or, even the 8k/8k springs I ran the year before. The biggest thing I noticed was the car was much better/faster in fast slaloms.
One thing I have learned is that there seems to be lots of different spring setups that can work. I've gotten feedback from a number of notable people/vendors with drastically different suggestions lol as I try to learn more about how springs affect the drive. Everything from 11k/13k, the 5k/9k, everything in between, and even stiffer front springs ie: 11k/9k.
I will be testing 9k/11k here soon, mostly because I don't know much about spring tuning and want to see how it feels for myself. I have some other combinations to try as well, but Fontana will be here before I know it and I need something that works good soon
The Following 5 Users Say Thank You to justinco For This Useful Post:
autoXracer (01-23-2018), cjd (01-24-2018), dowroa (01-24-2018), e1_griego (01-23-2018), strat61caster (01-24-2018)
Old 01-23-2018, 11:35 PM   #3032
oinojo
Suspension Nerd
oinojo's Avatar
Fontana you need something compliant.
The Following User Says Thank You to oinojo For This Useful Post:
justinco (01-24-2018)
Old 01-24-2018, 12:19 AM   #3033
autoXracer
Thanks for the feedback! Some good info to think about. I agree there’s various setups that work, and everyone has their own preference. Another reason I love STX, having the ability setup and see what works best for you. I was on a softer 5/4k setup first, then 7/6k. Planning my next move lol, as I have 9k springs sitting in my garage.
Old 01-24-2018, 08:52 AM   #3034
cjd
cjd's Avatar
Drives: 2017 BRZ
What swaybars go with the softer front rate? So many things to try!
The Following 2 Users Say Thank You to cjd For This Useful Post:
Shark_Bait88 (01-24-2018), strat61caster (01-24-2018)
Old 01-24-2018, 12:01 PM   #3035
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I am 400/350 right now
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following User Says Thank You to Simmons For This Useful Post:
Old 01-24-2018, 12:42 PM   #3036
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I have a 20mm Whiteline front and OE rear and I couldn't get it to work (325/500), but I also didn't nail alignment (the consequences of jumping in over my head) and needed to work on my driving talent. Going to try and make it work this year after trying a 425# spring in various configurations with the other two, like Justin mentioned it's kind of incredible that the car feels relatively the same even with radically different spring setups.
@oinojo mentioned using a 22mm solid Perrin front and the 13mm Mann rear in another thread. For whatever reason stiffening the front/rear in ride relatively equally seems to need a big change in sways to keep the roll balance, the front feels soft and compliant but the rear feels super stiff in comparison (at least on my setup, dampers might be playing a factor), I meant to see if I could figure it out with maths but guess I'm just ambitious without follow through like on those SPC bushings I have measurements for
ineedyourdiddly
cjd (01-24-2018)
Old 01-24-2018, 01:00 PM   #3037
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
For me, I switched to the Perrin 22m front early 2017 (from the Whiteline 20mm). Ran the 14mm OEM rear all year but now on the Mann eng bar stiff setting.
The Following 2 Users Say Thank You to justinco For This Useful Post:
cjd (01-24-2018), strat61caster (01-24-2018)
Old 01-24-2018, 01:22 PM   #3038
oinojo
Suspension Nerd
oinojo's Avatar
yes. swaybar is important and thankfully the aftermarket has a vast amount of bars available to meet the needs. I used a Perrin 22mm on full soft and MANN Rear bar on Stiff. Put power down like a champ... oh yah and a STX tuned OS Giken LSD
Springs were 280/504.
The Following 5 Users Say Thank You to oinojo For This Useful Post:
autoXracer (01-25-2018), cjd (01-24-2018), DocWalt (01-25-2018), justinco (01-26-2018), strat61caster (01-24-2018)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
